查看: 15973|回复: 1
VB二次开发
发表于 2004-9-14 15:55:44 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
哪位大虾清帮忙下面的VB程序中为什么 不能再文本筐中显示零件的质量单位为Kg,调试时总是提示类型不匹配,应如何更改。
谢谢!!!
Private Sub Command1_Click()
    swMassPropertiesStatus_OK = 0
    swMassPropertiesStatus_UnknownError = 1
    swMassPropertiesStatus_NoBody = 2
Const swUpdateMassPropsDuringSave       As Long = 30
    Dim swApp                   As Object
    Dim swModel                 As Object
    Dim sFileName               As String
    Dim vConfNameArr            As Variant
    Dim sConfigName             As String
    Dim vMassProp               As Variant
    Dim i                       As Long
    Dim bRet                    As Boolean
    Dim weight                  As Single
    Set swApp = CreateObject("SldWorks.Application")
    Set swModel = swApp.ActiveDoc
    sFileName = swModel.GetPathName
    vConfNameArr = swModel.GetConfigurationNames
    For i = 0 To UBound(vConfNameArr)
        sConfigName = vConfNameArr(i)
        vMassProp = swApp.GetMassProperties(sFileName, sConfigName)
            weight = vMassProp(5)
        Text1.Text = Str(weight)
    Next i
End Sub
发表于 2004-9-23 21:18:00 | 只看该作者
在weight = vMassProp(5)、Text1.Text = Str(weight) 中仔细看看吧
GMT+8, 2025-7-30 23:08 , Processed in 0.021575 second(s), 12 queries , Gzip On, Redis On.
