查看: 16005|回复: 3
【求助】tolerance setting problem. Help!!!
发表于 2002-10-5 08:26:49 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
When I was creating the features, the default tolerance mode was limit. Now I finish the whole part and create the drawing of the part. I change the tolerance mode to Nominal in the config.pro file. And from utilities/optioins/..., I can see the changed setup. But the tolerance showed on the drawing does not change the format.
And after I change the config.pro, the tolerance mode of new part is changed. How can I changed the old ones?
发表于 2002-10-5 09:41:23 | 只看该作者
Please follow up :
Menu--->Format-->Decimal Place-->Enter Value-->ick Many ....-->Done
发表于 2002-10-5 16:23:54 | 只看该作者
修改config里的tol_mode只會對new part起作用的
在舊的drawing文件里可以一次選擇多個尺寸然后右鍵--properties在彈出的菜單中改tolerance mode為normal就行了
如果該選項是灰色的﹐則改drawing setup里的tol_display為yes同時還要該
发表于 2002-10-6 03:30:45 | 只看该作者
thanks!
GMT+8, 2025-4-8 19:54 , Processed in 0.022734 second(s), 13 queries , Gzip On, Redis On.
