返回列表 发新帖
【求助】作工程图,无法使用自己定义的标注尺寸的属性
发表于 2004-6-3 21:23:42 | 只看该作者
zhaxia wrote:
This functionality is only available with drawings created with versions up to V5 R10.
  This functionality is not available with drawings created with version V5 R11 and later, nor with drawings created with older versions and whose standard has been updated or changed in V5 R11 and later. These drawings use the styles which are defined in the standard used by the drawing. Standards are managed by the administrator.
刚才又看了一下,10以上的版本OPTION中设置不管用。只能进入管理员模式搞了。TNND,麻烦!!!!!
发表于 2004-6-4 09:40:45 | 只看该作者
这一点感觉不是很爽。。。
发表于 2004-6-8 17:17:54 | 只看该作者
这个问题怎么解决!请斑主帮忙呀!
在R1O中一切OK!怎么在R12中就没法解决!
GMT+8, 2025-4-26 02:54 , Processed in 0.019595 second(s), 10 queries , Gzip On, Redis On.
