查看: 17942|回复: 24
made a mold cavity and core tutorial
发表于 2002-10-12 23:03:44 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
i will show you how to use i-deas made a mold cavity and core
1.base part
发表于 2002-10-12 23:05:07 | 只看该作者
2.create a rectangle for boundary surface
发表于 2002-10-12 23:06:38 | 只看该作者
3.use trim at curve to modify the boundary surface
发表于 2002-10-12 23:07:40 | 只看该作者
4.you will see
发表于 2002-10-12 23:08:55 | 只看该作者
5.use (show free edge function) to check your model
发表于 2002-10-12 23:10:28 | 只看该作者
6.i-deas show your model have free edge , so you need to solve the problem.
发表于 2002-10-12 23:11:30 | 只看该作者
7.use stitch surface to fix your model
发表于 2002-10-12 23:13:09 | 只看该作者
8.use (show free edge) again,the free edge problem had solved
发表于 2002-10-12 23:14:58 | 只看该作者
9.made a box for mold cavity and core and make sure the box is smaller the boundary surface.
发表于 2002-10-12 23:16:09 | 只看该作者
10. use patition function to split cavity and core
GMT+8, 2025-4-7 14:10 , Processed in 0.028153 second(s), 11 queries , Gzip On, Redis On.
