查看: 5911|回复: 10
[求助] 怎么才能用SW-API
发表于 2016-12-15 17:03:22 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
Sub 打开文件()
Range("A3").Activate
Set swApp = CreateObject("SldWorks.Application") '启动SW
Dim intChoice As Integer
Dim FilePathName As String
Dim i As Integer
HeaderRow = 2
RowNumber = 3
PathName = Cells(RowNumber, 1) '讀取第一個路徑的值
While Not (PathName = "" Or PathName = 0 Or IsEmpty(PathName)) '直到讀完路徑欄(尋找繼續填寫的位置)
    RowNumber = RowNumber + 1 '下一列
Wend '回到>直到讀完路徑欄
Application.FileDialog(msoFileDialogFilePicker).AllowMultiSelect = True '設定為多選對話框
Application.FileDialog(msoFileDialogFilePicker).Filters.Clear '清除既有類型
Application.FileDialog(msoFileDialogFilePicker).Filters.Add "零件自定义属性", "*.SLDPRT" '設定檔案類型
Application.FileDialog(msoFileDialogFilePicker).Filters.Add "零件配置属性", "*.SLDPRT" '設定檔案類型
Application.FileDialog(msoFileDialogFilePicker).Filters.Add "装配体自定义属性", "*.SLDASM" '設定檔案類型
Application.FileDialog(msoFileDialogFilePicker).Filters.Add "装配体配置属性", "*.SLDASM" '設定檔案類型
Application.FileDialog(msoFileDialogFilePicker).Filters.Add "工程图属性", "*.SLDDRW" '設定檔案類型
If Cells(1, 1) = 1 Or Cells(1, 1) = 2 Or Cells(1, 1) = 3 Or Cells(1, 1) = 4 Or Cells(1, 1) = 5 Then
    Application.FileDialog(msoFileDialogFilePicker).FilterIndex = Cells(1, 1)
End If
If Cells(1, 2) <> "" Then Application.FileDialog(msoFileDialogFilePicker).InitialFileName = Cells(1, 2)
intChoice = Application.FileDialog(msoFileDialogFilePicker).Show '彈出對話框
If intChoice <> 0 Then '判斷有否點選檔案
    RowCount = 1
    swFilterIndex = Application.FileDialog(msoFileDialogFilePicker).FilterIndex
    For i = 1 To Application.FileDialog(msoFileDialogFilePicker).SelectedItems.Count '逐一讀取所選檔案
        FilePathName = Application.FileDialog(msoFileDialogFilePicker).SelectedItems(i) '讀取完整檔案名稱
        FilePath = Left(FilePathName, InStrRev(FilePathName, "\")) '分解路徑
        FileName = Right(FilePathName, Len(FilePathName) - Len(FilePath)) '分解檔案名稱
        FileExtname = UCase(Right(FilePathName, 6)) '分解檔案類型
        If swFilterIndex = 1 Or swFilterIndex = 3 Or swFilterIndex = 5 Then
            Cells(RowCount + RowNumber - 1, 1) = FilePath '填寫路徑
            Cells(RowCount + RowNumber - 1, 2) = FileName '填寫檔案名稱
            RowCount = RowCount + 1
        End If
        If swFilterIndex = 2 Or swFilterIndex = 4 Then '過濾器是2或4
            swConfigNames = swApp.GetConfigurationNames(FilePathName)
                ConfigColor = 200
                For Each swConfigName In swConfigNames
                    Cells(RowCount + RowNumber - 1, 3).NumberFormatLocal = "@" '设为“文本”格式
                    Cells(RowCount + RowNumber - 1, 3) = swConfigName '填寫模型組態名稱
                    Cells(RowCount + RowNumber - 1, 3).Errors.Item(xlNumberAsText).Ignore = True '去除三角错误
                    Cells(RowCount + RowNumber - 1, 3).Interior.Color = RGB(ConfigColor, ConfigColor, ConfigColor)
                Next
            End If '排除無效檔案<完>
    Next i '逐一讀取所選檔案<完>
End If '判斷有否點選檔案<完>
End Sub
Sub 读取配置特性属性值()
Dim HeaderRow As Integer
Dim RowNumber As Integer
Dim FileName As String
Dim swExtName As String
Dim swFileTYpe As Integer
Dim swConfigName As String
Dim vCustPropName
Dim PropValue As String
HeaderRow = 2
RowNumber = HeaderRow + 1
    FileName = Trim(Cells(RowNumber, 2))
    FileExtname = UCase(Right(Cells(RowNumber, 2), 6))
    If "SLDPRT" = FileExtname Then swFileTYpe = 1
    If "SLDASM" = FileExtname Then swFileTYpe = 2
    If "SLDDRW" = FileExtname Then swFileTYpe = 3
'    Set swDoc = swDM.GetDocument(PathName & FileName, swFileTYpe, False, mOpenErrors) '開啟
    If Not swDoc Is Nothing Then
        If swFileTYpe = 1 Or swFileTYpe = 2 Then
            If Not (Cells(RowNumber, 3) = "" Or Cells(RowNumber, 3) = 0) Then
                Set swCfgMgr = swDoc.ConfigurationManager
                swConfigName = Cells(RowNumber, 3)
                Set swCfg = swCfgMgr.GetConfigurationByName(swConfigName)
            End If
        End If
        ColumnNumber = 4
        PropName = Cells(HeaderRow, ColumnNumber)
        While Not (PropName = "" Or PropName = 0) 'Or IsEmpty(PropName)) '直到讀完表頭
            PropName = PropName & ""
            If PropName = "$Author$" Then '作者
                Cells(RowNumber, ColumnNumber) = swDoc.Author
            ElseIf PropName = "$Keywords$" Then '標記
                Cells(RowNumber, ColumnNumber) = swDoc.Keywords
            ElseIf PropName = "$Comments$" Then '註解
                Cells(RowNumber, ColumnNumber) = swDoc.Comments
            ElseIf PropName = "$Subject$" Then '主題
                Cells(RowNumber, ColumnNumber) = swDoc.Subject
            ElseIf PropName = "$Title$" Then '標題
                Cells(RowNumber, ColumnNumber) = swDoc.Title
            Else
                If Cells(RowNumber, 3) = "" Or Cells(RowNumber, 3) = 0 Then '模型組態欄位是否空值
                    vCustPropNameArr = swDoc.GetCustomPropertyNames '是
                    If TypeName(vCustPropNameArr) = "String()" Then
                         For Each vCustPropName In vCustPropNameArr
                            If PropName = vCustPropName Then
                                PropValue = swDoc.GetCustomProperty(PropName, swDmCustomInfoText) '獲取屬性
                                Cells(RowNumber, ColumnNumber) = PropValue
                            End If
                        Next
                    End If
                Else '否
                    vCustPropNameArr = swCfg.GetCustomPropertyNames
                                PropValue = swCfg.GetCustomProperty(PropName, swDmCustomInfoText) '獲取屬性
                            End If
                        Next
                    End If
                End If
            End If
            ColumnNumber = ColumnNumber + 1 '下一欄
        Wend '回到>直到讀完表頭
        swDoc.CloseDoc
        Cells(RowNumber, 1).Interior.Color = RGB(200, 255, 200)
    Else
        Cells(RowNumber, 1).Interior.Pattern = xlNoneColor
    End If
Wend '回到>直到讀完路徑欄
End Sub
Sub 写入配置特性属性值()
Dim vCustPropName
HeaderRow = 2
            End If
        End If
        ColumnNumber = 4
'                If Cells(RowNumber, ColumnNumber) <> "" Then
                swDoc.Author = Cells(RowNumber, ColumnNumber)
                swDoc.Keywords = Cells(RowNumber, ColumnNumber)
                swDoc.Comments = Cells(RowNumber, ColumnNumber)
                swDoc.Subject = Cells(RowNumber, ColumnNumber)
                swDoc.Title = Cells(RowNumber, ColumnNumber)
            Else
                    PropValue = Cells(RowNumber, ColumnNumber)
                    swDoc.DeleteCustomProperty PropName '刪除屬性
                    swDoc.AddCustomProperty PropName, 30, PropValue '新增屬性
                Else '否
                    swCfg.DeleteCustomProperty PropName '刪除屬性
                    swCfg.AddCustomProperty PropName, 30, PropValue '新增屬性
                End If
            End If
        Wend '回到>直到讀完表頭
        swDoc.Save
        swDoc.CloseDoc
        Cells(RowNumber, 1).Interior.Color = RGB(255, 255, 200)
    Else
    End If
Wend '回到>直到讀完路徑欄
End Sub
Sub 删除配置特性属性()
YN = MsgBox("作者提醒你,一旦删除不能恢复,是否继续?", vbYesNo)
If YN <> 6 Then Exit Sub
Dim vCustPropName
HeaderRow = 2
            End If
        End If
        ColumnNumber = 4
            Else
                Else '否
                End If
            End If
        Wend '回到>直到讀完表頭
        swDoc.Save
        swDoc.CloseDoc
        Cells(RowNumber, 1).Interior.Color = RGB(255, 50, 50)
    Else
    End If
Wend '回到>直到讀完路徑欄
HeaderRow = 2
i = HeaderRow
While (Cells(i, 1) <> "")
  i = i + 1
Wend
j = 4
While (Cells(HeaderRow, j) <> "")
j = j + 1
Wend
Range(Cells(HeaderRow + 1, RowNumber + 1), Cells(i, j)).ClearContents
End Sub
Sub 读取配置特性属性名称()
Set swApp = CreateObject("SldWorks.Application") '啟動SW
Dim vCfgNameArr As Object
Dim vCfgName As Object
Dim swCfg As Object
Dim nPropType As Long
Dim PropList() As String
ReDim PropList(0)
PropList(0) = ""
Dim i As Integer
HeaderRow = 2
RowNumber = 3
PropColumn = 4
PropName = Cells(HeaderRow, PropColumn)
While Not (PropName = "" Or PropName = 0 Or IsEmpty(PropName)) '直到讀完路徑欄
    ReDim Preserve PropList(PropColumn - 3)
    PropList(PropColumn - 3) = PropName
    PropColumn = PropColumn + 1 '下一列
Wend
'    Set swDoc = swApp.OpenDoc(PathName & FileName, swFileTYpe) '開啟檔案
    If Not swDoc Is Nothing Then '排除無效檔案
        If swConfigName = "" Or swConfigName = 0 Then
                     InList = False
                     For Each PropItem In PropList
                        If vCustPropName = PropItem Then InList = True
                     Next
                     If Not InList Then
                        ReDim Preserve PropList(UBound(PropList) + 1)
                        PropList(UBound(PropList)) = vCustPropName
                     End If
                Next
            End If
        Else
            swConfigNames = swCfgMgr.GetConfigurationNames
                Set swCfg = swDoc.GetConfigurationByName(swConfigName)
                         InList = False
                         Next
                         If Not InList Then
                         End If
                    Next
                End If
            Next
        End If 'If swConfigName = "" Or swConfigName = 0
        swDoc.CloseDoc '關閉檔案
        Cells(RowNumber, 1).Interior.Color = RGB(200, 200, 255)
    End If ''If Not swDoc Is Nothing
Wend '回到>直到讀完路徑欄
PropHeading = 4
For i = 1 To UBound(PropList) '- 1
    Cells(HeaderRow, PropHeading) = PropList(i)
    Cells(HeaderRow, PropHeading).Font.Bold = True
    PropHeading = PropHeading + 1
Next
End Sub
收藏收藏1 分享淘帖 赞一下!赞一下!
发表于 2016-12-15 17:17:20 | 只看该作者
樓主厲害,俺學習了。
发表于 2016-12-15 17:20:36 | 只看该作者
樓主厲害,俺學習了。
发表于 2016-12-15 20:32:52 | 只看该作者
从Range("A3").Activate这句判断,A3是指Excel中的A3单元格,
所以说这是一个Excel电子表格VBA,那就要用Excel来使用这些代码。
大致过程如下:
打开Excel
按Alt+F11
插入模块
复制粘贴代码
添加按钮,选择子程序
右键点击按钮可编辑文字,拖动边缘改变大小
发表于 2016-12-16 07:50:54 | 只看该作者
是EXCEL,打开文件那没有问题了啊。就是下面的那几个弄不了啊。能帮忙下吗
发表于 2016-12-16 09:28:29 | 只看该作者
菜虫,你别逗了啊。我也是抄别人的啊。现在换2016了啊。没有SWDM许可证了啊。看看帮我怎么能改成SW-API的啊。谢谢
发表于 2016-12-16 13:04:35 | 只看该作者
虽然不知道是什么但是看起来66666666
发表于 2016-12-16 16:59:35 | 只看该作者
没有人帮忙吗
发表于 2016-12-16 22:55:15 | 只看该作者
阿丹在台湾几何论坛有分享2016的版本
发表于 2016-12-17 08:16:03 | 只看该作者
可那个不是SW-API的吧,在说也读取不了2017的啊
GMT+8, 2025-4-19 06:51 , Processed in 0.032218 second(s), 12 queries , Gzip On, Redis On.
