查看: 18734|回复: 3
【求助】柔性体仿真出错的原因
发表于 2004-6-9 11:15:57 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
我在做门式起重机的刚性四连杆机构仿真,我想大家都见过吧.在ANSYS里对小拉杆建模,共有三个外部结点(一端与臂架连接,另一端两头分别与平衡梁两头连接,这里是否会引进虚约束?)导入ADAMS,连接仿真,出错结果如下:
   ERROR:      The simulation is terminating at time = 0.0.
   ADAMS can not solve the equations of motion because the mechanism has
   "locked up."    At least one constraint  can  no longer be satisfied.
   ADAMS is unable to satisfy the constraint for: JOINT  MODEL_2.JOINT_23 .
ERROR:      Symbolic refactorization failed.  The matrix is structurally singular
   at time = 0.0.
WARNING:    On iteration 1, the Jacobian matrix for the initial values of
   the displacements (for the assembly analysis) is singular, a condition
   usually caused by over specification of EXACT coordinates.  Since
   ADAMS/Solver employs a penalty-function method to assemble the mechanism,
   the approach becomes less effective as more and more EXACT initial
   conditions are specified.  If the user labels too many initial values
   as EXACT, the Jacobian matrix can become ill-conditioned or even
   singular.  Although the analysis will continue, the simulation could
   fail or produce inaccurate results due to inconsistent initial conditions.
里面的“MODEL_2.JOINT_23”为小拉杆与平衡梁上两个施转副中的一个?
我百思不得其解,因为我用刚体做结果很好没有这样的错误为什么改用柔性体后会有这样的错误,是柔性体导入的问题吗?是虚约束的问题吗?但用刚体这样联接没有问题?
  请教各位大侠及斑主!!!!急盼回复
发表于 2004-6-12 01:29:57 | 只看该作者
   真么不用autoflex试试直接将刚性体替换成柔性体呢,我想知道你对象鼻梁前端的模仿货物提升的激励力真么加的啊,还有你的模型中臂架和大小拉杆里面的横格板,筋板都简化了吗,可以贴副图上来看看吗.
发表于 2004-6-14 12:28:16 | 只看该作者
用AUTOFLEX怎么把它转换能告诉我吗?象鼻梁前端的货物提升想用弹簧来做不知可否?模型没有简化我是用PRO/E画的然后再转到ADAMS里的急切盼望你的回复
发表于 2004-6-14 20:03:01 | 只看该作者
    呵呵,我其实也想用这个搞毕业设计的,我是菜鸟,我想我们能否多交流下啊,我现在还在ug建摸阶段.见笑拉,我考虑加在臂架上的变化的齿条力来拉动4连杆机构的运动,至于象鼻梁前端突然提升到平稳起升,我还不知道用什么知道用什么激励曲线啊,还有风载荷真么加啊,一般建模一般要多久啊,至于autoflex,你看帮助里面很详细的介绍啊!!!我的qq16190432希望和您这样的高手多交流!!!
GMT+8, 2025-9-18 21:01 , Processed in 0.027313 second(s), 11 queries , Gzip On, Redis On.
