查看: 16030|回复: 4
【讨论】请教家族分析问题
发表于 2004-11-23 09:06:42 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
mpi提供了自动balance-runner的功能,在相同阵列形式的产品上面是可以得到实现,但是在不同的零件之间能够实现吗?我尝试分析的2个不同零件进行平衡时,总是出现警告,说2个零件的匹配率不同,无法进行下去,请问老斑有做过同样的分析吗?在调入不同零件进入同一个项目进行多模穴分析,是怎样一个操作流程,我的做法是这样的。。调入第一个stl零件==〉+add命令再来调入第二个stl零件==〉修面(这个过程中有很多麻烦,第一个零件跟第二个零件的匹配率没办法一致)==〉设定runner,gate==〉设定材料==〉选择balance runner分析功能进行运算。。出现警告:(Allocating memory for analysis...
... finished allocating memory
Processing fusion mesh...
... finished processing fusion mesh
** WARNING ** The mesh may have problems. The match ratio is   78 %, and the
               reciprocal match ratio is   70 %.==就是这个问题,怎么解决?
Reading input data...
   File name : yy_study~1
   Reading solver parameters...
   Reading material data...
   Reading process settings...
   Reading finite element mesh...
** WARNING ** No cooling channel is specified(这个不要紧,没设定水路)
   Reading cooling data...
   NOTE: The analysis sequence does not start with a cooling analysis.
         The current flow analysis will assume constant mold temperatures.
** WARNING ** The flow analysis is continuing without using the .C2P file
Finished reading input data
Checking input data...
... finished checking input data
Optimizing memory usage...
... finished optimizing memory usage
Initializing variables...
... finished initializing variables
请问?:这样的步骤有何欠妥的地方?
发表于 2004-11-23 09:09:58 | 只看该作者
Filling Analysis
Residual Stress Analysis
has completed successfully.
Weld line/air trap analysis completed
Preparing output data...
Finished preparing output data
SYNERGY Weld-line and air trap
Execution time
   Analysis commenced at        Mon Nov 22 20:57:33 2004
   Analysis completed at        Mon Nov 22 21:04:34 2004
   CPU time used                      420.17 s
Copyright Moldflow Corporation and Moldflow Pty. Ltd. All Rights Reserved.
(C)2000 2001 2002 2003
This product may be covered by
   US patent 6,096,088 ,
   Australian Patent No. 721978 ,
and foreign patents and pending applications
Runner Balancing Analysis
Version: mpi410  (Build 03203)
Analysis commenced at        Mon Nov 22 21:04:38 2004
** ERROR 1100350 ** No balance pressure provided.===〉这里可看到没有实现balance平衡处理。。有错误发生!
发表于 2004-11-23 09:13:58 | 只看该作者
Model details :
   Mesh Type                                          = Fusion
   Match ratio                                        =   78 %===〉这个大
   Reciprocal match ratio                             =   70 %==〉这个小
   Total number of nodes                              =        3007
   Total number of injection location nodes           =           1
      The injection location node labels are:
                                                               3161
   Total number of elements                           =        6011
     Number of part elements                          =        5982
     Number of sprue/runner/gate elements             =          29
     Number of channel elements                       =           0
     Number of connector elements                     =           0
  &nbsparting plane normal                          (dx) =      0.0000
                                                 (dy) =      0.0000
                                                 (dz) =      1.0000
   Average aspect ratio of triangle elements          =      3.2814
   Maximum aspect ratio of triangle elements          =      9.9677
   Element number with maximum aspect ratio           =        3111
   Minimum aspect ratio of triangle elements          =      1.1594
   Element number with minimum aspect ratio           =        1233
   Total volume                                       =     24.8413 cm^3
     Volume filled initially                          =      0.0000 cm^3
     Volume to be filled                              =     24.8413 cm^3
      &nbspart volume to be filled                       =     21.4804 cm^3
       Sprue/runner/gate volume to be filled          =      3.3609 cm^3
   Total projected area                               =     68.3398 cm^2
发表于 2004-11-24 11:16:26 | 只看该作者
没人顶?
发表于 2004-11-28 12:22:10 | 只看该作者
FUSION网格的匹配率太低,一般不能低于85%,否则会报警,建议调整网格密度.
GMT+8, 2025-1-30 16:28 , Processed in 0.030119 second(s), 11 queries , Gzip On, Redis On.
