查看: 1770|回复: 0
[求助] 怎么获取零件的外形尺寸写入配置
发表于 2019-8-30 11:23:00 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
以下的是获取的装配体外形尺寸写入配置
但是我现在需要的是零件的
  1. Dim swApp                   As SldWorks.SldWorks
  2. Dim swModel                 As SldWorks.ModelDoc2
  3. Dim vBox                    As Variant
  4. Dim X_max                   As Double
  5. Dim X_min                   As Double
  6. Dim Y_max                   As Double
  7. Dim Y_min                   As Double
  8. Dim Z_max                   As Double
  9. Dim Z_min                   As Double
  10. Dim chang                   As Double
  11. Dim kuan                    As Double
  12. Dim gao                     As Double
  13. Sub main()
  14.     Set swApp = Application.SldWorks
  15.     Set swModel = swApp.ActiveDoc
  16.     vBox = swModel.GetBox()  '获取装配体的边界框swBoundingBoxIncludeRefPlanes
  17.
  18.     X_max = vBox(3)                                      '获取边界框6个点的坐标
  19.     X_min = vBox(0)
  20.     Y_max = vBox(4)
  21.     Y_min = vBox(1)
  22.     Z_max = vBox(5)
  23.     Z_min = vBox(2)
  24.
  25.     chang = X_max * 1000 - X_min * 1000            '获取长宽高
  26.     kuan = Y_max * 1000 - Y_min * 1000
  27.     gao = Z_max * 1000 - Z_min * 1000
  28.
  29.     blnretval = swModel.DeleteCustomInfo2("", "外形尺寸")  '把数据导入属性栏
  30.     blnretval = swModel.AddCustomInfo3("", "外形尺寸", swCustomInfoText, Format(chang, "0.0") & "*" & Format(kuan, "0.0") & "*" & Format(gao, "0.0"))
  31.
  32. End Sub
复制代码
GMT+8, 2025-7-8 15:30 , Processed in 0.022602 second(s), 10 queries , Gzip On, Redis On.
