查看: 15475|回复: 1
CDRS2001问题
 关闭 [复制链接]
发表于 2004-5-15 19:24:19 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
我安装了CDRS2001后,启动的时候,总是蹦出来个dmgr的应用程序,过了一会就没响应了,什么问题?
发表于 2004-5-15 19:32:32 | 只看该作者
dmgr 是启动程序    不影响应用的
  ) Open ptc.dat in txt editor and where it say: HOSTID=PTC_HOSTID=00-00-00-00-00-00
   Replace 0's with your own mac address.
2) Save the changes and run keygen.bat to generate a license
CDRS 2001 Build 450:
1) Run setup and deselect license management and then select help
   and animator.
2) Select all options to install.
3) Hit the add button for "Specify license Server" and select node lock options.
  &nbspoint the browser to the license file you created.
4) Configure the cdrs2001 by selecting the start command line and then hit edit. Define the
   paths and the start commands for the other ptc products if applicable.
5) For the rest of the installation use the defaults unless you know what your doing.
GMT+8, 2025-4-27 10:18 , Processed in 0.055318 second(s), 11 queries , Gzip On, Redis On.
