查看: 15282|回复: 1
【求助】icemsurf 4.3
发表于 2004-5-16 21:58:24 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
哪位能告诉我ICEMSURF4.3怎么安装??谢谢!!
发表于 2004-5-17 08:30:35 | 只看该作者
可能在这问这问题不大好吧
ICEM Surf v4.3.0
1) Run setup and select ICEM Surf and the Flexlm License Server and install
   the programs.
2) Open the license.dat in the crack directory and change "host" to your computer name.
   Copy the license.dat and theorem.dat to <drive>:\icem\flexlm-8.3.0\lic directory.
3) Run flexlm.cpl in the "lic" directory and manually setup Flexlm services for ICEM
   and start the license server.
4) Set the following environment:
   LM_LICENSE_FILE = 27010@host;<drive>:\icem\flexlm-8.3\lic\theorem.dat
   Note: Change "host" to your computer name and "<drive>" to your installed drive.
         and do not remove the ";" in the value.
5) Run the program and select main menu "Windows" and then in the pull down "License".
   Select all the boxes to license and hit the save button at the bottom.
6) Copy the content of "Tiff_Library" on CD2 to <drive>:\icem\icemsurf-4.3.0\surf\Tiff_Library.
  下不为例哦
GMT+8, 2025-4-29 19:38 , Processed in 0.019181 second(s), 11 queries , Gzip On, Redis On.
