查看: 16702|回复: 7
【求助】关于曲面“join"
发表于 2004-12-21 23:53:02 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
关于里面的选项 federation不知道怎么回事,起到什么效果,希望老大指点
如图
发表于 2004-12-22 07:51:54 | 只看该作者
顶!我搞不清楚!!
发表于 2004-12-22 21:14:25 | 只看该作者
顶,怎么沉拉,都不晓得?8可能啊
发表于 2004-12-28 22:04:44 | 只看该作者
我也顶一下!
想了好久也不大清楚其作用如何
纳闷阿
发表于 2004-12-28 23:20:23 | 只看该作者
发表于 2004-12-29 13:29:20 | 只看该作者
发表于 2009-12-10 21:38:43 | 只看该作者
我也非常希望搞懂,很难理解!高手们请教!
发表于 2009-12-10 22:28:21 | 只看该作者
总算弄懂了:
其实就是为了在以后(不管是JOINT还是EXTRACT之后),选择那些曲面或曲线会很方便的。比如:在joint了多个元素并用FEDERATION其中几个元素后,则只要选择federation中的其中一个元素,其余的都会选上。看看下面的英文介绍,虽然没有图(抱歉),但是应该能理解。
Federation is grouping elements like surfaces and curves in a Join for easy picking of surfaces/curve later. Federation can be found in “Join” and “Extract” command in CATIA V5 GSD(Generative Shape Design) Workbench. This is useful grouping feature. We shall explain you what is it and how to use it.
Consider a set of simple surfaces as shown in the image below. The Geometrical set consists of 4 surfaces.
Surface 1, Surface 2, Surface 3 and Surface 4 is included in ‘Join.1’. In the Federation tab of join command we have added Surface 4 and Surface 3 as shown in the image below.
Join.1 with ‘F’ is reflected in the Join command icon in the model tree.
For comparison, we have created a simple ‘Join.2’ without Federation. ‘Join.2’ is join of Surface 1, Surface 2, Surface 3 and Surface 4.
‘Extract’ command on ‘Join.2’ gives 4 elements selection (refer image below).
Where as ‘Extract’ on ‘Join.1’ gives only 3 elements. That’s because Join.1 involves Federation of two surfaces. Those two surfaces are grouped together.
This way in a complex geometry you can group several surfaces and involve it in a Federation. Later selecting of those surfaces is very simple and will happen in a single click.
GMT+8, 2025-4-16 12:54 , Processed in 0.023134 second(s), 13 queries , Gzip On, Redis On.
