查看: 16605|回复: 8
【求助】 I am Very SAD with IDEAS
发表于 2002-10-31 23:41:02 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
Hi evrybody,
Just started to use IDEAS 8.0 in my new job, feel very sad :( .
I use ProE before this, i find IDEAS very slow, still use the old style Boolean Operation. I need help and comment from you all.
How to imoprove my sefl in IDEAS, what is the concept it use, very different from ProE, and i cant catch up with it .
What good is IDEAS compare to ProE, i dont see any, please let me know .
many thanks, i am serius on this .
发表于 2002-11-3 18:06:36 | 只看该作者
i ever used pro/e ,but i feel i-deas is better than pro/e ,you just try it, you'll find i-deas is so powerful . pro/e have too many constrain to modify your model ,parameter system is bad ,variable system is good method to create your model
发表于 2002-11-4 20:27:22 | 只看该作者
I think so. It's easy to learn.and it has a perfect tutorial in help.you can learn quickly.  Good Luck. Be patient to it,you can be success!::y
发表于 2002-11-7 23:08:38 | 只看该作者
JUst getting into it, feel it was more flexible then ProE, your are rite .
I like to ask, does people use IDEAS in designing high profile / curve product ? such as automobiles and consumer product ?
发表于 2002-11-12 12:53:41 | 只看该作者
over 10000seats ideas
  Ford,
over 1000 seats ideas
  renault, Nissan, Mazda, Boeing, LG, Samsung, xerrox toshiba,
over 500 seats ideas
matihita(national), canon, Thomson, Nokia, Lexmark, segate,
as it focus on big company, fortune500( over80)
bigger then pro/e
bigger then Ug
it is not famous by you only.
do you need a lsit for ideas customer.
发表于 2002-11-12 21:54:35 | 只看该作者
Ok, thanks for the list, it does give me more confidence. I think maybe i am not get into it yet , especially the surface modelling stuff i used to do last time with ProE.
发表于 2002-12-19 20:47:25 | 只看该作者
i can use these two softares, they are quite deference from each other.
in my opinion, i_deas is much better than pro/e, and i_deas has very good tutorials, they are vry helpful.
发表于 2002-12-19 21:25:48 | 只看该作者
So far so good, can use IDEAS in daily job already .
发表于 2002-12-20 08:12:07 | 只看该作者
Congratulation!
GMT+8, 2025-4-9 06:17 , Processed in 0.023223 second(s), 12 queries , Gzip On, Redis On.
