查看: 16300|回复: 0
【求助】extern int UF_MODL_create_thru_curves 的用法
发表于 2004-5-19 09:59:03 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
extern int UF_MODL_create_thru_curves (
UF_STRING_p_t s_section,
UF_STRING_p_t s_spine,
int * patch,
int * alignment,
double value[ 6 ],
int * vdegree,
int * vstatus,
int * body_type,
UF_FEATURE_SIGN boolean,
double tol[ 3 ],
tag_t c_face_id[ 2 ],
int c_flag[ 2 ],
tag_t * body_obj_id );
其中UF_STRING_p_t s_section, UF_STRING_p_t s_spine,
  tag_t c_face_id[ 2 ], int c_flag[ 2 ], 参数不知是什么意思
请高手指点,最好给个例子
GMT+8, 2025-1-31 07:47 , Processed in 0.019839 second(s), 10 queries , Gzip On, Redis On.
