查看: 15540|回复: 0
【求助】恳请高手帮忙
发表于 2004-9-18 09:31:41 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
我是按照 adams 帮助里的讲解做的 天线仿真的例子, 不过我是反过来做的,
使用 adams 调用 matlab 做的,但到最后出现这样的问题:
### Starting Real-Time Workshop build procedure for model: antenna
### Generating code into build directory: .\antenna_grt_rtw
### Invoking Target Language Compiler on antenna.rtw
tlc -r .\antenna_grt_rtw\antenna.rtw 'D:\MATLAB6p1\rtw\c\grt\grt.tlc' -O.\antenna_grt_rtw '-ID:\MATLAB6p1\rtw\c\grt' '-ID:\MATLAB6p1\rtw\c\tlc' -aEnforceIntegerDowncast=1 -aExtMode=0 -aFoldNonRolledExpr=1 -aForceParamTrailComments=0 -aGenerateComments=1 -aIgnoreCustomStorageClasses=1 -aIncHierarchyInIds=0 -aInlineInvariantSignals=0 -aInlineParameters=0 -aLocalBlockOutputs=1 -aLogVarNameModifier="rt_" -aRTWVerbose=1 -aRollThreshold=5 -aShowEliminatedStatements=1 -aReleaseVersion=12.1 -p10000
### Loading TMW TLC function libraries
### Initial pass through model to cache user defined code
### Caching model source code
### Creating (RealTime) source file antenna.c
### Creating model header file antenna.h
### Creating model header file antenna_export.h
### Creating parameter file antenna_prm.h
### Creating registration file antenna_reg.h
### TLC code generation complete.
### Creating project marker file: rtw_proj.tmw
### Creating antenna.mk from D:\abs_test\shiyan\grt_vc.tmf
### Building antenna: nmake -f antenna.mk
'nmake' 不是内部或外部命令,也不是可运行的程序
或批处理文件。
   请问这怎么解决 ?
   谢谢!!!!!!!!!!!!!
GMT+8, 2025-4-29 11:50 , Processed in 0.031225 second(s), 12 queries , Gzip On, Redis On.
