查看: 18126|回复: 6
【求助】CAA不能加载framework???
发表于 2004-8-11 11:07:37 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
打开范例文件后需要定义framework,但是指定CATIA目录后,出现如下错误,怎么解决啊?
发表于 2004-8-11 11:11:25 | 只看该作者
pic2
发表于 2004-8-11 11:12:42 | 只看该作者
pic3
提示如下错误:
# Error copying D:\Program Files\Dassault Systemes\B13\.\intel_a\code\bin\CATObjectSpecsModeler.pdb : No such file or directory
# Error copying D:\Program Files\Dassault Systemes\B13\.\intel_a\code\bin\CATOsmAutoSave.pdb : No such file or directory
# Error copying D:\Program Files\Dassault Systemes\B13\.\intel_a\code\bin\CATOsmAutomation.pdb : No such file or directory
# Error copying D:\Program Files\Dassault Systemes\B13\.\intel_a\code\bin\CATOsmDumpTool.pdb : No such file or directory
# Error copying D:\Program Files\Dassault Systemes\B13\.\intel_a\code\bin\CATOsmItf.pdb : No such file or directory
# Error copying D:\Program Files\Dassault Systemes\B13\.\intel_a\code\bin\CATVBTCatalogBuilder.pdb : No such file or directory
# Error copying D:\Program Files\Dassault Systemes\B13\.\intel_a\code\bin\CATVBTExpCatalogDump.pdb : No such file or directory
# Error copying D:\Program Files\Dassault Systemes\B13\.\intel_a\code\bin\CATVBTImportStartUp.pdb : No such file or directory
# Error copying D:\Program Files\Dassault Systemes\B13\.\intel_a\code\bin\CollabStream.pdb : No such file or directory
# Error copying D:\Program Files\Dassault Systemes\B13\.\intel_a\code\lib\AC0SPBSK.exp : No such file or directory
# Error copying D:\Program Files\Dassault Systemes\B13\.\intel_a\code\lib\AC0SPCAA.exp : No such file or directory
# Error copying D:\Program Files\Dassault Systemes\B13\.\intel_a\code\lib\AC0SPNewXML.exp : No such file or directory
# Error copying D:\Program Files\Dassault Systemes\B13\.\intel_a\code\lib\AC0SPTLNK.exp : No such file or directory
# Error copying D:\Program Files\Dassault Systemes\B13\.\intel_a\code\lib\AC0SPXML.exp : No such file or directory
# Error copying D:\Program Files\Dassault Systemes\B13\.\intel_a\code\lib\CATClnSpecs.exp : No such file or directory
# Error copying D:\Program Files\Dassault Systemes\B13\.\intel_a\code\lib\CATObjectSpecsModeler.exp : No such file or directory
# Error copying D:\Program Files\Dassault Systemes\B13\.\intel_a\code\lib\CATOsmAutoSave.exp : No such file or directory
# Error copying D:\Program Files\Dassault Systemes\B13\.\intel_a\code\lib\CATOsmAutomation.exp : No such file or directory
# Error copying D:\Program Files\Dassault Systemes\B13\.\intel_a\code\lib\CATOsmDumpTool.exp : No such file or directory
# Error copying D:\Program Files\Dassault Systemes\B13\.\intel_a\code\lib\CATOsmItf.exp : No such file or directory
# Error copying D:\Program Files\Dassault Systemes\B13\.\intel_a\code\lib\CollabStream.exp : No such file or directory
# mkmk-INFO: C:\Documents and Settings\gaoxb\×[$Agrave][$Atilde][$aelig]\erbing\ObjectSpecsModeler -> End of update.
# Error copying D:\Program Files\Dassault Systemes\B13\.\intel_a\code\bin\BBHTTPTunneler.pdb : No such file or directory
# Error copying D:\Program Files\Dassault Systemes\B13\.\intel_a\code\bin\CATBBMagic.pdb : No such file or directory
# Error copying D:\Program Files\Dassault Systemes\B13\.\intel_a\code\bin\CATLMjni.pdb : No such file or directory
# Error copying D:\Program Files\Dassault Systemes\B13\.\intel_a\code\bin\CATLic.pdb : No such file or directory
# Error copying D:\Program Files\Dassault Systemes\B13\.\intel_a\code\bin\CATScriptEngine.pdb : No such file or directory
# Error copying D:\Program Files\Dassault Systemes\B13\.\intel_a\code\bin\CATScriptParser.pdb : No such file or directory
# Error copying D:\Program Files\Dassault Systemes\B13\.\intel_a\code\bin\CATSysAllocator.pdb : No such file or directory
# Error copying D:\Program Files\Dassault Systemes\B13\.\intel_a\code\bin\CATSysAsk.pdb : No such file or directory
# Error copying D:\Program Files\Dassault Systemes\B13\.\intel_a\code\bin\CATSysCacheTime.pdb : No such file or directory
# Error copying D:\Program Files\Dassault Systemes\B13\.\intel_a\code\bin\CATSysCommunication.pdb : No such file or directory
# Error copying D:\Program Files\Dassault Systemes\B13\.\intel_a\code\bin\CATSysCompFile.pdb : No such file or directory
# Error copying D:\Program Files\Dassault Systemes\B13\.\intel_a\code\bin\CATSysDLExport.pdb : No such file or directory
发表于 2004-8-11 16:25:52 | 只看该作者
或者还有这个错误,
是不是环境设置的问题, 在安装catia和caa的时候我把环境设置目录CATEnv指定在同一个地方了
发表于 2004-8-11 17:14:10 | 只看该作者
打开一个范例文件时候,出现的信息如下:
Running mkmk profile...
* NTsetenv Version 3.3.0 *
* mkmk Version 2.13.1 *
* Windows 2000 5.0 *
Using default 32-bit mode (intel_a)
Microsoft Visual Studio 6.0 detected.
WARNING : Microsoft Visual C# (CSharp) and J# (JSharp) compilers not detected in registry.
Microsoft Visual C++ 6.0 detected.
WARNING : Intel C/C++ Compiler 4.5 not detected in registry.
WARNING : Fortran compiler 5.0 not detected in registry.
WARNING : MKS tools kit not detected in registry.
WARNING : IBM Developer Kit, Java(TM) Tech. Edition not detected in registry. Using default (C:\jdk1.1.8).
WARNING : IBM Java Development Kit 1.3 not detected in registry.
WARNING : IBM Java Runtime Environment 1.3 not detected in registry.
mkCheckSource environment set.
SCM Variables:
ADL_LEVEL=
ADL_DIFF_LOCAL=
ADL_DIFF_LOCAL_PATH=
ADL_PATH=d:\Program Files\Dassault Systemes\T13\intel_a
User log cleaner started
User log cleaner ended
发表于 2004-8-11 18:39:35 | 只看该作者
# mkmk-INFO: C:\Documents and Settings\gaoxb\×[$#192][$#195][$#230]\erbing\ObjectSpecsModeler -> End of update.
别用中文
5楼没事,
发表于 2004-8-12 10:07:43 | 只看该作者
万分感谢指点,已经成功了。范例文件CAASysCharStrings.exe已经能运行了
GMT+8, 2025-4-18 15:15 , Processed in 0.028882 second(s), 11 queries , Gzip On, Redis On.
