查看: 15399|回复: 1
【推荐】PROE2001中打开野火版本
发表于 2004-8-25 16:26:53 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
今天在PTC官方网站溜达时发现一个关于在2001中打开野火版本的简单介绍,把它贴在这里,希望有些帮助,我试过能打开,但只是一种输入特征的方法,不能显示其建模过程
发表于 2004-8-25 16:29:57 | 只看该作者
Using the Associative Topology Bus to achieve cross-release interoperability between Pro/ENGINEER Wildfire and Pro/ENGINEER 2001
Figure 1
Figure 2
Figure 3
Figure 4
Figure 5
Figure 6
Figure 7
Figure 8
    In this tip, you will learn how to transfer data from Pro/ENGINEER Wildfire to Pro/ENGINEER 2001 using the Neutral file export and import format and the Associative Topology Bus (ATB).  You will maintain an associative link for any future changes made to parts created in Pro/ENGINEER Wildfire.  This process helps in situations where a design is created in Pro/ENGINEER Wildfire, but a partner performing manufacturing or analysis is using Pro/ENGINEER 2001.
The following steps outline this process:
·          Add TOPOBUS_ENABLE YES to your config.pro file.
·          Within an active Pro/ENGINEER Wildfire session, open a part and select File < Save a Copy and select Neutral file under Type (see Figure 1).
·          Select OK to export the data as a Neutral file (see Figure 2).
·          Select a Coordinate System or accept the Default (see Figure 3) to complete the export process.
·          Within an active Pro/ENGINEER 2001 session, select File < Open and set Type to Neutral (see Figure 4).
·          Highlight the file on the list and select Open.
·          From the Import New Model dialog box, select Part or Assembly and select OK to complete the import (see Figure 5).
Now return to Pro/ENGINEER Wildfire.
·          Open the original part, make a change, and save the part.
·          Select File < Save a Copy and select Neutral File under Type (see Figure 6).  Use the same name as the first neutral file that was exported.
Now return to Pro/ENGINEER 2001.
·          With the imported part active in session, select File < Associative Topology Bus and Check Status (see Figure 7).
·          The Information Window will provide data informing you if changes have been made to the model in Pro/ENGINEER Wildfire (i.e. changes to the neutral file) (see Figure 8).
·          Select File < Associative Topology Bus and Update All (see Figure 7).
Was this tip helpful?  Let us know.
[PRINTER FRIENDLY VERSION]
   &nbspTC Express Home
The Oops Factor Series - The Story of Sinclair C5
Making Your Design Tools Disappear
Mowing Down the Competition
contact PTC | privacy policy | subscribe  | edit profile | PTC Express archive
GMT+8, 2025-4-13 06:42 , Processed in 0.024880 second(s), 13 queries , Gzip On, Redis On.
