查看: 17295|回复: 13
【求助】我系新手,边位大虾帮我改后处理
发表于 2004-11-8 08:44:34 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
如我的格式(m64) 多谢赏脸E-MAIL:qiang790@163.com 急!!!我想上机试!系别的论坛无人采我,我发觉这里这大大们热心多了!?
G40 G49 G17 G21 G90 G54 G80 G00
G91 G28 Z0.
T01 M06
G90 S2000 M03
(NAME--- 1101a2.NC)
(Tool :   D25R5)
G00 G90 X171.157 Y-271.837
Z50.
Z9.236
Z8.736
G01 Z8.536 F1000.
X184.157
X230.757
X231.189 Y-264.337
X184.157
Y-256.837
X231.62
X232.049 Y-249.337
X184.157
Y-241.837
X232.48
X232.728 Y-237.509
X232.687 Y-236.814
X232.487 Y-236.147
X232.138 Y-235.544
X231.66 Y-235.038
X231.078 Y-234.655
X230.424 Y-234.417
X229.733 Y-234.337
X184.157
X183.115 Y-234.428
X182.105 Y-234.699
X181.157 Y-235.141
X180.3 Y-235.741
X179.56 Y-236.48
X178.961 Y-237.337
G00 Z50.
M05
M09
M30
发表于 2004-11-8 08:45:39 | 只看该作者
G91 G28 Z0.
T01 M06
G90 S2000 M03
(NAME--- 1101a2.NC)
(Tool : D25R5)
Z50.
Z9.236
Z8.736
G01 Z8.536 F1000.
X184.157
X230.757
X231.189 Y-264.337
X184.157
Y-256.837
X231.62
X232.049 Y-249.337
X184.157
Y-241.837
X232.48
X232.728 Y-237.509
X232.687 Y-236.814
X232.487 Y-236.147
X232.138 Y-235.544
X231.66 Y-235.038
X231.078 Y-234.655
X230.424 Y-234.417
X229.733 Y-234.337
X184.157
X183.115 Y-234.428
X182.105 Y-234.699
X181.157 Y-235.141
X180.3 Y-235.741
X179.56 Y-236.48
X178.961 Y-237.337
G00 Z50.
M05
M09
M30
发表于 2004-11-8 12:31:36 | 只看该作者
传上来我帮你改!~
发表于 2004-11-9 10:17:36 | 只看该作者
无限感激,多谢你为我在初学的路上推一把
machine fanuc
#  Option for with Fanuc18t control.
#  Modified by Delcam HK on 14 May 2002.
   define word TN
    address letter = "( T - "
    address width  = 6
    field width    = 2
   end define
   define word TL
    address letter = "   L - "
    address width  = 7
    field width    = 2
   end define
   define word TD
    address letter = "   DIA. = "
    address width  = 10
    field width    = 6
    scale factor   = 2
   end define
   define format (TD)
    metric formats
    decimal point = true
    decimal places = 2
    leading zeros  = false
    trailing zeros = true
    imperial formats = metric formats
   end define
   define word TD2
    address letter = "( DIA. = "
    address width  = 9
    field width    = 6
    scale factor   = 2
   end define
   define format (TD2)
    metric formats
    decimal places = 2
   end define
   define word TipR
    address letter = "   R = "
    address width  = 7
    field width    = 6
    scale factor   = 1
   end define
   define format (TipR)
    metric formats
    decimal places = 2
   end define
   define word TPN
    address letter = "   "
    address width  = 3
    field width    = 15
   end define
   define format ( / G6 S T L P D E H O )
    address width              =   1
    field width                =   2
    exponent width             =   0
    scale factor               =   1
    scale divisor              =   1
    tape position              =   0
    print position             =   1
    sign                       = none
    not permanent
    not modal
   metric formats
    decimal point              = false
    decimal places             =   0
   imperial formats
    decimal places             =   0
   end define
   define format ( M1 M2 )
    address width              =   1
    field width                =   2
    exponent width             =   0
    scale factor               =   1
    scale divisor              =   1
    tape position              =   0
    print position             =   1
    sign                       = none
    not permanent
    not modal
   metric formats
    leading zeros              = true
    decimal places             =   0
   imperial formats
    decimal places             =   0
   end define
   define format ( N )
    address width              =   1
    field width                =   4
    exponent width             =   0
    scale factor               =   1
    scale divisor              =   1
    tape position              =   0
    print position             =   1
    sign                       = none
    not permanent
    not modal
   metric formats
    decimal places             =   0
   imperial formats
    decimal places             =   0
   end define
   define format ( G1 G2 G3 G4 G5 G7 )
    address width              =   1
    field width                =   2
    exponent width             =   0
    scale factor               =   1
    scale divisor              =   1
    tape position              =   0
    print position             =   1
    sign                       = none
    not permanent
    modal
   metric formats
#    leading zeros              = false
    decimal places             =   0
   imperial formats
    decimal places             =   0
   end define
   define format ( X Y Z R B C )
    address width              =   1
    field width                =   8
    exponent width             =   0
    scale factor               =   1
    scale divisor              =   1
    tape position              =   0
    print position             =   1
    sign                       = if negative
    not permanent
    modal
   metric formats
    trailing zeros             = false
    decimal places             =   3
   imperial formats
    decimal places             =   4
   end define
   define format ( I J K )
    address width              =   1
    field width                =   8
    exponent width             =   0
    scale factor               =  -1
    scale divisor              =   1
    tape position              =   0
    print position             =   1
    sign                       = if negative
    not permanent
    not modal
   metric formats
    decimal places             =   3
   imperial formats
    decimal places             =   4
   end define
   define format ( R2 Z2 Q1 )
    address width              =   1
    field width                =   8
    exponent width             =   0
    scale factor               =   1
    scale divisor              =   1
    tape position              =   0
    print position             =   1
    sign                       = if negative
    not permanent
    not modal
   metric formats
    decimal places             =   3
   imperial formats
    decimal places             =   4
   end define
   define format ( Q A U V W )
    address width              =   1
    field width                =   2
    exponent width             =   0
    scale factor               =   1
    scale divisor              =   1
    tape position              =   0
    print position             =   1
    sign                       = if negative
    not permanent
    not modal
   metric formats
    decimal places             =   0
   imperial formats
    decimal places             =   0
   end define
   define format ( F )
    address width              =   1
    field width                =   2
    exponent width             =   0
    scale factor               =   1
    scale divisor              =   1
    tape position              =   0
    print position             =   1
    sign                       = if negative
    not permanent
    modal
   metric formats
    decimal places             =   0
   imperial formats
    decimal places             =   0
   end define
   define format ( MS EM OP )
    address width              =   1
    field width                =   0
    exponent width             =   0
    scale factor               =   1
    scale divisor              =   1
    tape position              =   0
    print position             =   1
    sign                       = none
    not permanent
    not modal
   metric formats
    decimal places             =   0
   imperial formats
    decimal places             =   0
   end define
   define format ( ID )
    address width              =   1
    field width                =   4
    exponent width             =   0
    scale factor               =   1
    scale divisor              =   1
    tape position              =   0
    print position             =   1
    sign                       = none
    not permanent
    not modal
   metric formats
    decimal places             =   0
   imperial formats
    decimal places             =   0
   end define
   define format ( null )
    address width              =   0
    field width                =   0
    exponent width             =   0
    scale factor               =   1
    scale divisor              =   1
    tape position              =   0
    print position             =   1
    sign                       = none
    not permanent
    not modal
   metric formats
    decimal places             =   0
   imperial formats
    decimal places             =   0
   end define
# linked words
   define format ( MS )
     link to EM
   end define
    word order = (    OP   N    G1   G2   G3   G4   G5   )
    word order = ( +  G6   G7   X    Y    Z    B    C    )
    word order = ( +  I    J    K    R    D    S    T    )
    word order = ( +  H    M1   M2   MS   msg  EM   Q    )
    word order = ( +  Q1   Z2   R2   ID   F    )
    word order = ( +  TN  TL  TD  TPN  TD2  TipR  )
  define keys
    blocknumber                       not used
    preparatory function              = G1
    aux function                      = M1
    x feedrate                        not used
    y feedrate                        not used
    z feedrate                        not used
    circle angle                      not used
    x coordinate                      = X
    y coordinate                      = Y
    z coordinate                      = Z
    key i                             = I
    key j                             = J
    key k                             = K
    feedrate                          = F
    feedrate per revolution           = F
    spindle                           = S
    tool number                       = T
    cycle dwell                       not used
    dwell                             = X
    tool length                       not used
    tool radius                       = D
    drill peck depth                  = Q1
    drill hole depth                  = Z2
    clearplane                        = R2
    message start                     = MS
    message end                       = EM
    opskip                            = OP
    radius                            = R
    program id                        = ID
    azimuth axis                      = B
    elevation axis                    = C
    3rd rotation axis                 = null
    leader                            not used
    x vector                          not used
    y vector                          not used
    z vector                          not used
  end define
  define codes
    rapid                             =  G1    0
    linear                            =  G1    1
    circle cw                         =  G1    2
    circle ccw                        =  G1    3
    dwell                             =  G6    4
    xy plane                          =  G3   17
    zy plane                          =  G3   19
    xz plane                          =  G3   18
    compensation off                  =  G2   40
    compensation on left              =  G2   41
    compensation on right             =  G2   42
    imperial data                     =  G4   20
    metric data                       =  G4   21
    absolute data                     =  G5   90
    incremental data                  =  G5   91
    from                              =  G3   54
    feedrate per minute               not used
    feedrate per revolution           not used
    spindle rpm                       not used
    constant surface speed            not used
    drill                             =  G4   81
    break chip                        =  G4   82
    deep drill                        =  G4   83
    tap                               =  G4   84
    bore 1                            =  G4   85
    bore 2                            =  G4   86
    bore 3                            =  G4   87
    bore 4                            =  G4   88
    bore 5                            =  G4   89
    end of drill                      =  G4   80
    macro start                       not used
    macro end                         not used
    macro call                        not used
    cycle retract                     =  G6   99
    tool length offset                not used
    spline                            not used
    stop                              =  M1    0
    opt stop                          =  M1    1
    spindle on cw                     =  M1    3
    spindle on cc                     =  M1    4
    spindle off                       =  M1    5
    spin coolant on cw                =  M1   13
    spin coolant on ccw               =  M1   14
    spin coolant off                  =  M1    5
    change tool                       =  M1    6
    coolant on mist                   =  M1    7
    coolant on                        =  M1    8
    coolant on flood                  =  M1    8
    coolant off                       =  M1    9
    clamp on                          not used
    clamp off                         not used
    end of tape                       =  M1    2
    end of prog                       =  M1   30
    gear range 1                      not used
    gear range 2                      not used
    gear range 3                      not used
    constant contour speed            not used
    constant contour speed 2          not used
    word drill                        not used
    word break chip                   not used
    word deep                         not used
    word tap                          not used
    word bore 1                       not used
    word bore 2                       not used
    word bore 3                       not used
    word bore 4                       not used
    word bore 5                       not used
  end define
  print header               = "Delcam Postprocessor"
  machine name               = "Fanuc6m          version 1.2"
  point                      = "."
  zero                       = "0"
  tape headers               =     1
  integer   6                =     2
  integer   7                =     1
  integer  10                =     2
  integer  11                =     1
  integer  12                =     1
#  integer  12                =     0
#  integer  13                =     0
  tool reset coordinates     =     2
  cycle output               =     1
  integer  20                =     1
  block start                =     1
  block increment            =     1
  split move                 =     0
  integer  26                =     1
  program id start           =     1
  integer  34                =     3
  integer  35                =     1
  integer  36                =     1
  integer  37                =     2
  rapid feed code            =     0
  maximum block number       =     0
  maximum tape blocks        =     0
  minimum tape blocks        =     0
  segment type               =     0
  counter start              =     0
  counter increment          =     0
  tape split retract distance  =  -999
  multiaxis coordinate transform  = true
  message output             = false
#  block order                = false
  block order                = true
  tlo output                 = true
  tape split on tool change  = false
  full circle                = true
  incremental centre         = true
  go home output             = false
  use partid                 = true
  use progid                 = true
  spindle x motion           = false
  spindle y motion           = false
  spindle z motion           = true
  spindle w motion           = false
  spindle azimuth rotation   = false
  spindle elevation rotation  = false
  linearise multiaxis moves  = true
  use hole top in cycles     = false
  knot vector type           = none
  units                      = input
  coordinates                = absolute
  azimuth axis units         = none
  azimuth axis direction     = none
  elevation axis units       = none
  elevation axis direction   = none
  spline type                = none
  maximum feedrate           =  9999.0000
  minimum feedrate           =     1.0000
  rapid feedrate             =  9999.0000
  maximum tape length        =     0.0000
  maximum segment            =     0.0000
  diameter                   =     1.0000
  withdrawal amount          =    50.0000
  azimuth axis parameters    = (      0      0      0      0      0      0 )
  azimuth centre             = (      0      0      0 )
  elevation axis parameters  = (      0      0      0      0      0      0 )
  elevation centre           = (      0      0      0 )
  pcs origin                 = (      0      0      0      0      0      0 )
  linear axis limits         = ( -99999 999999 -99999 999999 -99999 999999 )
  rotary axis limits         = ( -99999 999999 -99999 999999    999      1 )
  move safe angles           = (      0      0      0      0 )
  define block tape start
    TN ToolNumber ; TL ToolLength[ToolNum] ; TD ToolRadius[ToolNum] ; TPN ToolPathName ; " )"
    TD2 ToolRadius[ToolNum] ; TipR TipRadius[ToolNum] ; " )"
    G5  90    ; G3  17 ; G1 0 ; G6 ToolComp ; G2 49 ; G4  80 ; G3  54
    M1  07
  end define
  define block tape end
#    M1  9
    M1  5
    M1  30
  end define
  define block go home preamble
  end define
  define block tool change first
  end define
  end define
  define block tool change clear
  end define
  define block go home z move
  end define
  define block go home xy move
  end define
  define block move from
  end define
  define block move circle
    G1  ; G2  ; G3  ; X   ; Y   ; Z   ; I   ; J   ; K   ; F   ; D
  end define
  define block move linear
  end define
  define block move rapid
#    S  ; M1 3
#    G1  ; G2  ; G3  ; G5  ; G6  ; X   ; Y   ; Z   ; T   ; H
    rapid ; G2 ; G3 ; G5 ; G6 ; x coord ; y coord ; z coord ; tool length ; S ; M1
  end define
  define block move cycle
    G4  ; G6  ; X   ; Y   ; Z2  ; R2  ; Q   ; Q1  ; F   ; M2
  end define
  define block move tap
    G6  ; G4  ; X   ; Y   ; Z2  ; R2  ; F   ; M1  ; M2
  end define
  define block tape segment
  end define
  define block tape split start
  end define
  define block tape split end
#    M1  9
    M1  5
    G4  80    ; G1  28    ; G6  91    ; Z   0     ; Z =C
    G4  80    ; G6  28    ; Y   0     ; Y =C
    M1  30
  end define
  define block cycle start
    S   ; M1
    G3  ; G5  ; M2
    F =C      ; G4 =C     ; Z2  ; R2  ; Q   ; Q1  ; G6  ;
  end define
  define block cycle end
    G4  80
  end define
  define block tape split move
  end define
  define block move spline
  end define
end
发表于 2004-11-10 09:54:05 | 只看该作者
雪兄您也帮帮他我加您分
但是要ok才行喔
发表于 2004-11-10 12:36:38 | 只看该作者
c850h002 wrote:
雪兄您也帮帮他我加您分
  但是要ok才行喔
老大 一言为定!~ 等改好了就多加点分给我吧!~
发表于 2004-11-10 14:57:37 | 只看该作者
简单的改了下,希望对你有帮助.
发表于 2004-11-11 08:46:29 | 只看该作者
Thanks,我本用UG,听讲PM功能很强,所以自学PM,资料太少,学起来.仲系有点困难,希望各位始终如一助一下小弟.非常感激ICAX--DELCAM和各位热心的,爱好PM的同志.SORRY,我仲有一个不情这请,吾知边位可以把自己编的SEND的例子FORME.邮箱  qiang790@163.com.越多越好.THANKS---------------告诉大家一个好消息,昨天我上机试一下(我才学一个礼拜),感觉仲可以,我自己也改了一个.
祝各位PM好友用得越来越精,多多米入袋.
发表于 2004-11-11 10:30:45 | 只看该作者
c850h002 wrote:
雪兄您也帮帮他我加您分
  但是要ok才行喔
我改了一下
发表于 2004-11-11 16:09:17 | 只看该作者
这里这场很热闹,真系一个好汉三个帮,小弟谢过了.上楼的大帅你有无几个例子比我学习学习.EMAIL:qiang790@163.com 大帅我等你的宝贝。不胜感激!!!!!!!!你会帮我吗?!大帅
GMT+8, 2025-4-15 00:35 , Processed in 0.176457 second(s), 12 queries , Gzip On, Redis On.
