查看: 9269|回复: 35
[分享] 更改装配体特征树标准件图标——更新适用2014——2017
发表于 2017-7-5 23:40:51 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
更改装配体特征树标准件图标
功能:从装配体中选择一个或多个零件,将其图标更改成“标准件”图标,同样,也可以将图标还原。
操作间下图:
适用sw2013及以下——宏文件下载地址:
源代码如下:
  1. ' ------------------------------------------------------------------------------
  2. ' ChangeToolboxPartProperty
  3. ' ChangeToolboxPartProperty.swp -  by Lunkay, Copyright 2017/7/4
  4. ' Contact:  313618812@qq.com (Lunkay)
  5. ' 功能:
  6. '       选中零件,更改标准件图标属性。
  7. '
  8. ' 使用方法:
  9. ' 无
  10. 'BGU: 有时kill文件报错,无权限
  11. ' -------------------------------------------------------------------------------
  12. #If VBA7 Then
  13.     Private Declare PtrSafe Function GetKeyboardState Lib "user32" (pbKeyState As Byte) As Long
  14. #Else
  15.     Private Declare Function GetKeyboardState Lib "user32" (pbKeyState As Byte) As Long
  16. #End If
  17. Dim swDM As SwDMApplication
  18. Dim swDoc As SwDMDocument12
  19. Dim mOpenErrors As SwDmDocumentOpenError
  20. Dim swCfgMgr As SwDMConfigurationMgr
  21. Dim objClassfac As SwDMClassFactory
  22. Const SWDMLicenseKey = "LicenseKey"
  23. Dim swApp As SldWorks.SldWorks
  24. Dim swModel As SldWorks.ModelDoc2
  25. Dim swComp As SldWorks.Component2
  26. Dim swCompModel As SldWorks.ModelDoc2
  27. Dim ArrSelectedObjects() As Variant
  28. Dim sCompName As String
  29. Dim sMgr As SldWorks.SelectionMgr
  30. Dim sTyp As SwConst.swSelectType_e
  31. Dim iReply As String
  32. Dim swFrame As SldWorks.Frame    ' declare status bar object
  33. Dim nRetval As Long
  34. Dim bRet As Boolean
  35. Dim nErrors As Long
  36. Dim nWarnings As Long
  37. Dim mlngSWFileType As Long
  38. Dim ret As Integer
  39. Dim FilePath As String
  40. Dim ml As String
  41. Dim keys(0 To 255) As Byte
  42. Dim n As Long
  43. Dim CurSelCount As Long
  44. Dim swCompPartName As String
  45. Dim longstatus As Long, longwarnings As Long
  46. Public BZJ As Long
  47. Const MINSELECTIONS = 1
  48. Sub main()
  49.     FrmChangeToolboxPartProperty.Show
  50.     Set swApp = Application.SldWorks
  51.     Set swModel = swApp.ActiveDoc
  52.     If swModel Is Nothing Then
  53.         MsgBox "请先打开一个装配体文件!  ", vbCritical, "更改标准件标记 By Lunkay"
  54.         End
  55.     End If
  56.     If swModel.GetType = 2 Then    '如果模型是“装配体”
  57.         Set sMgr = swModel.SelectionManager
  58.
  59.         If sMgr.GetSelectedObjectCount < MINSELECTIONS Then
  60.
  61.             MsgBox "下面请在装配体中选择要改变标准件图标的零件!", vbCritical, "更改标准件标记 By Lunkay"
  62.
  63.         Else
  64.
  65.         End If
  66.
  67.         While sMgr.GetSelectedObjectCount < MINSELECTIONS
  68.
  69.             DoEvents
  70.             GetKeyboardState keys(0)
  71.             If keys(27) > 127 Then End
  72.         Wend
  73.
  74.         CurSelCount = sMgr.GetSelectedObjectCount
  75.
  76.         ReDim ArrSelectedObjects(1 To CurSelCount)
  77.         AtIndex = 1
  78.
  79.         For n = 1 To CurSelCount
  80.                 Set ArrSelectedObjects(n) = sMgr.GetSelectedObjectsComponent2(n)
  81.         Next n
  82.         For n = 1 To CurSelCount
  83.                 sMgr.DeSelect AtIndex
  84.         Next n
  85.         For n = 1 To CurSelCount
  86.              Set swComp = ArrSelectedObjects(n)
  87.             If swComp Is Nothing Then
  88.                 MsgBox "请先在装配体中选择要改变标准件图标的零件!", vbCritical, "更改标准件标记 By Lunkay"
  89.
  90.                 End
  91.             Else
  92.                 If swComp.GetSuppression = 1 Or swComp.GetSuppression = 4 Then    '零件压缩状态为轻化
  93.                     nRetval = swComp.SetSuppression2(2)    '将轻化还原
  94.                 End If
  95.                 sCompName = swComp.GetPathName
  96.
  97.                 Set swCompModel = swApp.ActivateDoc2(sCompName, True, nRetval)
  98.                 Set swCompModel = swApp.ActiveDoc
  99.                 swCompPartName = swCompModel.GetTitle
  100.                 If swCompModel.GetType <> 1 Then
  101.                     MsgBox "请先在装配体中选择要改变标准件图标的零件!", vbCritical, "更改标准件标记 By Lunkay"
  102.                     End
  103.                 End If
  104.                 longstatus = swCompModel.SaveAs3("C:\更改标准件标记.SLDPRT", 0, 1)
  105.                 Set swCompModel = Nothing
  106.                 swApp.CloseDoc "更改标准件标记.SLDPRT"
  107.                 Set swModel = swApp.ActiveDoc
  108.                 Set objClassfac = CreateObject("SwDocumentMgr.SwDMClassFactory")
  109.                 Set swDM = objClassfac.GetApplication(SWDMLicenseKey)    '启动SWDM
  110.                 Set swDoc = swDM.GetDocument(sCompName, 1, False, mOpenErrors)
  111.                 If BZJ = 1 Then    '变成标准件图标
  112.                     If swDoc.ToolboxPart <> swDmNotAToolboxPart Then
  113.                         MsgBox "所选零件是标准件!请选择一个非标准件!", vbCritical, "更改标准件标记 By Lunkay"
  114.
  115.                         swDoc.CloseDoc
  116.                         sMgr.DeSelect 1
  117.                         bRet = swComp.Select(True)
  118.                         bRet = swModel.ReplaceComponents(sCompName, "", True, True)
  119.
  120.                         Kill "C:\更改标准件标记.SLDPRT"
  121.
  122.                         End
  123.
  124.                     Else
  125.                         swDoc.ToolboxPart = swDmToolboxStandardPart
  126.                         swDoc.Save
  127.                         swDoc.CloseDoc
  128.                         'sMgr.DeSelect 1
  129.                         bRet = swComp.Select(True)
  130.                         bRet = swModel.ReplaceComponents(sCompName, "", True, True)
  131.                         Kill "C:\更改标准件标记.SLDPRT"
  132.                     End If
  133.                 ElseIf BZJ = 0 Then    '变成零件图标
  134.                     If swDoc.ToolboxPart = swDmNotAToolboxPart Then
  135.                         MsgBox "所选零件不是标准件!", vbCritical, "更改标准件标记 By Lunkay"
  136.                         swDoc.CloseDoc
  137.                         sMgr.DeSelect 1
  138.                         bRet = swComp.Select(True)
  139.                         bRet = swModel.ReplaceComponents(sCompName, "", True, True)
  140.                         Kill "C:\更改标准件标记.SLDPRT"
  141.                         End
  142.                     Else
  143.                         swDoc.ToolboxPart = swDmNotAToolboxPart
  144.                         swDoc.Save
  145.                         swDoc.CloseDoc
  146.                         sMgr.DeSelect 1
  147.                         bRet = swComp.Select(True)
  148.                         bRet = swModel.ReplaceComponents(sCompName, "", True, True)
  149.                         Kill "C:\更改标准件标记.SLDPRT"
  150.                     End If
  151.                 End If
  152.             End If
  153.         Next n
  154.         swModel.ClearSelection2 True
  155.     Else
  156.         MsgBox "请打开标装配体文件后再运行本程序!", vbCritical, "更改标准件标记 By Lunkay"
  157.     End If
  158. End Sub
复制代码
更新:适用于2014——2017
SW宏文件在此下载:
源代码如下:
  5. ' 功能:
  7. '
  8. ' 使用方法:
  9. ' 适用于SOLIDWORKS2014_2017
  12. #If VBA7 Then
  14. #Else
  16. #End If
  17. Dim swApp As Object
  18. Dim swModel As Object
  19. Dim swComp As Object
  20. Dim swCompModel As Object
  21. Dim ArrSelectedObjects() As Variant
  22. Dim sCompName As String
  23. Dim sMgr As Object
  24. Dim iReply As String
  25. Dim swFrame As Object    ' declare status bar object
  26. Dim nRetval As Long
  27. Dim bRet As Boolean
  28. Dim nErrors As Long
  29. Dim nWarnings As Long
  30. Dim mlngSWFileType As Long
  31. Dim ret As Integer
  32. Dim FilePath As String
  33. Dim ml As String
  34. Dim keys(0 To 255) As Byte
  35. Dim n As Long
  36. Dim CurSelCount As Long
  37. Dim AtIndex  As Long
  38. Dim swCompPartName As String
  39. Dim longstatus As Long, longwarnings As Long
  40. Public BZJ As Long
  41. Dim modelDocExt As Object
  42. Const MINSELECTIONS = 1
  43. Sub main()
  44.     FrmChangeToolboxPartProperty.Show
  45.     Set swApp = Application.SldWorks
  46.     Set swModel = swApp.ActiveDoc
  47.     If swModel Is Nothing Then
  48.         MsgBox "请先打开一个装配体文件!  ", vbCritical, "更改标准件标记 By Lunkay"
  49.         End
  50.     End If
  51.     If swModel.GetType = 2 Then    '如果模型是“装配体”
  52.         Set sMgr = swModel.SelectionManager
  53.
  54.         If sMgr.GetSelectedObjectCount < MINSELECTIONS Then
  55.
  56.             MsgBox "下面请在装配体中选择要改变标准件图标的零件!", vbCritical, "更改标准件标记 By Lunkay"
  57.
  58.         Else
  59.         End If
  60.         While sMgr.GetSelectedObjectCount < MINSELECTIONS
  61.
  62.             DoEvents
  63.             GetKeyboardState keys(0)
  64.             If keys(27) > 127 Then End
  65.         Wend
  66.         CurSelCount = sMgr.GetSelectedObjectCount
  67.
  68.         ReDim ArrSelectedObjects(1 To CurSelCount)
  69.         AtIndex = 1
  70.
  71.         For n = 1 To CurSelCount
  72.                 Set ArrSelectedObjects(n) = sMgr.GetSelectedObjectsComponent2(n)
  73.         Next n
  74.         For n = 1 To CurSelCount
  75.                 sMgr.DeSelect AtIndex
  76.         Next n
  77.         For n = 1 To CurSelCount
  78.              Set swComp = ArrSelectedObjects(n)
  79.             If swComp Is Nothing Then
  80.                 MsgBox "请先在装配体中选择要改变标准件图标的零件!", vbCritical, "更改标准件标记 By Lunkay"
  81.
  82.                 End
  83.             Else
  84.                 If swComp.GetSuppression = 1 Or swComp.GetSuppression = 4 Then    '零件压缩状态为轻化
  85.                     nRetval = swComp.SetSuppression2(2)    '将轻化还原
  86.                 End If
  87.                 sCompName = swComp.GetPathName
  88.
  89.                 Set swCompModel = swApp.ActivateDoc2(sCompName, True, nRetval)
  90.                 Set swCompModel = swApp.ActiveDoc
  91.                 swCompPartName = swCompModel.GetTitle
  92.                 If swCompModel.GetType <> 1 Then
  93.                     MsgBox "请先在装配体中选择要改变标准件图标的零件!", vbCritical, "更改标准件标记 By Lunkay"
  94.                     End
  95.                 End If
  96.                 Set modelDocExt = swCompModel.Extension
  97.                 If BZJ = 1 Then    '变成标准件图标
  98.                     If modelDocExt.ToolboxPartType <> 0 Then
  99.                         MsgBox "所选零件是标准件!请选择一个非标准件!", vbCritical, "更改标准件标记 By Lunkay"
  100.                         End
  101.
  102.                     Else
  103.                         modelDocExt.ToolboxPartType = 1
  104.                         swCompModel.Save
  105.                     End If
  106.                 ElseIf BZJ = 0 Then    '变成零件图标
  107.                     If modelDocExt.ToolboxPartType = 0 Then
  108.                         MsgBox "所选零件不是标准件!", vbCritical, "更改标准件标记 By Lunkay"
  109.                         End
  110.                     Else
  111.                         modelDocExt.ToolboxPartType = 0
  112.                         swCompModel.Save
  113.                     End If
  114.                 End If
  115.             End If
  116.         Next n
  117.         swModel.ClearSelection2 True
  118.     Else
  119.
  120.         MsgBox "请打开标装配体文件后再运行本程序!", vbCritical, "更改标准件标记 By Lunkay"
  121.     End If
  122. End Sub
复制代码
参与人数 1贡献 +5 收起 理由
gt.adan + 5 謝謝分享~
收藏收藏3 分享淘帖 赞一下!赞一下!
发表于 2017-7-5 23:47:52 | 只看该作者
怎么变脸的?
发表于 2017-7-5 23:56:19 | 只看该作者
更改文件的ToolboxPart属性
发表于 2017-7-6 03:26:46 | 只看该作者
发表于 2017-7-6 05:59:57 | 只看该作者
方便很多,谢谢分享。
发表于 2017-7-6 07:42:15 | 只看该作者
謝謝樓主的分享!
是否限定使用版本?
发表于 2017-7-6 08:16:48 | 只看该作者
好腻害的样子
发表于 2017-7-6 08:20:16 | 只看该作者
gt.adan 发表于 2017-7-6 07:42
謝謝樓主的分享!
是否限定使用版本?
所用函数,在高版本中任然有,没有被废弃。应该是都可以用的,但是使用了SWDM,不同sw,其SWDM license不同,所以没法通用,需要自行修改license。宏文件solidworks对象为前期绑定,不知道到其他soldiworks版本会不会引用丢失。有肯能需要修复。
发表于 2017-7-6 08:22:38 | 只看该作者
謝謝樓主的分享!
是否限定使用版本?
代码简陋,请版主予以完善修正。
发表于 2017-7-6 10:07:03 | 只看该作者
谢谢分享好方法,学习。
GMT+8, 2025-4-27 21:28 , Processed in 0.071134 second(s), 11 queries , Gzip On, Redis On.
