查看: 15634|回复: 0
3MBonding Films
发表于 2004-12-17 16:18:29 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
3MBonding Films  are thermoplastic films that reach up to 900 psi shear in seconds to speed assembly. They are reworkable.
Make a Selection:
3M[$#8482] Bonding Film 406
Flexible, light-colored, thermoplastic adhesive bonding film exhibits good adhesion to a variety of surfaces. Good solvent resistance.
3M[$#8482] Bonding Film 583
Flexible dry film that flows when heat or solvent activated to form a strong, permanent bond for nameplates and other applications. 100% solids formulation of synthetic elastomer, thermoplastic, and thermosetting resins. 2 mil thickness.
3M[$#8482] Bonding Film 588
3M[$#8482] Bonding Film 588 is composed of a higher ratio of thermosetting resins than 3M[$#8482] Bonding Film 583 for high internal strength and structural type bonds.
3M[$#8482] Bonding Film 615
Flexible, light-colored, thermoplastic adhesive bonding film. Good adhesion to a variety of surfaces, including LCP plastic.
3M[$#8482] Bonding Film 620
Three layer electronics grade bonding film consists of a 2 mil polyester film core coated both sides with 2 mils of a polyester based thermoplastic adhesive. Provides dielectric insulating layer. Good adhesion to a variety of substates.
3M[$#8482] Bonding Film 668
Electronics grade, flexible, light-colored, thermoplastic adhesive bonding film that exhibits good adhesion to a variety of substrates. The bonding film is removable from the release coated paper carrier.
3M[$#8482] Bonding Film AF42
Unsupported, thermosetting film adhesive. Designed for the structural bonding of metals and glass.
3M[$#8482] Bonding Film AF111
Developed for structural bonding of metals, high-strength plastic laminates (epoxy and phenolic) and honeycomb sandwich
assemblies. Features: Heat-curing film adhesive with 250 Degree F curing cycle. Bonds metal to metal and metal to honeycomb.
3M[$#8482] Thermo-Bond Film 557 and 557EG
3M[$#8482] Thermo-Bond Films 557 and 557EG are flexible, light colored thermoplastic adhesive bonding films which exhibit good adhesion to a variety of substrates, especially many plastics.
GMT+8, 2025-4-23 16:58 , Processed in 0.019288 second(s), 11 queries , Gzip On, Redis On.
