查看: 19233|回复: 1
请问caa中在空间创建点,直线,面以及圆弧的方法
发表于 2004-9-1 20:41:46 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
各位大虾,请问caa中在空间创建点,直线,面以及圆弧的方法,最好是generative shape design中建点,线,面的方法的API
发表于 2004-9-3 08:12:17 | 只看该作者
Object Explorer  Object Hierarchy  Previous  Next  Indexes
HybridShapeFactory (Object)
IUnknown
  +---IDispatch
    +---CATBaseUnknown
      +---CATBaseDispatch
        +---AnyObject
          +---Factory
            +---HybridShapeFactory
Creates all kinds of HybridShape objects that may be needed in wireframe and surface design.
Method Index
AddNewSpine
Creates a new spine within the current body.
AddNewAxisLine
Creates a new AxisLine within the current body.
AddNewLawDistProj
Creates a new law within the current body.
AddNewBlend
Creates a new blend surface within the current body.
AddNewConic
Creates a new conic within the current body.
AddNewHelix
Creates a new Helix within the current body.
AddNewCombine
Creates a new Combine within the current body.
AddNewExtremum
Creates a new Extremum within the current body.
AddNewExtremumPolar
Creates a new Extremum Polar within the current body.
AddNewCircle2PointsRad
Creates a new Circle passing through 2 points with a radius within the current body.
AddNewFillet
AddNewFilletBiTangent
Creates a new a sphere bitangent fillet between two skins.
AddNewFilletTriTangent
Creates a new a tritangent fillet between three skins.
AddNewCircle3Points
Creates a new circle passing through 3 points within the current body.
AddNewCircleBitangentPoint
Creates a new circle tangent to 2 curves and passing through one point within the current body.
AddNewCircleBitangentRadius
Creates a new circle tangent to 2 curves and with a radius within the current body.
AddNewCircleCtrPtWithAngles
Creates a new circle defined by its center, a passing point and angles within the current body.
AddNewCircleCtrPt
Creates a new whole circle defined by its center, a passing point within the current body.
AddNewCircleCtrRadWithAngles
Creates a new circle defined by its center, a radius and angles within the current body.
AddNewCircleCtrRad
Creates a new whole circle defined by its center and a radius within the current body.
AddNewCircleTritangent
Creates a new tritangent circle within the current body.
AddNewDevelop
Creates a new Develop within the current body.
AddNewUnfold
Creates a new Unfold within the current body.
AddNewSweepCircle
Creates a new SweepCircle within the current body.
AddNewSweepExplicit
Creates a new SweepExplicit within the current body.
AddNewSweepLine
Creates a new SweepLine within the current body.
AddNewPositionTransfo
Creates a new PositionTransfo within the current body.
AddNewLoft
Creates a new Loft within the current body.
AddNewJoin
Creates a new Join within the current body.
AddNewExtract
Creates a new Extract within the current body.
AddNewInverse
Creates a new Inverse within the current body.
AddNewNear
Creates a new Near within the current body.
AddNewConnect
Creates a new Connect within the current body.
AddNewCurvePar
Creates a new CurvePar within the current body.
AddNewCurveSmooth
Creates a new CurveSmooth within the current body.
AddNewTranslate
Creates a new Translate within the current body.
AddNewEmptyTranslate
Creates a new empty Translate within the current body.
AddNewAffinity
Creates a new Affinity within the current body.
AddNewHybridSplit
Creates a new Split within the current body.
AddNewHybridTrim
Creates a new Trim within the current body by cutting and joining two elements.
AddNewProject
Creates a new Project within the current body.
AddNewCorner
Creates a new Corner within the current body.
AddNew3DCorner
Creates a new 3D Corner within the current body.
AddNewExtrapolUntil
Creates a new Extrapol (until an element) within the current body.
AddNewExtrapolLength
Creates a new Extrapol (specified by length) within the current body.
AddNewRotate
Creates a new Rotate within the current body.
AddNewIntersection
Creates a new Intersection within the current body.
AddNewSymmetry
Creates a new Symmetry within the current body.
AddNewAxisToAxis
Creates a new axis to axis transformation within the current body.
AddNewPointDatum
Creates a new datum of point within the current body.
AddNewLineDatum
Creates a new datum of line within the current body.
AddNewPlaneDatum
Creates a new datum of plane within the current body.
AddNewCurveDatum
Creates a new datum of curve within the current body.
AddNewCircleDatum
Creates a new datum of circle within the current body.
AddNewSurfaceDatum
Creates a new datum of surface within the current body.
DeleteObjectForDatum
Role: to delete an object within the current body.
AddNewFill
Creates a new Fill within the current body.
AddNewFillEdgeWithSurface
Creates a new FillEdgeWithSurface within the current body.
AddNewFillEdge
Creates a new FillEdge within the current body.
AddNewFillEdges
Creates a new FillEdges within the current body.
AddNewEmptyFillEdges
Creates a new EmptyFillEdges within the current body.
AddNewSpline
Creates a new Spline within the current body.
AddNewSpiral
Creates a new Spiral within the current body.
AddNewBoundary
Creates a new Boundary within the current body.
AddNewBoundaryOfSurface
Creates a Boundary within the current body.
AddNewPointCoord
Creates a new point defined by its cartesian coordinates within the current body.
AddNewPointCoordWithReference
Creates a new point defined its the cartesian coordinates regarding a reference point.
AddNewPointBetween
Creates a new PointBetween within the current body.
AddNewPointOnCurveWithReferenceFromDistance
Creates a new point on a curve with a reference point and from a distance within the current body.
AddNewPointOnCurveFromDistance
Creates a new point on a curve from a distance to an extremity within the current body.
AddNewPointOnCurveWithReferenceFromPercent
Creates a new point on a curve with a reference point and from a ratio of distance within the current body.
AddNewPointOnCurveFromPercent
Creates a new point on a curve from a ratio of distance to an extremity within the current body.
AddNewPointOnPlaneWithReference
Creates a new point on a plane with a reference point within the current body.
AddNewPointOnPlane
Creates a new point on a plane within the current body.
AddNewPointOnSurfaceWithReference
Creates a new point on a surface with a reference point within the current body.
Creates a new point on a surface within the current body.
AddNewPointCenter
Creates a new circle center point within the current body.
AddNewPointTangent
Creates a new tangent to curve point within the current body.
AddNewLinePtPt
Creates a new point-point line within the current body.
AddNewLinePtPtOnSupport
Creates a new point-point line with support within the current body.
AddNewLinePtPtExtended
Creates a new point-point line with extensions within the current body.
AddNewLinePtPtOnSupportExtended
Creates a new point-point line with extensions and with support within the current body.
AddNewLinePtDir
Creates a new point-direction line within the current body.
AddNewLinePtDirOnSupport
AddNewLineAngle
Creates a new angle line within the current body.
AddNewLineTangency
Creates a new tangent line within the current body.
AddNewLineBiTangent
Creates a new bitangent line within the current body.
AddNewLineTangencyOnSupport
AddNewLineNormal
Creates a new normal line within the current body.
AddNewLineBisecting
Creates a new bisecting line within the current body.
AddNewLineBisectingOnSupport
Creates a new bisecting line on a support within the current body.
AddNewLineBisectingWithPoint
Creates a new bisecting line with a starting point within the current body.
AddNewLineBisectingOnSupportWithPoint
Creates a new bisecting line on a support with a atarting point within the current body.
AddNewPlaneEquation
Creates a new equation plane within the current body.
AddNewPlane3Points
Creates a new plane passing through 3 points within the current body.
AddNewPlane2Lines
Creates a new plane passing through 2 lines within the current body.
AddNewPlane1Line1Pt
Creates a new plane passing through 1 line and 1 point within the current body.
AddNewPlane1Curve
Creates a new plane passing through one planar curve within the current body.
AddNewPlaneTangent
Creates a new tangent plane within the current body.
AddNewPlaneNormal
Creates a new normal plane within the current body.
AddNewPlaneOffset
Creates a new offset plane within the current body.
AddNewPlaneOffsetPt
Creates a new offset trough point plane within the current body.
AddNewPlaneAngle
Creates a new angle plane within the current body.
AddNewPlaneMean
Creates a new mean through points plane within the current body.
AddNewExtrude
Creates a new extrude within the current body.
AddNewCylinder
Creates a new Cylinder within the current body.
AddNewRevol
Creates a new revolution within the current body.
AddNewDirection
Creates a new direction specified by an element within the current body.
AddNewDirectionByCoord
Creates a new Direction specifed by coordinates within the current body.
AddNewOffset
Creates a new offset within the current body.
AddNewHybridScaling
Creates a new scaling within the current body.
AddNewHealing
Creates a new healing within the current body.
AddNewReflectLine
Creates a new ReflectLine within the current body.
AddNewReflectLineWithType
AddNewSphere
Creates a new Sphere within the current body.
AddNewBump
Creates a new Bump within the current body.
AddNewWrapCurve
Creates a new Wrap Curve Surface within the current body.
AddNewWrapSurface
Creates a new Wrap Surface within the current body.
AddNewThickness
Creates a new thickness within the current body.
AddNewPolyline
Creates a new Polyline within the current body.
AddNewSweepConic
Creates a new SweepConic within the current body.
AddNewCircleCenterTangent
Creates a new circle with given center element and tangent curve.
AddNewVariableOffset
AddNew3DCurveOffset
Creates a 3D Curve Offset.
Methods
o Func AddNewSpine( ) As HybridShapeSpine
Parameters:
oExt
CATIAHybridShapeSpine created
o Func AddNewAxisLine( Reference  iElement) As HybridShapeAxisLine
Parameters:
iElement
Circle, Ellipse, Oblong, Sphere, Revolution surface. Axis is computed for this element
oAxisLine
Created axis line
o Func AddNewLawDistProj( Reference  iReference,
  Reference  iDefinition) As HybridShapeLawDistProj
Parameters:
iReference
Reference line of the law.
Sub-element(s) supported (see Boundary object): see CATIARectlinearTriDimFeatEdge and RectilinearBiDimFeatEdge.
iDefinition
Definition curve of the law.
Sub-element(s) supported (see Boundary object): see TriDimFeatEdge and BiDimFeatEdge.
oLaw
The Law object if succeded
o Func AddNewBlend( ) As HybridShapeBlend
Parameters:
oBlend
The Blend object if succeded
o Func AddNewConic( Reference  iSupport,
  Reference  iStartingPoint,
  Reference  iEndPoint) As HybridShapeConic
Parameters:
iSupport
The conic support (always a plane).
Sub-element(s) supported (see Boundary object): see PlanarFace.
iStartingPoint
Starting Point.
Sub-element(s) supported (see Boundary object): see Vertex.
iEndPoint
End Point
oConic
The Conic object if succeded
o Func AddNewHelix( Reference  iAxis,
  boolean  iInvertAxis,
  double  iPitch,
  double  iHeight,
  boolean  iClockwiseRevolution,
  double  iStartingAngle,
  double  iTaperAngle,
  boolean  iTaperOutward) As HybridShapeHelix
Parameters:
iAxis
The helix axis (always a line).
iInvertAxis
iStartingPoint
Starting Point.
iPitch
Pitch.
iHeight
Helix height.
Revolutions are clockwise if TRUE, counterclockwise if FALSE.
iStartingAngle
Starting angle from starting point measured on the helix itself. If no starting angle is wanted, set it to 0.0.
iTaperAngle
0 <= Taper Angle < Pi/2 If no taper angle is wanted, set it to 0.0 (constant helix radius).
iTaperOutward
Helix radius increases if TRUE, decreases if FALSE.
oHelix
The Helix object if succeded
o Func AddNewCombine( Reference  iFirstCurve,
  Reference  iSecondCurve,
  long  iNearestSolutions) As HybridShapeCombine
Creates a new Combine within the current body. By default, the combine direction is the normal of each curve. If you want to change see CATIAHybridShapeCombine interfaces.
Parameters:
iFirstCurve
First curve to combine
iSecondCurve
Second curve to combine
iNearestSolution
If more than one solution, to choose the nearest solution of the first curve
oCombine
The combine object if succeded
o Func AddNewExtremum( Reference  iObjet,
  HybridShapeDirection  iDir,
  long  iMinMax) As HybridShapeExtremum
Parameters:
iObjet
Element onto extremum is computed
Sub-element(s) supported (see Boundary object): see TriDimFeatEdge, BiDimFeatEdge and Face.
iDir
Extremum direction
iMinMax
Maximum (GSMMax) or Minimum (GSMMin)
oExt
The extremum object if succeded
o Func AddNewExtremumPolar( short  iType,
  Reference  ipIAContour) As HybridShapeExtremumPolar
Parameters:
iType
Type of extremum polar 0-Min Radius 1-Max Radius 2- Min Angle 3- Maximum Angle
ipIAContour
Extremum Polar Contour. It should be non convex
opIAExtPolar
The extremum polar object if succeded
o Func AddNewCircle2PointsRad( Reference  iPoint1,
  Reference  iPoint2,
  Reference  iSupport,
  boolean  iGeodesic,
  double  iRadius,
  long  iOri) As HybridShapeCircle2PointsRad
Parameters:
iPoint1
first passing point.
iPoint2
second passing point.
iSupport
support surface.
Sub-element(s) supported (see Boundary object): see Face.
iGeodesic
Puts the circle on the surface.
iRadius
radius
iOri
circle orientation. Defines the side where circle is computed using the normal direction of line between the 2 passing points.
oCircle
The Circle object if succeded
o Func AddNewFillet( Reference  iElement1,
  Reference  iElement2,
  double  iRadius,
  long  iOrientation1,
  long  iOrientation2,
  long  iSupportsTrimMode,
  long  iRibbonRelimitationMode) As HybridShapeFillet
Deprecated:
V5R11 Use AddNewFilletBiTangent Creates a new a sphere bitangent fillet between two skins.
Parameters:
iElement1
First support of fillet.
iElement2
Second support of fillet.
iRadius
Radius of the fillet.
iOrientation1
Manage the fillet center position.
iOrientation2
iSupportsTrimMode
The 2 supports can be trimmed and assembled with the fillet. Value can be 0 (No trim ) or 1 (Trim)
Manage the relimition of fillet extremities. Value can be : 0 (Smooth), 1 (Straight), 2 (Maximum) or 3 (Minimum)
oFillet
Created fillet.
o Func AddNewFilletBiTangent( Reference  iElement1,
  double  iRadius,
  long  iOrientation1,
  long  iOrientation2,
  long  iRibbonRelimitationMode) As HybridShapeFilletBiTangent
Parameters:
iElement1
iElement2
iRadius
iOrientation1
iOrientation2
iSupportsTrimMode
oFillet
Created fillet.
o Func AddNewFilletTriTangent( Reference  iElement1,
  Reference  iRemoveElem,
  long  iOrientation1,
  long  iOrientation2,
  long  iRemoveOrientation,
  long  iRibbonRelimitationMode) As HybridShapeFilletTriTangent
Parameters:
iElement1
iElement2
iRemoveElem
Support to remove of fillet.
iOrientation1
iOrientation2
iRemoveOrientation
iSupportsTrimMode
oFillet
Created fillet.
o Func AddNewCircle3Points( Reference  iPoint1,
  Reference  iPoint2,
  Reference  iPoint3) As HybridShapeCircle3Points
Parameters:
iPoint1
iPoint2
iPoint3
third passing point.
oCircle
Created circle
o Func AddNewCircleBitangentPoint( Reference  iCurve1,
  Reference  iCurve2,
  Reference  iPoint,
  Reference  iSupport,
  long  iOri1,
  long  iOri2) As HybridShapeCircleBitangentPoint
Parameters:
iCurve1
first curve to which the circle will be tangent.
iCurve2
second curve to which the circle will be tangent.
iPoint
passing point. This point must lie on second curve.
iSupport
support surface.
iOri1
first curve orientation for circle computation.
iOri2
second curve orientation for circle computation.
oCircle
Created circle
o Func AddNewCircleBitangentRadius( Reference  iCurve1,
  Reference  iCurve2,
  Reference  iSupport,
  double  iRadius,
  long  iOri1,
  long  iOri2) As HybridShapeCircleBitangentRadius
Parameters:
iCurve1
iCurve2
iSupport
support surface.
iRadius
circle radius
iOri1
iOri2
oCircle
Created circle
o Func AddNewCircleCtrPtWithAngles( Reference  iCenter,
  Reference  iCrossingPoint,
  Reference  iSupport,
  boolean  iGeodesic,
  double  iStartAngle,
  double  iEndAngle) As HybridShapeCircleCtrPt
Parameters:
iCenter
circle center.
iCrossingPoint
passing point.
iSupport
support surface.
iGeodesic
iStartAngle
start angle
iEndAngle
end angle
oCircle
Created circle
o Func AddNewCircleCtrPt( Reference  iCenter,
  Reference  iSupport,
  boolean  iGeodesic) As HybridShapeCircleCtrPt
Parameters:
iCenter
circle center.
iCrossingPoint
passing point.
iSupport
support surface.
iGeodesic
oCircle
CreatedCircle
o Func AddNewCircleCtrRadWithAngles( Reference  iCenter,
  Reference  iSupport,
  boolean  iGeodesic,
  double  iRadius,
  double  iStartAngle,
  double  iEndAngle) As HybridShapeCircleCtrRad
Parameters:
iCenter
circle center.
iSupport
support surface.
iGeodesic
iRadius
circle radius
iStartAngle
start angle
iEndAngle
end angle
oCircle
Created circle
o Func AddNewCircleCtrRad( Reference  iCenter,
  Reference  iSupport,
  boolean  iGeodesic,
  double  iRadius) As HybridShapeCircleCtrRad
Parameters:
iCenter
circle center.
iSupport
support surface.
iGeodesic
iRadius
radius
oCircle
Created circle
o Func AddNewCircleTritangent( Reference  iCurve1,
  Reference  iCurve2,
  Reference  iCurve3,
  Reference  iSupport,
  long  iOri1,
  long  iOri2,
  long  iOri3) As HybridShapeCircleTritangent
Parameters:
iCurve1
iCurve2
iCurve3
third curve to which the circle will be tangent.
iSupport
support surface.
iOri1
iOri2
iOri3
third curve orientation for circle computation.
oCircle
Created circle
o Func AddNewDevelop( long  iMode,
  Reference  iToDevelop,
  Reference  iSupport) As HybridShapeDevelop
Parameters:
iMode
Develop method.
iToDevelop
Wire to be developed.
iSupport
Revolution support surface.
oExt
Created developed wire.
o Func AddNewUnfold( ) As HybridShapeUnfold
Parameters:
oExt
Created unfold operation.
o Func AddNewSweepCircle( Reference  iGuide1) As HybridShapeSweepCircle
Parameters:
iGuide1
First guide or center curve.
oExt
Created swept surface.
o Func AddNewSweepExplicit( Reference  iProfile,
  Reference  iGuide) As HybridShapeSweepExplicit
Parameters:
iProfile
Profile.
iGuide
First guide curve.
oExt
o Func AddNewSweepLine( Reference  iGuide1) As HybridShapeSweepLine
Parameters:
iGuide1
First guide curve.
oExt
o Func AddNewPositionTransfo( long  iMode) As HybridShapePositionTransfo
Parameters:
iMode
Positioning mode.
oExt
Created positioning transformation (i.e. positioned wire / profile).
o Func AddNewLoft( ) As HybridShapeLoft
Parameters:
oExt
CATIAHybridShapeLoft created
o Func AddNewJoin( Reference  Element1,
  Reference  Element2) As HybridShapeAssemble
Parameters:
iElement1
First element to join ( curve or surface.
Sub-element(s) supported (see Boundary object): see Face, TriDimFeatEdge and BiDimFeatEdge.
iElement2
Second element to join ( same type of the first element)
oExt
Join result The default value used to join element is 0.001mm
o Func AddNewExtract( Reference  Element) As HybridShapeExtract
Parameters:
iElement
Initial element used to start the extraction
Sub-element(s) supported (see Boundary object): see Boundary.
oExt
The extracted object
o Func AddNewInverse( Reference  Element,
  long  Inverse) As HybridShapeInverse
Parameters:
iElement
The objet to inverse
iInverse
the type of inversion (see CATGSMOrientation.h) 1 for no inversion -1 for inversion
oInv
The inverted object
o Func AddNewNear( Reference  MultiElement,
  Reference  ReferenceElement) As HybridShapeNear
Parameters:
iMultiElement
Non connex element (point,curve,surface.
Sub-element(s) supported (see Boundary object): see Face, TriDimFeatEdge, BiDimFeatEdge and Vertex.
iReferenceElement
Reference element
oNear
The result is the connex component that is the nearest from the reference element
o Func AddNewConnect( Reference  iCurve1,
  Reference  iPoint1,
  long  iOrient1,
  long  iContinuity1,
  double  iTension1,
  Reference  iCurve2,
  Reference  iPoint2,
  long  iOrient2,
  long  iContinuity2,
  double  iTension2,
  boolean  Trim) As HybridShapeConnect
Parameters:
iCurve1
First curve.
iPoint1
First point (lying on the first curve)
iOrient1
Orientation on the first curve
iContinuity1
Continuity on first curve
iTension1
Tension on first curve
iCurve2
Second curve.
iPoint2
Second point (lying on the second curve)
iOrient2
Orientation on the second curve
iContinuity2
Continuity on second curve
iTension2
Tension on second curve
iTrim
Trim the two curves with the connect
oConnect
The connect object
o Func AddNewCurvePar( Reference  Curve,
  Reference  Support,
  double  Distance,
  boolean  InvertDirection,
  boolean  Geodesic) As HybridShapeCurvePar
Parameters:
iCurve
Reference curve.
iSupport
Support on which the curve is lying on
iDistance
Distance value
iInvertDirection
Orientation
iGeodesic
Geodesic mode
oCurvePar
Parallel curve
o Func AddNewCurveSmooth( Reference  ipIACurve) As HybridShapeCurveSmooth
Parameters:
iCurve
Reference curve to be smoothened
oCurveSmooth
Smoothened curve
o Func AddNewTranslate( Reference  iElement,
  HybridShapeDirection  iDirection,
  double  iDistance) As HybridShapeTranslate
Parameters:
iElement
Point, curve, surface or solid to translate.
iDirection
Translation direction.
iDistance
Translation Distance.
oTranslate
Created translation
oTranslate
Created Translate (Empty feature)
Note: Then translate mode and inputs has to be initialized
See also:
o Func AddNewEmptyTranslate( ) As HybridShapeTranslate
o Func AddNewAffinity( Reference  iElement,
  double  iXRatio,
  double  iYRatio,
  double  iZRatio) As HybridShapeAffinity
Parameters:
iElement
point, curve, surface or solid.
iXRatio
Ratio of affinity in iX direction.
iYRatio
Ratio of affinity in iY direction.
iZRatio
Ratio of affinity in iZ direction.
oAffinity
Created affinity
o Func AddNewHybridSplit( Reference  iElement1,
  long  iOrientation) As HybridShapeSplit
Parameters:
iElement1
The feature to cut (curve or surface).
iElement2
The cutting feature (point, curve, surface).
iOrientation
Manage the kept side of the feature to cut (value can be 1 or -1)
oSplit
Created split
o Func AddNewHybridTrim( Reference  iElement1,
  long  iOrientation1,
  long  iOrientation2) As HybridShapeTrim
You can trim a surface by a surface or a curve by a curve.
Parameters:
iElement1
The feature to trim (curve or surface).
iOrientation1
Manage the kept side of iElement1 (value can be 1 or -1).
iElement2
The second feature to trim (curve or surface).
iOrientation2
Manage the kept side of iElement2 (value can be 1 or -1).
oTrim
Created trim.
o Func AddNewProject( Reference  iElement,
  Reference  iSupport) As HybridShapeProject
Parameters:
iElement
Element to project (point, curve).
Sub-element(s) supported (see Boundary object): see TriDimFeatEdge, BiDimFeatEdge and Vertex.
iSupport
Curve or surface support for projection.
oProjection
Created projection
o Func AddNewCorner( Reference  iElement1,
  Reference  iSupport,
  double  iRadius,
  long  iOrientation1,
  long  iOrientation2,
  boolean  iTrim) As HybridShapeCorner
Create a corner curve between a point and a curve or 2 curves on a support surface.
Parameters:
iElement1
First reference curve.
iElement2
Second reference curve.
iSupport
Support surface.
iRadius
Radius of the corner.
iOrientation1
Manage the corner center position. Value can be 1 or -1
iOrientation2
iTrim
Value can be FALSE or TRUE
if TRUE the 2 curves are trimed and asembled with the corner.
oCorner
Created corner.
o Func AddNew3DCorner( Reference  iElement1,
  double  iRadius,
  long  iOrientation1,
  long  iOrientation2,
Create a 3D corner curve between a point and a curve or 2 curves along a direction.
Parameters:
iElement1
iElement2
iDirection
Direction.
iRadius
iOrientation1
iOrientation2
iTrim
oCorner
Created corner.
o Func AddNewExtrapolUntil( Reference  iBoundary,
  Reference  iToExtrapol,
  Reference  iUntil) As HybridShapeExtrapol
Parameters:
iBoundary
Boundary point of curve to extrapolate or boundary curve of surface to extrapolate.
iToExtrapol
Curve or surface to extrapolate.
iUntil
Extrapolation limit surface.
oExtrapol
Created Extrapolation.
o Func AddNewExtrapolLength( Reference  iBoundary,
  double  iLength) As HybridShapeExtrapol
Parameters:
iBoundary
iToExtrapol
iLength
Extrapolation length.
oExtrapol
o Func AddNewRotate( Reference  iToRotate,
  Reference  iAxis,
  double  iAngle) As HybridShapeRotate
Parameters:
iToRotate
point, curve, surface or solid to transform.
iAxis
Rotation axis.
Sub-element(s) supported (see Boundary object): see Edge.
iAngle
Rotation angle.
oRotate
Created rotation.
o Func AddNewIntersection( Reference  iObject1,
  Reference  iObject2) As HybridShapeIntersection
Parameters:
iObject1
First element ( line, curve, plane, surface.
Sub-element(s) supported (see Boundary object): see Face, CATIARectlinearTriDimFeatEdge and RectilinearBiDimFeatEdge.
iObject2
Second element ( line , curve, plane, surface.
oIntersection
Intersection
o Func AddNewSymmetry( Reference  iObject,
  Reference  iReference) As HybridShapeSymmetry
Parameters:
iObject
Point, curve, surface or solid to transform.
iReference
Point, line or reference plane.
Sub-element(s) supported (see Boundary object): see PlanarFace, Edge and Vertex.
oSymmetry
Created symmetry.
o Func AddNewAxisToAxis( Reference  iObject,
  Reference  iReferenceAxis,
  Reference  iTargetAxis) As HybridShapeAxisToAxis
Parameters:
iObject
iReferenceAxis
reference axis system
iTargetAxis
target axis system
oAxisToAxis
Created axis to axis transformation.
o Func AddNewPointDatum( Reference  iObject) As HybridShapePointExplicit
Parameters:
iObject
The object whose topological body will be duplicated and put into created datum
oPoint
Created datum
o Func AddNewLineDatum( Reference  iObject) As HybridShapeLineExplicit
Parameters:
iObject
oLine
Created datum
o Func AddNewPlaneDatum( Reference  iObject) As HybridShapePlaneExplicit
Parameters:
iObject
oPlane
Created datum
o Func AddNewCurveDatum( Reference  iObject) As HybridShapeCurveExplicit
Parameters:
iObject
oCurve
Created curve
o Func AddNewCircleDatum( Reference  iObject) As HybridShapeCircleExplicit
Parameters:
iObject
oCircle
Created datum
o Func AddNewSurfaceDatum( Reference  iObject) As HybridShapeSurfaceExplicit
Parameters:
iObject
oSurface
Created surface
o Sub DeleteObjectForDatum( Reference  iObject)
Parameters:
iObject
Object to delete
o Func AddNewFill( ) As HybridShapeFill
Parameters:
oFill
Fill object
o Func AddNewFillEdgeWithSurface( Reference  iCurve,
  Reference  iSurface,
  long  iContinuity,
  double  iTension) As HybridShapeFillEdge
Parameters:
iCurve
Curve boundary
iSurface
Curve boundary surface support
iContinuity
Continuity with surface support
iTension
Tension with Fill curve boundary
oFillEdge
Fill surface
o Func AddNewFillEdge( Reference  iCurve,
  long  iContinuity,
Parameters:
iCurve
Curve boundary
iContinuity
iTension
oFillEdge
Fill curve boundary
o Func AddNewFillEdges( HybridShapeFillEdge  iFillEdge) As HybridShapeFillEdges
Parameters:
iFillEdge
Fill Curve boundary
oFillEdges
List of Fill curve boundaries
o Func AddNewEmptyFillEdges( ) As HybridShapeFillEdges
Parameters:
oFillEdges
o Func AddNewSpline( ) As HybridShapeSpline
Parameters:
oSpline
Created spline.
o Func AddNewSpiral( long  iType,
  Reference  iSupport,
  Reference  iCenterPoint,
  HybridShapeDirection  iAxis,
  double  iStartingRadius,
  boolean  iClockwiseRevolution) As HybridShapeSpiral
Parameters:
iType
Spiral is defined by AngleRadius, AnglePitch or PitchRadius.
iSupport
Spiral planar support.
iCenterPoint
Center point.
iAxis
Axis.
iStartingRadius
Defines the starting point: distance from the center point on the axis.
oSpiral
The Spiral object if succeded
o Func AddNewBoundary( Reference  iInitialElement,
  Reference  iSupport,
  long  iTypedePropagation) As HybridShapeBoundary
Parameters:
iInitialElement
the element used to initialise the propagation around the surface
Sub-element(s) supported (see Boundary object): see BiDimFeatEdge.
iSupport
the surface used to compute the boundary around it
iTypedePropagation
Propagation type the values are: 0 for Boundary for all edges 1 for Boundary propagation for edges on connexe point 2 for Boundary propagation for edges tangent at point breaks 3 for Boundary not propagation from the current edge
oBoundary
The computed element
o Func AddNewBoundaryOfSurface( Reference  Surface) As HybridShapeBoundary
Parameters:
iSurface
the feature on which all the boundaries will be computed
oBoundary
the whole boundary of the Surface given in first parameter
o Func AddNewPointCoord( double  iX,
  double  iY,
  double  iZ) As HybridShapePointCoord
Parameters:
iX
X coordinate for the point
iY
Y coordinate for the point
iZ
Z coordinate for the point
oPoint
Created point
o Func AddNewPointCoordWithReference( double  iX,
  double  iY,
  double  iZ,
  Reference  iPt) As HybridShapePointCoord
Parameters:
iX
iY
iZ
iPt
Reference point.
oPoint
Created point
o Func AddNewPointBetween( Reference  iPoint1,
  Reference  iPoint2,
  double  iRatio,
  long  iOrientation) As HybridShapePointBetween
Parameters:
iPoint1
Reference point to compute the barycenter.
iPoint2
Second point.
iRatio
barycenter parameter
iOrientation
To compute the barycenter of the segment [Pt1 - Pt2]
oPoint
PointBetween if succeded
o Func AddNewPointOnCurveWithReferenceFromDistance( Reference  iCrv,
  Reference  iPt,
  double  iLong,
  boolean  iOrientation) As HybridShapePointOnCurve
Parameters:
iCrv
support curve.
iPt
reference point.
iLong
distance (length) to reference point
iOrientation
Orientation = TRUE means that distance is measured in the other orientation of the curve
oPoint
Created point
o Func AddNewPointOnCurveFromDistance( Reference  iCrv,
  double  iLong,
Parameters:
iCrv
support curve.
iLong
distance to extremity
iOrientation
Orientation = TRUE means that distance is measured in the other orientation of the curve and from the other extremity.
oPoint
Created point
o Func AddNewPointOnCurveWithReferenceFromPercent( Reference  iCrv,
  Reference  iPt,
  double  iLong,
Parameters:
iCrv
Support curve.
iPt
reference point.
iLong
Ratio of curve length
iOrientation
Orientation = TRUE means that ratio is measured in the other orientation of the curve
oPoint
Created point
o Func AddNewPointOnCurveFromPercent( Reference  iCrv,
  double  iLong,
Parameters:
iCrv
support curve.
iLong
iOrientation
Orientation = TRUE means that ratio is measured in the other orientation of the curve and from the other extremity.
oPoint
Created point
o Func AddNewPointOnPlaneWithReference( Reference  iPlane,
  Reference  iPt,
  double  iX,
  double  iY) As HybridShapePointOnPlane
Parameters:
iPlane
Support plane
iPt
Reference plane
iX
X cartesian coordinates in the plane.
iY
Y cartesian coordinates in the plane.
oPoint
Created point
o Func AddNewPointOnPlane( Reference  iPlane,
  double  iX,
Parameters:
iPlane
Support plane
iX
iY
oPoint
Created point
o Func AddNewPointOnSurfaceWithReference( Reference  iSurface,
  Reference  iPt,
  double  iX) As HybridShapePointOnSurface
Parameters:
iSurface
Support surface.
iPt
reference point.
iDirection
Direction from the reference point in which the point is computed.
iX
geodesic length to reference point
oPoint
Created point
o Func AddNewPointOnSurface( Reference  iSurface,
Parameters:
iSurface
Support surface.
iDirection
iX
oPoint
Created point
o Func AddNewPointCenter( Reference  iCurve) As HybridShapePointCenter
Parameters:
iCurve
Reference circle
oPoint
Created point
o Func AddNewPointTangent( Reference  iCurve,
  HybridShapeDirection  iDirection) As HybridShapePointTangent
Parameters:
iCurve
Reference curve.
iDirection
Direction in which tangent points are computed
oPoint
Created point
o Func AddNewLinePtPt( Reference  iPtOrigine,
  Reference  iPtExtremite) As HybridShapeLinePtPt
Parameters:
iPtOrigine
Origin point.
iPtExtremite
Extremity point.
oLine
Created line
o Func AddNewLinePtPtOnSupport( Reference  iPtOrigine,
  Reference  iPtExtremite,
  Reference  iSupport) As HybridShapeLinePtPt
Parameters:
iPtOrigine
Origin point.
iPtExtremite
Extremity point.
iSupport
Support element (surface or plane)
oLine
Created line
o Func AddNewLinePtPtExtended( Reference  iPtOrigine,
  double  iBeginOffset,
  double  iEndOffset) As HybridShapeLinePtPt
Parameters:
iPtOrigine
Origin point.
iPtExtremite
Extremity point.
iBeginOffset
start offset
iEndOffset
end offset
oLine
Created line
o Func AddNewLinePtPtOnSupportExtended( Reference  iPtOrigine,
  Reference  iSupport,
Parameters:
iPtOrigine
Origin point.
iPtExtremite
Extremity point.
iSupport
iBeginOffset
start offset
iEndOffset
end offset
oLine
Created line
o Func AddNewLinePtDir( Reference  iPt,
  double  iEndOffset,
  boolean  iOrientation) As HybridShapeLinePtDir
Parameters:
iPt
reference point.
iDirection
Direction
iBeginOffset
start offset
iEndOffset
end offset
iOrientation
Orientation allows to reverse the line direction from the reference point. For a line of L length, it is the same as creating this line with -L length.
oLine
Created line
o Func AddNewLinePtDirOnSupport( Reference  iPt,
  Reference  iSupport,
  double  iEndOffset,
Parameters:
iPt
reference point.
iDirection
Direction
iSupport
iBeginOffset
start offset
iEndOffset
end offset
iOrientation
oLine
Created line
o Func AddNewLineAngle( Reference  iCurve,
  Reference  iSurface,
  Reference  iPoint,
  boolean  iGeodesic,
  double  iEndOffset,
  double  iAngle,
  boolean  iOrientation) As HybridShapeLineAngle
Parameters:
iCurve
Reference curve.
iSurface
Reference surface.
iPoint
reference point.
iGeodesic
Puts the line on the surface
iBeginOffset
start offset
iEndOffset
end offset
iAngle
angle to reference curve
iOrientation
oLine
Created line
o Func AddNewLineTangency( Reference  iCurve,
  Reference  iPoint,
  double  iEndOffset,
  boolean  iOrientation) As HybridShapeLineTangency
Parameters:
iCurve
Reference curve.
iPoint
Reference point.
iBeginOffset
start offset
iEndOffset
end offset
iOrientation
oLine
Created line
o Func AddNewLineBiTangent( Reference  iCurve1,
  Reference  iSupport) As HybridShapeLineBiTangent
Parameters:
iCurve1
First tangency curve lying on the support surface.
iCurve2
Second tangency element (point, curve) lying on the support surface.
iSupport
The support surface of the two elements.
oLine
Created line
o Func AddNewLineTangencyOnSupport( Reference  iCurve,
  Reference  iPoint,
  Reference  iSupport,
  double  iEndOffset,
Parameters:
iCurve
Reference curve.
iPoint
Reference point.
iSupport
iBeginOffset
start offset
iEndOffset
end offset
iOrientation
oLine
Created line
o Func AddNewLineNormal( Reference  iSurface,
  Reference  iPoint,
  double  iEndOffset,
  boolean  iOrientation) As HybridShapeLineNormal
Parameters:
iSurface
Reference surface.
iPoint
Reference point.
iBeginOffset
start offset
iEndOffset
end offset
iOrientation
oLine
Created line
o Func AddNewLineBisecting( Reference  iLine1,
  Reference  iLine2,
  double  iEndOffset,
  boolean  iOrientation,
  long  SolutionNb) As HybridShapeLineBisecting
Parameters:
iLine1
First line.
Sub-element(s) supported (see Boundary object): see CATIARectlinearTriDimFeatEdge and CATIARectlinearBiDimFeatEdge.
iLine2
Second line.
iBeginOffset
start offset
iEndOffset
end offset
iOrientation
oLine
Created line
o Func AddNewLineBisectingOnSupport( Reference  iLine1,
  Reference  iLine2,
  Reference  iSurface,
  double  iEndOffset,
Parameters:
iLine1
First line.
iLine2
Second line.
GMT+8, 2025-4-22 04:00 , Processed in 0.028067 second(s), 14 queries , Gzip On, Redis On.
