查看: 16307|回复: 6
SE15补丁4发布了。
 关闭 [复制链接]
发表于 2004-5-27 19:22:17 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
补丁 4 能帮助我们解决以下程序存在的问题:
=====装配=====
PR 1324981:
In some cases 'File->Open', 'Activate' and 'Close and Return' is slower in V15 than in V14.
PR 2034939:
Fit command does not work correctly after edit in place and Hide Previous Level. The provided assembly contains three parts with their RPs all hidden. If a part is edited and Hide Previous Level is selected, the part display seems to be incorrect and the RPs no longer are considered for Fit. Zooming out shows a strange problem with the RPs display. This does not occur if the part RPs were shown before editing.
PR 4931970:
Fixed multiple crashes in the display pathway based on Auto Crashlogs received.
PR 4944916:
Sheet Metal model does not show when in-place activated.
PR 4948924:
When a part is conatrsined to a line in a sektch, the system places the part in the same orientation regardless of which choice is selected.
PR 4949922:
Fixed multiple crashes in the Place Part pathway based on Auto Crashlogs received.
PR 1325190:
Alternate assembly is placed in draft. The assembly is opened from draft, and File Properties are activated from Assembly Pathfinder. When the properties dialog is dismissed an abort occurs.
PR 4969294:
Fixed multiple crashes in the highlight lists pathway based on Auto Crashlogs received.
PR 4970096:
Fixed multiple crashes in the locate pathway based on Auto Crashlogs received.
PR 1308473:
If you in-place edit a subassembly you cannot use the 'select all identical parts' option to locate parts.
PR 1326549:
The Relative To pulldown list is once again populated with the appropriate existing coordinate systems in the Assembly environment.
PR 4912423:
Can only single select parts if subassembly is in-place activated. If a subassembly is in-place activated, their parts can be selected one by one, but the fence select, or 'Select Small Parts' are not able to select parts.
=====零件=====
PR 1257298:
When the supplied Assembly will be saved as STEP with the options as Volume, AP214 and Millimeter and reimported in UGNX or IDEAS wrong surfaces will be generated at the holes (revolved cutouts).
PR 2028858:
Can not apply a "Base Styles" color from within the "Color Manager" environment to a Body feature for some cases.
PR 4931539:
The problem of surface by boundary creating a large spike has been fixed.
PR 4948212:
Trimming a surface is inconsistent with its results after the Side step option
PR 1309682:
Fix for a crash in BlueSurf when using periodic sections, guide curves and user defined vertex maps.
PR 4968909:
The multiple crashes in CUnknownEnumDataHolder::ClearEntries have been corrected based on Crashlogs.
PR 4952929:
A fix has been made to correct a display problem with dimension text when the handle color was set to black.
=====绘图=====
PR 1319011:
Corrected a problem that could cause parts to disappear from drawing views after view update.
PR 1324286:
Corrects problem with line colors not being copied to derived views.
PR 2036507:
The problem where SE aborts when the textbox is highlighted is fixed in.
PR 4916341:
The problem of views disappearing on export to AutoCAD has been fixed.
PR 4920219:
Corrected a problem that could cause parts in drawing views to disappear after those views were updated.
PR 4921101:
The problem where SE aborts when saving draft files having broken views is fixed.
PR 4928838:
PR 4936590:
Fixed a problem with moving from draft to assembly and back using assemblies of parts with displayed reference planes.
PR 4633032:
The problem with drawing view hatching not honoring layers is fixed.
PR 4937110:
The problem where the dimensions are not moving with the view when the break region is applied is fixed in V15SP4.
PR 1316836:
View does not show cutaway after update
PR 2033778:
The problem where the dimensions are losing thier position(broken) after save,close and open is fixed in V14SP14.
PR 4959844:
The problem of hatch not clipping to detail circle when export to DWG has been fixed
=====开发接口=====
PR 1327051:
Corrects problem with ModelMember.DVLines2d.Count.
PR 1327288:
Fix for FOA per member automation issue
PR 4952023:
This problem of SaveBody api crashing when called through automation.
=====Insight=====
PR 4886984:
markup aborts using measurement commands
PR 4952504:
Crash while using Rev Man assistant on FOP member.
PR 2036236:
User will now see the error dialog giving information that the probable cause of failure may be due to missing of SharePoint client component from the machine.
PR 4948494:
Developer logging will be now always enabled during migration via SharePoint migration tool.
PR 4952613:
Lifecycle crash when selecting a folder in doc library.folder
PR 4954034:
V1 to V2 Insight Migration interrupted with Microsoft Excel warning dialog box
PR 4954889:
Now migrated part files will not contain "thispart" string in their name on Solid Edge side.
PR 4956891:
Clicking on the document library folder from Delete From Library dialog taking too much time. Fixed this problem
PR 4958705:
Able to upload assembly files having a variable link to itself.
PR 4962765:
Migration tool will now migrate files from SPS V1 to SPS V2 along with the custom properties.
PR 4944287:
Documents will follow approval process though user has "Manage List" rights on the Sharepoint Document Library End user should properly remove the "Microsoft.Sharepoint.Workflow.Utilities" assembly from GAC and install new assembly.
PR 4962765:
PR 4962937:
V1 URLs without filename portion will be logged upfront as invalid files during migration
PR 4968249:
User can now Saveas new asm(in memory)to SP V2 server with link to local file(drag-n-drop).
发表于 2004-5-28 09:50:52 | 只看该作者
哪里可下?
发表于 2004-5-28 16:40:52 | 只看该作者
ddz wrote:
哪里可下?
头像被屏蔽
发表于 2004-5-28 21:55:52 | 只看该作者
提示: 作者被禁止或删除 内容自动屏蔽
发表于 2004-5-29 19:24:00 | 只看该作者
用正版的可以在网上升级吗?
发表于 2004-5-31 08:57:51 | 只看该作者
sywzb0478 wrote:
中文版出了没?用英文太累了!
中文版已经出来快一个月了吧。
正版用户如果处于维护期内的话,是可以在网上直接下载升级补丁的。
发表于 2004-7-3 15:23:16 | 只看该作者
请好心人告诉网址
GMT+8, 2025-4-8 06:32 , Processed in 0.026494 second(s), 11 queries , Gzip On, Redis On.
