查看: 15639|回复: 4
求教渲染问题?关于UG NX的.
发表于 2002-11-20 10:12:08 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
我的UG NX里面的TIFF图板一片空白,没有图库的?为什么?艺术图像里面也一样,是否要设置什么参数?请高手指点,谢谢!
发表于 2002-11-20 13:21:39 | 只看该作者
有人能答吗?::?::?
发表于 2002-11-20 15:22:37 | 只看该作者
发表于 2002-11-20 15:38:36 | 只看该作者
应该是设置的问题吧:The remainder of the variables are defined in this file and are divided
#  into the following sections:
#     DISK FILES        - variables relating to *.ugf files that are used.
#     MODELING          - variables relating to modeling
#     MACHINING         - variables relating to machining products
#     CGM               - variables relating to the CGM product
#     ERROR and HELP    - variables relating to error and help files
#     USER FUNCTION     - variables relating to user function
#     MISCELLANEOUS     - miscellaneous variables used by unigraphics
#     USER EXITS        - variables relating to user exits.
#     SMD               - variables relating to sheet metal design
#     ROUTING           - variables relating to the UG/Routing product
#     GRIP BATCH        - variables relating to grip batch
#     DISPLAY DRIVERS   - variables relating to the display drivers
#     PLOTTER           - variables relating to plotter configuration.
#     TRANSLATORS       - translators & process specific applications.
#     SCENARIO          - variables relating to the SCENARIO product
#     MACHINE DEPENDENT - variables with  platform specific settings.
#  Some variables do not need to be set, the code has a default value.  These
#  variables will be commented out using the "#" sign.  If you assign a local
#  value you must uncomment the line.
发表于 2002-11-24 23:52:52 | 只看该作者
高手出手指点一下啦?盼望指教!
GMT+8, 2025-2-26 04:42 , Processed in 0.026971 second(s), 11 queries , Gzip On, Redis On.
