查看: 18167|回复: 11
工程图配置文件祥解
发表于 2002-10-14 14:24:54 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
《工程图配置文件祥解》哪位好心的兄弟能够提供啊!:~):~):~):~):~):~):~):~):~):~):~):~):~):~):~):~):~):~):~)
! ! These options control text not subject to other options !
drawing_text_height 3.500000
text_thickness 0
text_width_factor 0.850000
! ! These options control views and their annotations !
broken_view_offset 5.000000
create_area_unfold_segmented YES
def_view_text_height 3.5
def_view_text_thickness 0.000000
detail_circle_line_style PHANTOMFONT
detail_view_circle ON half_view_line SYMMETRY
projection_type FIRST_ANGLE
show_total_unfold_seam YES
view_note std_din view_scale_denominator 1
view_scale_format ratio_colon
! ! These options control cross sections and their arrows !
crossec_arrow_length 5
crossec_arrow_style HEAD_ONLINE
crossec_arrow_width 2
crossec_text_place ABOVE_TAIL
cutting_line STD_ISO
cutting_line_adapt NO
cutting_line_segment 6
draw_cosms_in_area_xsec NO
remove_cosms_from_xsecs TOTAL
! ! These options control solids shown in views !
datum_point_size 8.000000
datum_point_shape CROSS
hlr_for_pipe_solid_cl NO
hlr_for_threads YES
location_radius DEFAULT(2.)
mesh_surface_lines OFF
thread_standard STD_ISO
hidden_tangent_edges DEFAULT
ref_des_display NO
! ! These options control dimensions
allow_3d_dimensions YES
angdim_text_orientation HORIZONTAL
associative_dimensioning YES
blank_zero_tolerance yes
chamfer_45deg_leader_style STD_ISO
clip_dimensions YES
clip_dim_arrow_style NONE
default_dim_elbows YES
dim_leader_length 5.000000
dim_text_gap 1.300000
draft_scale 1.000000
draw_ang_units ANG_DEG
draw_ang_unit_trail_zeros YES
dual_digits_diff 1
dual_dimension_brackets YES
dual_dimensioning NO
dual_secondary_units INCH
iso_ordinate_delta YES
lead_trail_zeros STD_METRIC
ord_dim_standard STD_ISO
orddim_text_orientation PARALLEL
parallel_dim_placement ABOVE
shrinkage_value_display PERCENT_SHRINK
text_orientation PARALLEL_DIAM_HORIZ
tol_display no tol_text_height_factor 0.600000
tol_text_width_factor 0.600000
witness_line_delta 1.500000
witness_line_offset 1.000000
! ! These options control text and line fonts !
default_font font
aux_font 1 filled
aux_font 2 leroy
aux_font 3 cal_alf
aux_font 4 cal_grek
aux_font 5 font3d
! ! These options control leaders !
draw_arrow_length 3.500000
draw_arrow_style FILLED
dim_dot_box_style DEFAULT
draw_arrow_width 1.500000
draw_sym_height DEFAULT
draw_sym_width DEFAULT
draw_dot_diameter 1.000000
leader_elbow_length 6.000000
! ! These options control axes !
axis_interior_clipping NO
axis_line_offset 5.000000
circle_axis_offset 4.000000
radial_pattern_axis_circle YES
! ! These options control geometric tolerancing information !
gtol_datums STD_ISO_JIS
gtol_dim_placement ON_BOTTOM
new_iso_set_datums YES
asme_dtm_on_dia_dim_gtol ON_GTOL
! ! These options control tables, repeat regions, and BOM balloons !
dash_supp_dims_in_region YES
def_bom_balloon_leader_sym filled_dot
model_digits_in_region NO
show_cbl_term_in_region YES
! ! These options control layers !
draw_layer_overrides_model NO
ignore_model_layer_status YES
! ! These options control model grids !
model_grid_balloon_size 4.000000
model_grid_neg_prefix -
model_grid_num_dig_display 0
model_grid_offset DEFAULT
! ! These options control theoretical piping bend intersection !
show_pipe_theor_cl_pts BEND_CL
pipe_pt_shape CROSS pipe_pt_size DEFAULT
! ! Miscellaneous options !
decimal_marker COMMA_FOR_METRIC_DUAL
drawing_units MM
line_style_standard STD_ANSI
max_balloon_radius 0.000000
min_balloon_radius 0.000000
node_radius DEFAULT
sym_flip_rotated_text NO
weld_symbol_standard STD_ISO y
es_no_parameter_display TRUE_FALSE
default_pipe_bend_note NO
发表于 2002-11-19 16:35:34 | 只看该作者
供参考
发表于 2002-11-20 20:51:50 | 只看该作者
更详细
发表于 2002-11-20 20:52:24 | 只看该作者
发表于 2002-11-20 20:53:11 | 只看该作者
发表于 2002-11-20 20:53:58 | 只看该作者
发表于 2002-11-20 20:54:42 | 只看该作者
发表于 2002-11-20 20:55:19 | 只看该作者
发表于 2002-11-20 20:56:09 | 只看该作者
没了
发表于 2002-11-23 11:04:42 | 只看该作者
请问一下,标注用国家标注,怎么设定,在PROE里,邮件25lixiaoxiao@mail.china.com
GMT+8, 2025-4-24 16:16 , Processed in 0.082053 second(s), 11 queries , Gzip On, Redis On.
