查看: 3382|回复: 2
[求助] 新手求助,用SelectByID2命令总是选错边线
发表于 2017-2-28 14:31:18 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
在做下图中橙色圆圈中倒角的宏程序时,所用的SelectByID2命令总是选不对正确的边线,原因出在哪里?又该如何解决?
求高手解答,谢谢!
下面是代码
  1. Dim swApp As Object
  2. Dim Part As Object
  3. Dim boolstatus As Boolean
  4. Dim longstatus As Long, longwarnings As Long
  5. Sub main()
  6. Set swApp = _
  7. Application.SldWorks
  8. Set Part = swApp.NewDocument("C:\ProgramData\SOLIDWORKS\SOLIDWORKS 2016\templates\gb_part.prtdot", 0, 0, 0)
  9. swApp.ActivateDoc2 "零件4", False, longstatus
  10. Set Part = swApp.ActiveDoc
  11. Dim myModelView As Object
  12. Set myModelView = Part.ActiveView
  13. myModelView.FrameState = swWindowState_e.swWindowMaximized
  14. swApp.SetUserPreferenceToggle swUserPreferenceToggle_e.swInputDimValOnCreate, False
  15. boolstatus = Part.Extension.SelectByID2("右视基准面", "PLANE", 0, 0, 0, False, 0, Nothing, 0)
  16. Part.SketchManager.InsertSketch True
  17. Dim skSegment As Object
  18. Set skSegment = Part.SketchManager.CreateCircle(-0#, 0#, 0#, -0.045, 0, 0#)
  19. Dim myDisplayDim As Object
  20. Set myDisplayDim = Part.AddDimension2(0, 0, 0.09)
  21. Dim myDimension As Object
  22. Set myDimension = Part.Parameter("D1@草图1")
  23. myDimension.SystemValue = 0.09
  24. Part.SketchManager.InsertSketch True
  25. boolstatus = Part.Extension.SelectByID2("草图1", "SKETCH", 0, 0, 0, False, 4, Nothing, 0)
  26. Dim myFeature As Object
  27. Set myFeature = Part.FeatureManager.FeatureExtrusion2(True, False, False, 0, 0, 0.41, 0.01, False, False, False, False, 0, 0, False, False, False, False, True, True, True, 0, 0, False)
  28. Part.SelectionManager.EnableContourSelection = False
  29. Part.ViewZoomtofit2
  30. boolstatus = Part.Extension.SelectByID2("", "FACE", 0.41, 0, 0, False, 0, Nothing, 0)
  31. Part.SketchManager.InsertSketch True
  32. Set skSegment = Part.SketchManager.CreateCircle(0#, 0#, 0#, -0.0475, 0, 0#)
  33. Set myDisplayDim = Part.AddDimension2(0.41, 0, 0.095)
  34. Set myDimension = Part.Parameter("D1@草图2")
  35. myDimension.SystemValue = 0.095
  36. Part.SketchManager.InsertSketch True
  37. Set myFeature = Part.FeatureManager.FeatureExtrusion2(True, False, False, 0, 0, 0.24, 0.41, False, False, False, False, 0, 0, False, False, False, False, True, True, True, 0, 0, False)
  38. Part.SelectionManager.EnableContourSelection = False
  39. Part.ViewZoomtofit2
  40. '*******************************************************************************************************************************************************************************
  41. '总是不能选中正确的边线,命令中的那三个数值是边线上某一点的坐标
  42. boolstatus = Part.Extension.SelectByID2("", "EDGE", 0.41, 0, 0.0475, True, 0, Nothing, 0)
  43. Set myFeature = Part.FeatureManager.InsertFeatureChamfer(4, 1, 0.001, 0.78539816339745, 0, 0, 0, 0)
  44. boolstatus = Part.DeSelectByID("倒角1", "BODYFEATURE", 0, 0, 0)
  45. boolstatus = Part.Extension.SelectByID2("", "EDGE", 0.41, 0, 0.045, True, 1, Nothing, 0)
  46. '********************************************************************************************************************************************************************************
  47. Dim radiiArray3 As Variant
  48. Dim radiis3 As Double
  49. Dim dist2Array3 As Variant
  50. Dim dists23 As Double
  51. Dim conicRhosArray3 As Variant
  52. Dim coniRhos3 As Double
  53. Dim setBackArray3 As Variant
  54. Dim setBacks3 As Double
  55. Dim pointArray3 As Variant
  56. Dim points3 As Double
  57. Dim pointDist2Array3 As Variant
  58. Dim pointsDist23 As Double
  59. Dim pointRhoArray3 As Variant
  60. Dim pointsRhos3 As Double
  61. radiiArray3 = radiis3
  62. dist2Array3 = dists23
  63. conicRhosArray3 = coniRhos3
  64. setBackArray3 = setBacks3
  65. pointArray3 = points3
  66. pointDist2Array3 = pointsDist23
  67. pointRhoArray3 = pointsRhos3
  68. Set myFeature = Part.FeatureManager.FeatureFillet3(195, 0.001, 0.01, 0, 0, 0, 0, (radiiArray3), (dist2Array3), (conicRhosArray3), (setBackArray3), (pointArray3), (pointDist2Array3), (pointRhoArray3))
  69. swApp.SetUserPreferenceToggle swUserPreferenceToggle_e.swInputDimValOnCreate, True
  70. End Sub
复制代码
发表于 2017-2-28 15:46:27 | 只看该作者
试一下在选边线之前,在零件中将零件的视角方向调整一下
发表于 2017-2-28 16:23:05 | 只看该作者
嗯。放大并旋转视角是吧。那能告诉我,我这个地方哪里出了问题吗
SelectByID2应该是通过输入所选对象的类型,及其所具有的某一个对象(例如所选边线上的某一个点)的坐标位置来进行目标的选取吧?那在提供正确信息之后软件为何会选错?是不是我少设置了什么?
GMT+8, 2025-4-10 17:28 , Processed in 0.022980 second(s), 13 queries , Gzip On, Redis On.
