1.你的力矩加错了
一个加到轮胎上
你加到地面上了
2.首先得提示是
WARNING: Model .jeep is no longer compatible with the ADAMS/Solver (C++).
.jeep.TIRE_1 is causing the incompatibility because:
1) Objects of type Tire are not compatible with the
ADAMS/Solver (C++).
2) The topology of the model has changed so .jeep.TIRE_1
is no longer connected in a way that is compatible with the
ADAMS/Solver (C++).
3) An attribute of .jeep.TIRE_1 is no longer compatible with
If you intend to use the ADAMS/Solver (C++), then be sure that you
set your preferences so ADAMS/Solver (C++) is the default as follows:
- From the Settings menu, point to Solver and select either
Solver Executable or Preferences, depending on the product
you are using.
- Press F1 in the dialog box that appears to learn more.
If you do not want to use the ADAMS/Solver (C++), you must change
your model to eliminate the incompatibilty. See the online help
for the object listed for more information.
2003可能有了重大变化
以前是可以的
3. The greatest error in an equation is 1.87514E+08 in the
equation for GFORCE jeep.TIRE_1.GFORCE_16912385 .
The greatest change in a variable is 1.5601 in the
variable for PART jeep.TIRE_3.PART_17171457 .
Try the following in this order:
1. Use the MAXIT argument on the EQUILIBRIUM, IC, KINEMATICS,
or INTEGRATOR command to increase the maximum number of
iterations.
2. Temporarily change the value of the PATTERN argument on the
EQUILIBRIUM, IC, KINEMATICS, or INTEGRATOR command to
 ATTERN = T.
3. Temporarily increase the value of the ERROR argument on the
EQUILIBRIUM, IC, KINEMATICS, or INTEGRATOR command at
time = 2.1663 .
4. If one or more forces change rapidly or sharply near
time = 2.1663, modify the force or forces.
ERROR: Simulation failure detected
林林总总的问题
我的也是
sigh |
