查看: 17535|回复: 8
【原创】
发表于 2002-11-5 03:15:33 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
this one done by alias and photoshop.
发表于 2002-11-22 18:43:52 | 只看该作者
不错。能不能介绍一下render的方法。谢谢了。
发表于 2002-11-26 10:54:02 | 只看该作者
the top portion is done in Alias, the tripod and background are photo. since it's a comp, the most important thing is to match the perspective.
then match the light source, look at where the light source on the photo. and adjust the lighting in Alias, there is no good way to do it. it just need a lot of tweaking........
samething on the material, try to look at the any references material that can represent the material you try to cheat, for example, how glass's reflection, how shining is the material ...etc......to make this rendering real, the detail color mapping is also important, so spend time to scan the type and graph for mapping....
whatelse can I say? your question is kind of general, if you have more specific question will be easier to answer you....
发表于 2002-11-28 13:33:51 | 只看该作者
This picture is excellent!! Looks like real photo .
I want to know which part modified by photoshop?
Using photoshop to do what's knid of effect?
Thanks a lot!
发表于 2002-12-4 02:44:05 | 只看该作者
tripod, remote contral and the cord ..of course the background are real photo. the main unit and the arms are Alias render. so the only overlapping is the remote cord. I have to extend the cord and adjust the position where it connect to the main body. to be more detail, I cut part of the cord and copy it to extend the length. after that, copy part of the cord, blur it and use it as casting shadow on the main body. other than that just lots of detail clean out. not much photoshop effect actually. hope that will answer your question.
发表于 2002-12-6 19:43:38 | 只看该作者
awesome
where are you working at?
发表于 2002-12-7 08:39:47 | 只看该作者
I work at State. once a year will go to ShenZhen...
发表于 2005-10-3 12:11:57 | 只看该作者
good !
发表于 2005-11-4 14:40:41 | 只看该作者
how do you do!
I am chinese boy,
I am working at shenzhen.
I am a industry designer ,
I wish see you ,your design is very nice.
I use Rhino and Alias 、photshop,
I wish studing Alias by you.
Can you help me ?
Thank you very much,
My MSN:achenggegeaini@hotmail.com
My phone:13798360731
My QQ:173208454
you are welcome,Best Regards!
I waiting for your news.
GMT+8, 2025-4-28 00:26 , Processed in 0.027240 second(s), 12 queries , Gzip On, Redis On.
