查看: 15803|回复: 2
求各位大侠了转换".STL"格式的参数怎么设定呀
发表于 2004-5-16 13:49:16 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
求各位大侠了转换".STL"格式的话这参数怎么设定呀
"点应用后就提示:不能三角剖分2曲面,尝试手工修复?"怎么修复呀
这个格式是不是CNC用的呀
求求各位大侠了,我先给您作揖了!!!
发表于 2004-5-16 13:49:52 | 只看该作者
求求各位大侠了,我先给您作揖了!!!
发表于 2004-5-17 12:27:37 | 只看该作者
The first coloum you can enter 0 and the next one use 0.1.
The second picture has problems in the CAD sturcture, you can use add point or delete point to release the errors. If it's not working, you can export the file in step and use Solidwork or UG to conver it.
GMT+8, 2025-4-30 17:35 , Processed in 0.023368 second(s), 11 queries , Gzip On, Redis On.
