made a mold cavity and core tutorial
发表于 2002-10-12 23:19:07 | 只看该作者
11.then select the Extract icon ,press the right button of mouse,select Filter,and follow the red circle step
发表于 2002-10-12 23:20:22 | 只看该作者
12.then press the right button of mouse again,select related to
发表于 2002-10-12 23:21:09 | 只看该作者
13.follow the red area step
发表于 2002-10-12 23:23:04 | 只看该作者
14.select any side surface,i-deas auto search the volume.
发表于 2002-10-12 23:24:40 | 只看该作者
15.repeat the step11-14,the select the upper mold
发表于 2002-10-12 23:26:21 | 只看该作者
use move function to move your cavity and core you'll see
发表于 2002-10-12 23:27:45 | 只看该作者
16.use move function to move your cavity and core , then you'll see
发表于 2002-10-12 23:30:11 | 只看该作者
finally i want to say i-deas is a great cad system,it's better than pro/e ,so support i-deas
19
发表于 2002-10-13 00:40:12 | 只看该作者
support
20
发表于 2002-10-14 11:19:00 | 只看该作者
不推荐这种方法,自8版后有专门的模块了,这种方法简单的还行,复杂的难应付。
GMT+8, 2025-4-10 08:34 , Processed in 0.025979 second(s), 11 queries , Gzip On, Redis On.
