查看: 19664|回复: 2
【求助】ansys中的shell63变厚度网格划分
发表于 2005-1-5 22:11:55 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
请教下面程序中的 NDINQR(0,14)是什么意思?
/TITLE,RTHICK Example
/PREP7
ET,1,63
RECT,,10,,10
ESHAPE,2
ESIZE,,20
AMESH,1
EPLO
MXNODE = NDINQR(0,14)
*DIM,THICK,,MXNODE
*DO,NODE,1,MXNODE
    *IF,NDINQR(NODE,1),EQ,1,THEN
       THICK(node) = 0.5 + 0.2*NX(NODE) + 0.02*NY(NODE)**2
    *ELSE
       THICK(NODE) = 0
    *ENDIF
*ENDDO
在ansys help里没有找到,唉
发表于 2005-1-6 13:26:08 | 只看该作者
这是查询函数,我转贴一下
ansys查询函数大全
Here is just about everything I know about inquiry functions. They are similar to *GET functions in usage, and have two input arguments. Here's an example.
a=ndinqr(33,1)
In this case, "a" will be assigned a value of -1 if node 33 is unselected, 0 if it is undefined, and 1 if it is selected. This is an example of using an inquiry function to obtain information about a specific entity, in this case node 33.
An alternative use of an inquiry function is to find more generic data about a certain kind of entities. The following example illustrates this.
a=ndinqr(0,14)
This will assign to parameter "a" the highest node number defined in the model. Notice that the first argument is zero, and the second argument is 14.
Here are the inquiry functions I am aware of.
ndinqr(node,key) node number or zero, and key number
elmiqr(elem,key)
kpinqr(keypoint,key)
lsinqr(line,key)
arinqr(area,key)
vlinqr(volume,key)
rlinqr(real,key)
gapiqr(gap element,key)
masiqr(master DOF,key)
ceinqr(constraint equation,key)
cpinqr(coupled set,key)
csyiqr(coord system,key)
etyiqr(element type,key)
foriqr(nodal force,key)
All of these work pretty much the same, with the first argument used as either an entity ID number (for data about a specific node, element, etc.) or a zero if the information is about a class of element (number of selected nodes, etc.)
The key numbers are defined as follows.
key=1 return select status (for a specific entity)
key=12 return number of defined entities (KP's, nodes, etc.)
key=13 return number of selected entities
key=14 return the highest ID number in use
There a few other inquiry functions which have a slightly different format.
mpinqr(mat,prop,key) material property table number, property number, key additional key=3 for number of temps used in a specific property
dget(node,idof,kcmplx) node number, displacement pointer, complex key displacement pointers are...
1=ux, 2=uy, 3=uz, 4=rotx, 5=roty, 6=rotz, 7=ax, 8=ay 9=az, 10=vx, 11=vy, 12=vz, 19=pres, 20=temp, 21=volt, 22=mag, 23=enke, 24=ends, 25=emf, 26=curr
complex key=0 for real, 1 for imaginary
fget(node,idof,kcomplx) same definition as dget, but for forces this time.
 &nbsposted by John Crawford on 10.28.1997
Additional Inquiry Function
  Some time ago I dug out one additional Key:
NUMS value for the entity:
ndinqr(0,25)
elmiqr(0,25)
kpinqr(0,25)
lsinqr(0,25)
arinqr(0,25)
vlinqr(0,25)
It is sometimes handy for use in macros.
 &nbsposted by Juha Tyllinen on 10.28.1999
Inquiry Functions for Sections
  I have looked at the code and can confirm Tyllinen Juha's observation. It will work in 5.5, 5.6, and not likely to change.
"Quick testing seems to indicate that Section number would be available with sn = elmiqr(n,-4), where n is the element number. At least that is the way it worked in 5.5.1 with Beam188 and Beam189."
Other possibilites for element characteristics
-1, material number
-2, element type
-3, real constant number
-4, Element Section ID number
-5, coordinate system number
 &nbsposted by Grama Bhashyam on 10.29.1999
Useful Inquiry Functions
  Nodes ndinqr(node,key)
  node - node number, should be 0 for key = 12, 13, 14
  key - information needed
    = 1, return select status:
    = 12, return number of defined nodes
    = 13, return number of selected nodes
    = 14, return highest node number defined
    = -2, superelement flag
    = -3, master degrees of freedom bit pattern
    = -4, active degrees of freedom bit pattern
    = -5, solid model attachment
    = -6, pack nodal line parametric value
  output arguments:
  for key = 1
    = 0, node is undefined.
   = -1, node is unselected.
   = 1, node is selected.
Element elmiqr(ielem,key)
  ielem - element number, should be zero for key = 12, 13, or 14
  key - information flag
   = 12, return number of defined elements
    = 13, return number of selected elements
    = 14, return maximum element number used
    = -1, material number
    = -2, type.
   = -3, real.
    = 4, element section ID number
    = 5, coordinate system number
    = 7, solid model reference
  output arguments:
  for key = 1
    = 0, element is undefined
    = -1, element is unselected
    = 1, element is selected
Keypoints kpinqr(kpid,key)
  kpid - keypoint may be 0 for key = 12, 13, 14
  key - information flag.
    = 1, select
    = 12, number of defined
    = 13, number of selected
    = 14, highest number defined
    = -2, type
    = -3, real number
    = -4, node number, if meshed
    = -7, element number, if meshed
  output arguments:
  for key = 1
    = -1, unselected
    = 0, undefined
    = 1, selected
Lines lsinqr(lsid,key)
  lsid - line segment for inquire may be 0 for key = 12, 13, 14
  key - item to be returned
    = 1, select status
    = 2, length (in model units)
    = 12 number of defined
    = -2, type
    = -3, real number
    = -4, number of nodes
    = -5, esys number
    = -6, number of elements
    = -8, number of element divs in existing mesh
    = -9, keypoint 1
    = -10, keypoint 2
    = -15, section id
    = -16, number of element divs for next mesh
    = -17, 0 = hard / 1 = soft NDIV
    = -18, 0 = hard / 1 = soft SPACE
Area arinqr(areaid,key)
  areaid - area for inquiry, may be 0 for key = 12, 13, 14
  key - key to information needed about the areaid
    = 14, return highest number defined
    = -1, return material
    = -2, return type
    = -3, return real
    = -4, return number of nodes
    = -6, return number of elements
    = -7, return pointer to area in foreign db
    = -8, return element shape
    = -9, return mid-node element key
    = -10, return element coordinate system
    = -11, return area constraint information
  output arguments:
  for key = 1
    = 0, areaid is undefined
    = -1, areaid is unselected
    = 1, areaid is selected
  for key = - 11
    = 0, no constraint on this area
    = 1, symmetry constraint
    = 2, anti-symmetry
    = 3, both symmetry and anti-symmetry
Volumes vlinqr(vnmi,key)
  vnmi - volume for inquiry, may be 0 for key = 12, 13, 14
    = -1, material
    = -2, type
    = -3, real
    = -8, element shape
    = -9, mid-node element key
    = -10, element coordinate system
  output arguments:
  for key = 1
    = 0, real constant table is undefined.
    = -1, real constant table is unselected.
    = 1, real constant table is selected
Element Type etyiqr(itype,key)
  itype - element type number, should be 0 for key = 12 and 14
    = 12, return number of defined element types
    = 14, return highest element type number defined
  output arguments:
  for key = 1
    = 0, element type is undefined
    = -1, element type is unselected
    = 1, element type is selected
Real Constants rlinqr(nreal,key)
  nreal - real constant table number, should be 0 for key = 12, 13, 14
    = 1, select status
    = 12, number of defined real constant tables
    = 13, number of selected real constant tables
    = 14, highest real constant table defined
  output arguments:
  for key = 1
Section Table sectinqr(nsect,key)
  nsect - section id table number, should be 0 for key = 12, 13, 14
    = 1, select status
    = 12, return number of defined section id tables
    = 13, return number of selected section id tables
    = 14, return highest section id table defined
  output arguments:
  for key = 1
    = 0, section id table is undefined.
    = -1, section id table is unselected.
    = 1, section id table is selected
Materials mpinqr(mat,iprop,key)
  mat - material number, should be 0 for key = 12 and 14
  iprop - property reference number
  iprop = 0, test for existence of any material property with this material number (with key = 1)
  key - key as to the information needed about material property
    = 12, number of defined material properties
    = 14, highest material property number defined
  output arguments:
  for key = 1, iprop = 0 (test for existence of any material property with this material number)
    EX = 1, EY = 2, EZ = 3, NUXY = 4, NUYZ = 5, NUXZ = 6, GXY = 7, GYZ = 8, GXZ = 9, ALPX = 10, ALPY = 11, ALPZ = 12, DENS = 13, MU =14, DAMP = 15, KXX = 16, KYY = 17, KZZ = 18, RSVX = 19, RSVY = 20, RSVZ = 21, C = 22, HF =23, VISC = 24, EMIS = 25, ENTH = 26, LSST = 27, PRXY = 28, PRYZ = 29, PRXZ = 30, MURX = 31, MURY = 32, MURZ = 33, PERX = 34, PERY = 35, PERZ = 36, MGXX = 37, MGYY = 38, MGZZ = 39, EGXX = 40, EGYY = 41, EGZZ = 42, TGXX = 43, TGYY = 44, TGZZ = 45, SONC = 46, SLIM = 47, ELIM = 48, ORTH = 54, CABL = 55, RIGI = 56, HGLS = 57, BM = 58, QRAT = 59, REFT = 60, PLAS = 61, CREE = 62, FAIL = 63, BH = 64, PIEZ = 65, SWEL = 66, WATE = 67, CONC = 68, PFLO = 69, ANEL = 70, ACOU = 71, EVIS = 72, USER = 73, NL = 74, HYPE = 75, NNEW = 76, MOON = 77, OGDE = 78, SUTH = 79, WIND = 80
  for key = 1 (otherwise)
    = 0, material prop is undefined
    = 1, material prop is selected
Constraint Equations ceinqr(ceid,key)
  ceid - constraint equation number
  key - inquiry key, should be zero for key = 12, 13, 14
    = 1, equation is selected
    = 0, equation is undefined
    = -1, equation is unselected
    = 12, return number of defined constraint equations
    = 13, return number of selected constraint equations
    = 14, return number of highest numbered constraint equation defined
    = -1, return master degrees of freedom for this equation
Couples cpinqr(cpid,key)
  cpid - coupled set number
    = 12, return number of defined coupled sets
   = 13, return number of selected coupled sets
   = 14, return the number of the highest numbered coupled set
  output arguments:
  for key = 1
    = 1, coupled set is selected
    = 0, coupled set in undefined
    = -1, coupled set in unseleted
Coordinate System csyiqr(csysid,key)
  csysid - coordinate system reference number, should be zero for key = 12 or 14
    = 1, return status:
   = 12, number of defined coordinate systems
    = 14, maximum coordinate system reference number used.
  output arguments:
  for key = 1
    = 0, coordinate system is not defined
    = -1, coordinate system is not selected
    = 1, coordinate system is selected
Warning and Error Messages erinqr(key)
    = 3, total number of notes displayed
    = 4, total number of warnings displayed
    = 5, total number of errors displayed
    = 6, total number of fatals displayed
发表于 2005-1-6 16:08:36 | 只看该作者
斑竹真是高人,谢谢了!!
GMT+8, 2025-4-21 02:22 , Processed in 0.023042 second(s), 12 queries , Gzip On, Redis On.
