查看: 16761|回复: 14
cimatron问题2
发表于 2005-2-5 11:08:41 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
钻孔
发表于 2005-2-5 11:09:38 | 只看该作者
参数
发表于 2005-2-5 11:12:01 | 只看该作者
处理出来的程式:
  O0100
  T01
  G90 G80 G00 G17 G40 M23
  G43 H01 Z50. S1000 M03
  G98 G81 X-50. Y0.0 Z-60. R-49. F350 M09
  G99 X0.0 Z-10. R1.
  G80 Z-40.
  M30
发表于 2005-2-5 11:13:36 | 只看该作者
好象是这里有问题:
CYCLE: ON:
       FlagSpin = NO ;
       IF_SET (SPIN_SPEED) FlagSpin = YES ; END_IF ;
       IF_SET (SPIN_DIR)   FlagSpin = YES ; END_IF ;
       IF_SET (FlagSpin _EQ_ YES)
    SET_ON SPIN_SPEED SPIN_DIR ;
    OUTPUT $ " S" SPIN_SPEED " " SPIN_DIR ;
       END_IF ;
       SET_ON X_CURPOS Y_CURPOS Z_CURPOS   ;
       SET_ON CYC_DEPTH CYC_RETR CYC_CLEAR MCH_FEED MCH_COOL ;
       SET_ON Zinit Depth Clear ;
       Zinit    = Z_CURPOS + CYC_DZINIT ;
       Depth    = Z_CURPOS - CYC_DEPTH ;
       Clear    = Z_CURPOS + CYC_CLEAR ;
       IF_SET (Zold _LT_ Zinit) OUTPUT $ " Z" Zinit ; END_IF ;
        OUTPUT $ ;
        OUTPUT " "  CYC_RETR ;
        OUTPUT " "  CYC_CODE ;
        OUTPUT " X" X_CURPOS ;
        OUTPUT " Y" Y_CURPOS ;
        OUTPUT " Z" Depth    ;
        OUTPUT " R" Clear ;
       IF_SET (CYC_PECK)  OUTPUT " Q" CYC_PECK  ; END_IF ;
       IF_SET (CYC_DWELL) OUTPUT " P" CYC_DWELL ; END_IF ;
       IF_SET (CYC_XSHFT) OUTPUT " I" CYC_XSHFT ; END_IF ;
       IF_SET (CYC_YSHFT) OUTPUT " J" CYC_YSHFT ; END_IF ;
        OUTPUT " F" MCH_FEED ;
        OUTPUT " "  MCH_COOL ;
       SET_ON  LIN_MOV CIRC_MOV ;
       SET_OFF CYC_DEPTH CYC_CLEAR;
       Xold = X_CURPOS ;
       Yold = Y_CURPOS ;
       Zold = Z_CURPOS ;
CYCLE:
       OUTPUT $ ;
       IF_SET (CYC_RETR)   OUTPUT " "  CYC_RETR   ; END_IF ;
       IF_SET (X_CURPOS)   OUTPUT " X" X_CURPOS   ; END_IF ;
       IF_SET (Y_CURPOS)   OUTPUT " Y" Y_CURPOS   ; END_IF ;
       IF_SET (Depth)      OUTPUT " Z" Depth      ; END_IF ;
       IF_SET (Clear)      OUTPUT " R" Clear      ; END_IF ;
       IF_SET (SPIN_SPEED) OUTPUT " S" SPIN_SPEED ; END_IF ;
       IF_SET (SPIN_DIR)   OUTPUT " "  SPIN_DIR   ; END_IF ;
       IF_SET (MCH_FEED)   OUTPUT " F" MCH_FEED   ; END_IF ;
       IF_SET (MCH_COOL)   OUTPUT " "  MCH_COOL   ; END_IF ;
       Xold = X_CURPOS ;
       Yold = Y_CURPOS ;
       Zold = Z_CURPOS ;
CYCLE: OFF:
       OUTPUT $ " G80 Z" Zinit ;
       Zold = Zinit ;
发表于 2005-2-5 11:21:41 | 只看该作者
用DEMO或用DEMO改的POST的朋友请小心。
发表于 2005-2-9 17:21:45 | 只看该作者
不会吧,这贴子居然没人顶。
发表于 2005-2-15 12:06:13 | 只看该作者
我自个顶
发表于 2005-2-17 18:14:05 | 只看该作者
顶,
等大侠。
发表于 2005-2-17 18:36:26 | 只看该作者
将那里改成G28 Z0就没事了!
发表于 2005-2-17 21:17:40 | 只看该作者
dearbabyer,你好!
    如果说是后处理后改,只适合几个孔的。当孔有几十个时,就没法改了。
    另外G99的问题没有解决。
    我认为应改后处理程序。
GMT+8, 2025-2-21 03:39 , Processed in 0.041988 second(s), 11 queries , Gzip On, Redis On.
