查看: 18457|回复: 3
求助:CAAV5R14调试程序时出错,不知道什么原因
发表于 2004-10-10 20:53:43 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
小弟在CAA V5R13上调试通过
但在R14上却出现一些问题,为了了解全面,将整个调试信息粘上来了
== cmd /c type E:\CAAExcises\test\ToolsData\Log\Log-0 ====================================
mkmk -a  -u -g
2004/10/10 と 08:21:48
## start step: CIbuild   at 10/10/2004-20:21:48
## end   step: CIbuild   at 10/10/2004-20:21:48
## start step: DataUpdate   at 10/10/2004-20:21:48
# make:  fr1\IdentityCard\Objects\intel_a\.mkdata.mk
# make:  fr2\IdentityCard\Objects\intel_a\.mkdata.mk
## end   step: DataUpdate   at 10/10/2004-20:21:48
# make:  fr1\Draw.m\Objects\intel_a\.mkdata.mk
# make:  fr1\HanJie.m\Objects\intel_a\.mkdata.mk
# make:  fr1\partmodule.m\Objects\intel_a\.mkdata.mk
# make:  fr2\m2.m\Objects\intel_a\.mkdata.mk
## end   step: DataUpdate   at 10/10/2004-20:21:49
## start step: headerlist   at 10/10/2004-20:21:49
## end   step: headerlist   at 10/10/2004-20:21:49
## start step: headermap   at 10/10/2004-20:21:49
# make:  fr1\ImportedInterfaces\intel_a\.HeaderTable.map
# make:  fr2\ImportedInterfaces\intel_a\.HeaderTable.map
## end   step: headermap   at 10/10/2004-20:21:50
## start step: grammar1st   at 10/10/2004-20:21:50
# make:  fr1\Draw.m\LocalGenerated\intel_a\mkCAAV5Licensing.cpp
mkCAAV5Licensing.cpp.CPP
# make:  fr1\HanJie.m\LocalGenerated\intel_a\mkCAAV5Licensing.cpp
# make:  fr1\partmodule.m\LocalGenerated\intel_a\mkCAAV5Licensing.cpp
# make:  fr2\m2.m\LocalGenerated\intel_a\mkCAAV5Licensing.cpp
## end   step: grammar1st   at 10/10/2004-20:21:50
## start step: headerlist   at 10/10/2004-20:21:50
## end   step: headerlist   at 10/10/2004-20:21:50
## start step: headermap   at 10/10/2004-20:21:50
## start step: grammar2nd   at 10/10/2004-20:21:50
# make:  fr1\HanJie.m\src\TIE_IHanJieAddin.tsrc
# make:  fr1\HanJie.m\src\TIE_IHanJieWorkbenchFactory.tsrc
## end   step: grammar2nd   at 10/10/2004-20:21:51
## start step: headerlist   at 10/10/2004-20:21:51
## end   step: headerlist   at 10/10/2004-20:21:51
## start step: headermap   at 10/10/2004-20:21:51
## end   step: headermap   at 10/10/2004-20:21:51
## start step: headerruler   at 10/10/2004-20:21:51
## end   step: headerruler   at 10/10/2004-20:21:51
## start step: compilation   at 10/10/2004-20:21:51
# make:  fr1\Draw.m\src\Draft.cpp
Draft.cpp
# make:  fr1\HanJie.m\src\HanJieWorkbench.cpp
HanJieWorkbench.cpp
# make:  fr1\HanJie.m\src\HanJieWorkbenchFactory.cpp
# make:  fr1\HanJie.m\src\IHanJieAddin.cpp
IHanJieAddin.cpp
# make:  fr1\HanJie.m\src\IHanJieWorkbenchFactory.cpp
# make:  fr1\partmodule.m\src\part.cpp
part.cpp
# make:  fr2\m2.m\src\aaBox.cpp
aaBox.cpp
# make:  fr2\m2.m\src\aaCmd.cpp
aaCmd.cpp
# make:  fr2\m2.m\src\CreateBox.cpp
CreateBox.cpp
# make:  fr2\m2.m\src\CreateCmd.cpp
CreateCmd.cpp
# make:  fr2\m2.m\src\GetRootProd.cpp
GetRootProd.cpp
# make:  fr2\m2.m\src\lash2Box.cpp
lash2Box.cpp
# make:  fr2\m2.m\src\lash2Cmd.cpp
lash2Cmd.cpp
# make:  fr2\m2.m\src\lashBox.cpp
lashBox.cpp
# make:  fr2\m2.m\src\lashCmd.cpp
lashCmd.cpp
# make:  fr2\m2.m\src\NewProjectBox.cpp
NewProjectBox.cpp
# make:  fr2\m2.m\src\NewProjectCmd.cpp
NewProjectCmd.cpp
# make:  fr2\m2.m\src\OpenPartCmd.cpp
OpenPartCmd.cpp
# make:  fr2\m2.m\src\OpenProjectCmd.cpp
OpenProjectCmd.cpp
# make:  fr2\m2.m\src\padBox.cpp
padBox.cpp
# make:  fr2\m2.m\src\padCmd.cpp
padCmd.cpp
# make:  fr2\m2.m\src\PaiyangBox.cpp
PaiyangBox.cpp
# make:  fr2\m2.m\src\PaiyangCmd.cpp
PaiyangCmd.cpp
# make:  fr2\m2.m\src\SaveProjectBox.cpp
SaveProjectBox.cpp
# make:  fr2\m2.m\src\SaveProjectCmd.cpp
SaveProjectCmd.cpp
## end   step: compilation   at 10/10/2004-20:22:11
## start step: link1st   at 10/10/2004-20:22:11
# make: fr1\Draw.m intel_a\code\lib\Draw.lib
    Creating library E:\CAAExcises\test\.\intel_a\code\lib\Draw.lib and object E:\CAAExcises\test\.\intel_a\code\lib\Draw.exp
# make: fr1\HanJie.m intel_a\code\lib\HanJie.lib
    Creating library E:\CAAExcises\test\.\intel_a\code\lib\HanJie.lib and object E:\CAAExcises\test\.\intel_a\code\lib\HanJie.exp
# make: fr1\partmodule.m intel_a\code\lib\partmodule.lib
    Creating library E:\CAAExcises\test\.\intel_a\code\lib\partmodule.lib and object E:\CAAExcises\test\.\intel_a\code\lib\partmodule.exp
# make: fr2\m2.m intel_a\code\lib\m2.lib
    Creating library E:\CAAExcises\test\.\intel_a\code\lib\m2.lib and object E:\CAAExcises\test\.\intel_a\code\lib\m2.exp
## end   step: link1st   at 10/10/2004-20:22:12
## start step: link2nd   at 10/10/2004-20:22:12
# make: fr1\Draw.m intel_a\code\bin\Draw.dll
# make: fr1\HanJie.m intel_a\code\bin\HanJie.dll
# make: fr1\partmodule.m intel_a\code\bin\partmodule.dll
# make: fr2\m2.m intel_a\code\bin\m2.dll
# CAAV5-ERROR: unauthorized API for CAA V5:
# CAAV5-ERROR:    -> CATIPrtManagement_var
# make-ERROR: intel_a\code\bin\m2.dll
## end   step: link2nd   at 10/10/2004-20:22:44
## start step: dummynls   at 10/10/2004-20:22:44
# make: fr1 fr1\CNext\resources\msgcatalog\Draft.CATNls
# make: fr1 fr1\CNext\resources\msgcatalog\part.CATNls
# make: fr1 fr1\CNext\resources\msgcatalog\partCmdHeader.CATNls
# make: fr1 fr1\CNext\resources\msgcatalog\OpenProjectCmdCmdHeader.CATNls
# make: fr1 fr1\CNext\resources\msgcatalog\DraftCmdHeader.CATNls
# make: fr1 fr1\CNext\resources\msgcatalog\HanJieCmdHeader.CATNls
# make: fr1 fr1\CNext\resources\msgcatalog\HanJie.CATNls
# make: fr2 fr2\CNext\resources\msgcatalog\SaveProjectCmd.CATNls
# make: fr2 fr2\CNext\resources\msgcatalog\NewProjectCmd.CATNls
# make: fr2 fr2\CNext\resources\msgcatalog\NewProjectBox.CATNls
# make: fr2 fr2\CNext\resources\msgcatalog\lash2Box.CATNls
# make: fr2 fr2\CNext\resources\msgcatalog\CreateBox.CATNls
# make: fr2 fr2\CNext\resources\msgcatalog\padBox.CATNls
# make: fr2 fr2\CNext\resources\msgcatalog\OpenProjectCmd.CATNls
# make: fr2 fr2\CNext\resources\msgcatalog\OpenPartCmd.CATNls
# make: fr2 fr2\CNext\resources\msgcatalog\lash2Cmd.CATNls
# make: fr2 fr2\CNext\resources\msgcatalog\PaiyangBox.CATNls
# make: fr2 fr2\CNext\resources\msgcatalog\lashCmd.CATNls
# make: fr2 fr2\CNext\resources\msgcatalog\lashBox.CATNls
# make: fr2 fr2\CNext\resources\msgcatalog\PaiyangCmd.CATNls
# make: fr2 fr2\CNext\resources\msgcatalog\aaCmd.CATNls
# make: fr2 fr2\CNext\resources\msgcatalog\aaBox.CATNls
# make: fr2 fr2\CNext\resources\msgcatalog\SaveProjectBox.CATNls
# make: fr2 fr2\CNext\resources\msgcatalog\CreateCmd.CATNls
# make: fr2 fr2\CNext\resources\msgcatalog\padCmd.CATNls
## end   step: dummynls   at 10/10/2004-20:22:45
== Command done, return code = 0
Tool returned code: 0
各位大侠帮忙看看原因
发表于 2004-10-16 00:25:34 | 只看该作者
使用了非正版的API
发表于 2004-10-16 09:21:01 | 只看该作者
CATIPrtManagement.h在13是公开的,14里不对外公开了
常有的事,多半会有更好用的类似功能的interface提供出来的
发表于 2004-10-26 17:05:46 | 只看该作者
谢谢acoka兄
GMT+8, 2025-4-19 01:07 , Processed in 0.025988 second(s), 11 queries , Gzip On, Redis On.
