查看: 23475|回复: 9
关于ModelCHECK
发表于 2002-11-26 12:11:46 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
在PRO/E的HELP中有如下定义,但看了以后不是很清楚,也不知怎么用,有用过的兄弟吗?进来讲讲!::y
发表于 2002-11-26 15:02:12 | 只看该作者
我顶,没人有兴趣吗?
发表于 2002-11-26 16:00:05 | 只看该作者
给点英文资料跟你看一下:
英文好一点的帮我翻译一下:
Check Out ModelCHECK
ModelCHECK, a quality control add-on to Pro/ENGINEER[$reg], helps you build parts, drawings, and assemblies according to company standards and best practices. This consistency, in turn, ensures that your models can be reused downstream in design, analysis or manufacturing applications. This web-based tool not only highlights problems in your model, but also guides you through the repair. In the process, ModelCHECK helps build your skills and proficiency with Pro/ENGINEER.
What kinds of things does ModelCHECK investigate?
PTC has steadily added new functionality to ModelCHECK[$reg] over the past several years. Today, this product checks the quality of Pro/ENGINEER models in three basic areas:
1.  Conformity to company standards and use of proper modeling techniques
2.  Manufacturability and quality of the geometry
3.  Detection of similar designs.
Because of the gap between these two surfaces, this part cannot be made into a solid. A wavy surface cannot be milled. How does it work? When you run ModelCHECK, it displays any problems in your parts, assemblies, or drawings in your web browser. From this report, you can either highlight or fix the problem following the online modeling advice (Fig. 1). For added efficiency, you can run this tool in batch mode, enabling you to report and fix a large number of models simultaneously.
发表于 2002-11-26 16:01:01 | 只看该作者
发表于 2002-11-26 16:01:28 | 只看该作者
hat are some of the specific productivity gains from using ModelCHECK?
Everyone agrees that it’s easier to work with models that are built properly and conform to a certain standard. To this end, companies are currently using ModelCHECK to:
·  Ensure that models built by suppliers or contractors are acceptable
·  Verify that models are error-free and ready for release to Pro/INTRALINK[$reg]
·  Automatically fix large quantities of models
·  Reduce the number of design changes required in order to manufacture a model
· &nbsprevent users from recreating models that already exist.
Last year, you added something called “Shape Indexing.” What does this do exactly?
When ModelCHECK runs on a part, it analyzes a series of shape attributes in the current model and compares them to those in all other previously created models. ModelCHECK stores the attributes for the different models in a separate file, making search times extremely fast (100,000 models in 3 seconds). Since our customers tell us that duplicate models are such a serious problem, we are aggressively working to add new functionality to the Shape Indexing component, such as:
·  Storing the shape attributes in Pro/INTRALINK
·  Integrating Fast Preview technology into ModelCHECK to allow users to visualize similar models before retrieving them into Pro/ENGINEER
·  Integrating Shape Indexing into Windchill and PartsLink to enable enterprise-wide searches.
What’s new in ModelCHECK 2001?
We’ve added 46 new checks this year—more than in any past release of the product. Perhaps the most important addition is GeomIntegrityCHECK. This new feature allows you to check for problems that will make it difficult to manufacture or to translate the model between CAD systems. GeomIntegrityCHECK is written to comply with the German VDA 4955 V2 standard. Some of the other new additions are checks for small elements, identical elements, surface and curve continuity, and edge alignment.
What other enhancements is PTC planning in the near future?
PTC is working diligently on making ModelCHECK easier to set up and use. We will be introducing new user interfaces and configuration wizards over the next few releases. A prime example is the configuration program written for GeomIntegrity-CHECK
发表于 2002-11-26 16:08:24 | 只看该作者
孤独剑 wrote:
有人知道吗,图上的MODELCHECK REPORT是怎么做出来的.
发表于 2002-11-26 16:16:04 | 只看该作者
哈哈!!
没时间给大家翻译呀!!
发表于 2010-12-27 10:37:52 | 只看该作者
孤独剑 发表于 2002-11-26 16:00
给点英文资料跟你看一下:
英文好一点的帮我翻译一下:
ModelCHECK, a quality control add-on to Pro/ENGINEER[$reg], helps you build parts, drawings, and assemblies according ...
modelcheck, 一个于pro/e上的质量控制组件,旨在帮助你依据公司标准规则和最好工程实践规则来创建零件、工程图和组件。这些符合性,依次来确保你的模型能够被下游设计、分析和制造应用程序所重复利用。它是个基于web的工具,不仅是加亮模型中的问题,而且能够指导你顺利的修复模型。在这些过程中,modelcheck帮助提升和熟练掌握pro/e技能。
哪种东西是modelcheck所要检查研究的?
PTC在过去的数年里,稳步的增加modelcheck的新功能。现在,这个产品检查在三维环境中的pro/e模型的质量,包括:
1,是否符合公司标准并使用合适的建模技术
2,检查制造和几何质量
3,类似的设计检测
因为在这两个面片上有裂口,这个零件不能构成实体。起伏的表面不能铣削成型。该如何办?当你启动modelcheck, 它能在web浏览器中显示你的零件、组件和绘图中的任何问题。从这个报告中,你可以根据在线建模方法意见加亮和修正这些问题。为能增加效率,你可以在批处理模式下运行这个工具,使你同时报告和修复一个大模型。
这介绍等于白说
发表于 2010-12-27 11:34:28 | 只看该作者
这个modelcheck还真没有用过,也请高手指点一下使用方法
发表于 2013-11-30 22:51:30 | 只看该作者
还是有许多东西要你学习的
GMT+8, 2025-3-5 09:19 , Processed in 0.048380 second(s), 11 queries , Gzip On, Redis On.
