查看: 17310|回复: 12
【求助】Customise PC for Running Alias & Maya
发表于 2002-10-24 14:16:36 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
To Dear All Alias Master
I would like to customize a new PC for running Alias & Maya, In my office
there are using Dell P4 , 512DDRAM , Oxygen GVX1 Pro graphic card. I think which is too expensive for me.
Dear all of Alias Master, do you have any subjection for the cheaper & stable hardware for running Alias & Maya.
Thank you very much
发表于 2002-10-26 00:50:29 | 只看该作者
there's no master here....
I think the most important component is display card (graphic card)
you need to buy some card better than GF2 GTS 64MB
ii think that's not very expensive...
cpu > P3 500 is OK
RAM >512
发表于 2002-10-26 01:02:07 | 只看该作者
Yes, I agree,
Display card's config is more important than CPU performance.
I am use GF3 64Mb.
发表于 2002-10-26 16:55:40 | 只看该作者
Thanks for yours prompt reply!!
   I saw somebody recommend the 耕升TI4200DT显卡 is good!  What is the 耕升 in english name?
   Is there enough for complicate rendering?
Below is my design, render by Alias 9.6,  please comment!!
发表于 2002-10-30 03:01:24 | 只看该作者
pretty good....
do some places use the cv controling to manipulate?
that's fine...but if you need more accurate controling...that wont be so exact...
耕宇 : Gainward
发表于 2002-11-1 15:14:07 | 只看该作者
I'm not understand what your mean (  cv controling to manipulate ) ,
The modeling was started with a sample Object_sphere and pulling the CV.
the shape guiding is export from Ai format.
发表于 2002-11-6 02:36:46 | 只看该作者
I MEAN IF YOU MOVE CV TO ACHIEVE THIS FORM, THAT WON'T BE VERY EXACTLY ACCURATE.
IF YOU DONT NEED ACCURACY AND NOT CONSIDER ABOUT FURTHER MANUFACTURE, THAT'S OK.....
发表于 2002-11-6 10:07:37 | 只看该作者
As you said that the CV can be controled in accurate, How? could you please let me know !
Actually, the product have produced in the US & eupro market ! sometime the free form  design I con't control in accurate - just depend
the design sence!
发表于 2002-11-8 02:27:06 | 只看该作者
CAN'T BE ACCURATE
BUT BEING APPROXIMATE IS POSSIBLE
发表于 2002-12-4 03:10:29 | 只看该作者
both design and alias is very good, I like it!
GMT+8, 2025-4-20 08:34 , Processed in 0.032500 second(s), 12 queries , Gzip On, Redis On.
