双11·3D打印优惠活动
查看: 8105|回复: 34
[分享] 宏-按顺序特征重命名
发表于 2018-6-8 09:18:35 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
以前搞过一个宏是英文名改中文的,有网友问能不能按顺序特征重命名.正好下载了一个,供大家分享.其中的语名值得学习
  1. 'PYCZT2018/5/26下载于https://www.codestack.net
  2. 'This macro renames all the features in active model in the order, preserving the base names.
  3. '该宏按顺序重命名活动模型中的所有特征名,保留原基本名称。
  4. 'Only indices are renamed and the base name is preserved. For example Sketch21 will be renamed to Sketch1 for
  5. 'the first appearance of the sketch feature.
  6. '只有索引被重命名,基本名称被保留。例如,对于草图特性的第一次出现,Sketch 21将被重命名为Sketch 1.
  7. 'Notes注意事项:
  8. '1.Only features with number at the end will be renamed (e.g. Front Plane will not be renamed to Front Plane1 and My1Feature will not be renamed)
  9. '只在结尾处有编号的特征将被重命名(例如,Front Plane不会被重命名为Front Plane1,以及My1Feature也不会被重命名)
  10. '2.Case is ignored (case insensitive search)
  11. '大小写是忽略的
  12. '3.Only modelling features are renamed (the ones created after the Origin feature)
  13. '只重命名建模用的特征名(在原点特征之后的)
  14. '*****************************************************************
  15. Dim swApp As SldWorks.SldWorks
  16. Dim swModel As SldWorks.ModelDoc2
  17. Sub main()
  18.     Set swApp = Application.SldWorks
  19.
  20.     Set swModel = swApp.ActiveDoc
  21.
  22.     Dim passedOrigin As Boolean
  23.     passedOrigin = False
  24.
  25.     If Not swModel Is Nothing Then
  26.
  27.         Dim featNamesTable As Object
  28.         Dim processedFeats As Collection
  29.
  30.         Set featNamesTable = CreateObject("Scripting.Dictionary")
  31.         Set processedFeats = New Collection
  32.
  33.         featNamesTable.CompareMode = vbTextCompare 'case insensitive
  34.
  35.         Dim swFeat As SldWorks.Feature
  36.         Set swFeat = swModel.FirstFeature
  37.
  38.         While Not swFeat Is Nothing
  39.
  40.             If passedOrigin Then
  41.
  42.                 If Not Contains(processedFeats, swFeat) Then
  43.                     processedFeats.Add swFeat
  44.                     RenameFeature swFeat, featNamesTable
  45.                 End If
  46.
  47.                 Dim swSubFeat As SldWorks.Feature
  48.                 Set swSubFeat = swFeat.GetFirstSubFeature
  49.
  50.                 While Not swSubFeat Is Nothing
  51.
  52.                     If Not Contains(processedFeats, swSubFeat) Then
  53.                         processedFeats.Add swSubFeat
  54.                         RenameFeature swSubFeat, featNamesTable
  55.                     End If
  56.
  57.                     Set swSubFeat = swSubFeat.GetNextSubFeature
  58.
  59.                 Wend
  60.
  61.             End If
  62.
  63.             If swFeat.GetTypeName2() = "OriginProfileFeature" Then
  64.                 passedOrigin = True
  65.             End If
  66.
  67.             Set swFeat = swFeat.GetNextFeature
  68.         Wend
  69.
  70.     Else
  71.         MsgBox "Please open model"
  72.     End If
  73. End Sub
  74. Sub RenameFeature(feat As SldWorks.Feature, featNamesTable As Object)
  75.     Dim regEx As Object
  76.     Set regEx = CreateObject("VBScript.RegExp")
  77.
  78.     regEx.Global = True
  79.     regEx.IgnoreCase = True
  80.     regEx.Pattern = "(.+?)(\d+)$"
  81.
  82.     Dim regExMatches As Object
  83.     Set regExMatches = regEx.Execute(feat.Name)
  84.
  85.     If regExMatches.Count = 1 Then
  86.
  87.         If regExMatches(0).SubMatches.Count = 2 Then
  88.
  89.             Dim baseFeatName As String
  90.             baseFeatName = regExMatches(0).SubMatches(0)
  91.
  92.             Dim nextIndex As Integer
  93.
  94.             If featNamesTable.Exists(baseFeatName) Then
  95.                 nextIndex = featNamesTable.item(baseFeatName) + 1
  96.                 featNamesTable.item(baseFeatName) = nextIndex
  97.             Else
  98.                 nextIndex = 1
  99.                 featNamesTable.Add baseFeatName, nextIndex
  100.             End If
  101.             feat.Name = baseFeatName & nextIndex
  102.         End If
  103.     End If
  104. End Sub
  105. Function Contains(coll As Collection, item As Object) As Boolean
  106.
  107.     Dim i As Integer
  108.
  109.     For i = 1 To coll.Count
  110.         If coll.item(i) Is item Then
  111.             Contains = True
  112.             Exit Function
  113.         End If
  114.     Next
  115.
  116.     Contains = False
  117.
  118. End Function
复制代码
参与人数 1贡献 +5 收起 理由
ryouss + 5 赞一个!
收藏收藏8 分享淘帖 赞一下!赞一下!
发表于 2018-6-8 10:39:48 | 只看该作者
謝謝分享,學習了!
发表于 2018-6-8 19:14:18 | 只看该作者
学习一下,谢谢楼主分享!
发表于 2018-6-9 08:07:08 | 只看该作者
是啥意思呢?看不懂,能说明下功能嘛?
发表于 2018-6-9 08:13:48 | 只看该作者
下载来试验了一下,运行该宏既不报错,也不改名,没任何反应。
发表于 2018-6-9 09:56:33 | 只看该作者
https://www.codestack.net/solidworks-api/document/features-manager/rename-features-sequentially这是来源网页
试验一下,对中文特征名是改名不理想.理想改名如下
发表于 2018-6-9 16:39:25 | 只看该作者
2012版測試正常,謝謝 pyczt大大.
发表于 2018-6-10 10:14:44 | 只看该作者
如圖所示,請教pyczt大大是用什麼樣的簡体字型,用簡繁轉譯有些字型還是沒轉成!
发表于 2018-6-11 06:32:03 | 只看该作者
感谢分享
发表于 2018-6-11 15:00:15 | 只看该作者
原宏有缺陷,修改过的应该OK了,增加注释,供大家一起学习
  1. 'PYCZT2018/5/26下载于https://www.codestack.net,2018/6/11修改
  6. '只有索引被重命名,基本名称被保留。例如,对于第一次出现的草图特性Sketch21将被重命名为Sketch1.
  7. 'Notes注意事项:
  9. '只在结尾处有编号的特征将被重命名(例如,Front Plane不会被重命名为Front Plane1,以及My1Feature也不会被重命名)---因为正则表达式为开始(任意字符)(任意数字)结束
  11. '大小写是忽略的
  17. Sub main()
  19.
  21.
  22.     Dim passedOrigin As Boolean    '定义一个过原点的逻辑变量
  24.
  26.
  28.         Dim processedFeats As Collection    ' 定义为记录集合类(Collection)。
  29.
  30.         Set featNamesTable = CreateObject("Scripting.Dictionary")   '变量为字典Dictionary对象
  32.
  33.         featNamesTable.CompareMode = vbTextCompare '比较模式为字符串(不分大小写)
  34.
  37.
  39.
  41.
  42.             Debug.Print swFeat.Name
  43.
  44.                 If Not Contains(processedFeats, swFeat) Then '比对特征记录集合与特征
  45.                     processedFeats.Add swFeat   '将特征增加到记录集合中
  46.                     RenameFeature swFeat, featNamesTable   '改名子程序
  47.                 End If
  48.
  49.                 Dim swSubFeat As SldWorks.Feature
  50.                 Set swSubFeat = swFeat.GetFirstSubFeature   '子特征
  51.
  52.                 While Not swSubFeat Is Nothing
  53.
  54.                     If Not Contains(processedFeats, swSubFeat) Then
  55.                         processedFeats.Add swSubFeat
  56.                         RenameFeature swSubFeat, featNamesTable
  57.                     End If
  58.
  59.                     Set swSubFeat = swSubFeat.GetNextSubFeature
  60.
  61.                 Wend
  62.
  63.             End If
  64.
  65.             If swFeat.GetTypeName2() = "OriginProfileFeature" Then
  66.                 OriginName = swFeat.Name   '预留原点特征名,以后使用
  67.                 passedOrigin = True
  68.             End If
  69.
  70.             Set swFeat = swFeat.GetNextFeature
  71.         Wend
  72.
  73.     '以下语名为已顺序的特征名去除后缀$
  74.     Set swFeat = swModel.FeatureByName(OriginName)
  75.     While Not swFeat Is Nothing
  76.     Set swFeat = swFeat.GetNextFeature
  77.     If Not swFeat Is Nothing Then
  78.     If Right(swFeat.Name, 1) = "$" Then swFeat.Name = Left(swFeat.Name, Len(swFeat.Name) - 1)   '去除后缀$
  79.     End If
  80.     Wend
  81.
  82.
  83.     Else
  84.         MsgBox "Please open model请打开模型文件"
  85.     End If
  86. End Sub
  87. Sub RenameFeature(feat As SldWorks.Feature, featNamesTable As Object)
  88.     Dim regEx As Object
  89.     Set regEx = CreateObject("VBScript.RegExp")   '创建正则表达式(RegEx)对象
  90.
  91.     regEx.Global = True       '设置全程匹配
  92.     regEx.IgnoreCase = True   '设置忽略区分大小写
  93.     regEx.Pattern = "(.+?)(\d+)$"    '设置正则表达式:开始(任意字符)(任意数字)结束
  94.
  95.     Dim regExMatches As Object
  96.     Set regExMatches = regEx.Execute(feat.Name)   '用于对指定正则表达式进行匹配检测,其值返回一个Matches集合,其中
  97.                                    '包含了所有检测到匹配的Match对象。如果没有检测到任何匹配则返回一个空的Matches集合
  98.
  99.     If regExMatches.Count = 1 Then
  100.
  101.     Debug.Print regExMatches(0)
  102.
  103.         If regExMatches(0).SubMatches.Count = 2 Then    'SubMatches数量为2,说明符合正则表达式
  104.         ' SubMatches 集合包含了单个的子匹配字符串,只能用 RegExp 对象的 Execute 方法创建。
  105.          'SubMatches 集合的属性是只读的。运行一个正则表达式时,当圆括号中捕捉到子表达式时可以有零个或多个子匹配。
  106.          'SubMatches 集合中的每一项是由正则表达式找到并捕获的的字符串。
  107.
  108.             Dim baseFeatName As String
  109.             baseFeatName = regExMatches(0).SubMatches(0)  '取正则表达式的第一个子匹配字符串,也就是基本特征名
  110.             'Debug.Print baseFeatName
  111.             Dim nextIndex As Integer
  112.
  113.             If featNamesTable.Exists(baseFeatName) Then    '如果指定的键(基本特征名)存在,返回True,否则返回False,
  114.                 nextIndex = featNamesTable.item(baseFeatName) + 1    'Items() 返回该键的条目数,增1
  115.                 featNamesTable.item(baseFeatName) = nextIndex   '将条目数赋值,即特征顺序号
  116.             Else
  117.                 nextIndex = 1
  118.                 featNamesTable.Add baseFeatName, nextIndex     '增加键到字典Dictionary,条目数为1
  119.             End If
  120.             feat.Name = baseFeatName & nextIndex & "$"    '原宏没有增加$后缀,可能造成改名失败
  121.             Debug.Print "已改名为:" & feat.Name
  122.         End If
  123.     End If
  124. End Sub
  125. Function Contains(coll As Collection, item As Object) As Boolean   '(比对processedFeats特征记录集合与swFeat是否相同,以免子特征改名重复)
  126.
  127.     Dim i As Integer
  128.     Debug.Print "特征记录集合数量为" & coll.Count  '记录集合数量
  129.     For i = 1 To coll.Count
  130.         Debug.Print "比对" & item.Name & "   " & i
  131.         Debug.Print
  132.         If coll.item(i) Is item Then '记录中特征相同
  133.             Contains = True
  134.             Exit Function
  135.         End If
  136.
  137.     Next
  138.
  139.     Contains = False
  140.
  141. End Function
复制代码
GMT+8, 2025-10-16 12:26 , Processed in 0.027343 second(s), 11 queries , Gzip On, Redis On.
