查看: 16207|回复: 1
奇怪,一台机器可以装TC,另一台不行!!!
发表于 2004-5-20 16:51:26 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
我在一台机器装上了TC,而原来出错的机器却在重装中一直出现下面问题!!十分不解!!(我已经全部卸载ORACLE和TC了,只差重装Win2000了!!)
盼高手解决!!!!!
shell.err,内容如下:
2003-12-30 11:01:25
Command Executed:
checkfrm -fmtien_us.frm -btmti.frm -q tmti.fri
Output from Command:
*** <tokLoad> (tokbuf.c - 930): error opening Load file <C:\APPS\TC31> *** <metaparse> (metparse.c - 7145): error reading optimized file *** traceback - metaGetDefaultMeta : ( 20) not okay *** traceback - ufmLoadAllForms : ( 20) not okayTeamcenter Enterprise 3.1 on 03-12-30 at 11:01:26.(21ui001, 0, ./ui.c, uiInitCapture, 222)Teamcenter Enterprise 3.1 on 03-12-30 at 11:01:26.Client Internal Error: File ufmload.c, routine ufmLoadAllForms, line 1360.This session should be terminated. See file NULL for details.(20uitext003, 20, ufmload.c, ufmLoadAllForms, 1360)Client Internal Error: File ufmload.c, routine ufmLoadAllForms, line 1360.This session should be terminated. See file NULL for details.
发表于 2004-5-21 13:16:12 | 只看该作者
唉,没办法,重装了w2000,才搞定,累死我了。实在不知问题出在何处,希望大家在此多发表些见解,交流一下!!个人猜测是TC在注册表了做了标记!不让反复重装!
GMT+8, 2025-4-15 01:57 , Processed in 0.025645 second(s), 12 queries , Gzip On, Redis On.
