查看: 15919|回复: 10
问2个问题
发表于 2005-2-18 20:20:19 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
1,2001草绘里的RELATION在野火里怎么找不到啊
藏在哪了
发表于 2005-2-18 20:25:28 | 只看该作者
spinal blend是什么的命令,哪位高手可以指点啊,解释一下
发表于 2005-2-18 20:38:20 | 只看该作者
ttyt
发表于 2005-2-18 20:54:41 | 只看该作者
谢谢,第2个问题呢
发表于 2005-2-18 21:17:22 | 只看该作者
dfg
发表于 2005-2-18 21:17:54 | 只看该作者
PRO/E部分命令对照LIST (PRO/E 2001_to_wf2)
资料来源:https://www.ptc.com/community/proewf2/menu_mapper/en/index.htm
part
Wildfire 2.0 : Edit > Solidify
2001 : Feature > Create > Solid > Cut > Use Quilt > Solid
Wildfire 2.0 : Edit > Thicken
2001 : Feature > Create > Solid > Cut > Use Quilt > Thin
Wildfire 2.0 : Insert > Hole
2001 : Feature > Create > Solid > Hole
Wildfire 2.0 : Insert > Variable Section Sweep
2001 : Feature > Create > Solid > Cut > Advanced > Solid > Var Sec Swp
2001 : Feature > Create > Solid > Protrusion > Use Quilt > Solid
2001 : Feature > Create > Solid > Protrusion > Use Quilt > Thin
2001 : Feature > Create > Solid > Protrusion > Advanced > Solid > Var Sec Swp
Wildfire 2.0 : Insert > Advanced > Radius Dome...
2001 : Feature > Create > Solid > Tweak > Radius Dome
Wildfire 2.0 : Edit > Offset
2001 : Feature > Create > Solid > Tweak > Offset
Wildfire 2.0 : Edit > Offset > Replace Surface Feature
2001 : Feature > Create > Solid > Tweak > Replace
Wildfire 2.0 : Insert > Advance > Ear...
2001 : Feature > Create > Solid > Tweak > Ear
Wildfire 2.0 : Insert > Advanced > Toroidal Bend
2001 : Feature > Create > Solid > Tweak > Toroidal Bend
Wildfire 2.0 : Insert > Advanced > Spinal Bend
2001 : Feature > Create > Solid > Tweak > Spinal Bend
Wildfire 2.0 : Insert > Advanced > Bend Solid
2001 : Feature > Create > Solid > Tweak > Solid Bend
Wildfire 2.0 : Insert > Advanced > Flatten Quilt
2001 : Feature > Create > Solid > Tweak > Flatten Quilt
Wildfire 2.0 : Insert > Sweep > Surface
2001 : Feature > Create > Surface > New > Sweep
Wildfire 2.0 : Insert > Blend > Surface
2001 : Feature > Create > Surface > New > Blend
Wildfire 2.0 : Edit > Fill
2001 : Feature > Create > Surface > New > Flat
2001 : Feature > Create > Surface > New > Offset
Wildfire 2.0 : Edit > Copy, Edit > Paste
2001 : Feature > Create > Surface > New > Copy
2001 : Feature > Create > Surface > New > Copy by Trim
Wildfire 2.0 : Insert > Round
2001 : Feature > Create > Surface > New > Fillet
Wildfire 2.0 : Insert > Swept Blend > Surface
2001 : Feature > Create > Surface > New > Advanced > Swept Blend
Wildfire 2.0 : Edit > Merge
2001 : Feature > Create > Surface > Merge
Wildfire 2.0 : Insert > Extrude
2001 : Feature > Create > Surface > Trim > Extrude > Solid
Wildfire 2.0 : Insert > Sweep > Surface Trim
2001 : Feature > Create > Surface > Trim > Sweep > Solid
Wildfire 2.0 : Edit > Trim
2001 : Feature > Create > Surface > Trim > Use Quilt > Solid
2001 : Feature > Create > Surface > Trim > Use Curves
Wildfire 2.0 : Insert > Advanced > Silhouette Trim
2001 : Feature > Create > Surface > Trim > Vertex Round
2001 : Feature > Create > Surface > Trim > Silhouette
2001 : Feature > Create > Surface > Trim > Advanced > Solid > Var Sec Swp
Wildfire 2.0 : Edit > Extend
2001 : Feature > Create > Surface > Extend
Wildfire 2.0 : Edit > Copy, Edit > Paste Special
2001 : Feature > Create > Surface > Transform > Move
Wildfire 2.0 : Edit > Mirror
2001 : Feature > Create > Surface > Transform > Mirror
Wildfire 2.0 : Edit > Flip Normal...
2001 : Feature > Create > Surface > Transform > Flip Normal
Wildfire 2.0 : Insert > Draft
2001 : Feature > Create > Surface > Draft
2001 : Feature > Create > Surface > Area Offset
2001 : Feature > Create > Surface > Draft Offset
Wildfire 2.0 : Insert > Shared Data > Copy Geometry from Other Model
2001 : Feature > Create > Data Sharing > Ext Copy Geom
Wildfire 2.0 : Insert > Shared Data > Merge from Other Model
2001 : Feature > Create > Data Sharing > Ext Merge
Wildfire 2.0 : Insert > Shared Data > Cutout from Other Model
2001 : Feature > Create > Data Sharing > Ext Cutout
Wildfire 2.0 : Edit > Feature Operations > Copy
2001 : Feature > Copy
Wildfire 2.0 : Edit > Feature Operations > Group
2001 : Feature > Group
Wildfire 2.0 : Edit > Resume
2001 : Feature > Resume
Wildfire 2.0 : Edit > Read Only
2001 : Feature > Read Only
Wildfire 2.0 : Select the Part name in the Model Tree > Edit > Mirror
2001 : Feature > Mirror Geom
Wildfire 2.0 : Edit > Value
2001 : Modify > Value
Wildfire 2.0 : Edit > Properties
2001 : Modify > Dimension
Wildfire 2.0 : View > View Manager > Simp Rep > New
2001 : Simplfd Rep > Create
Wildfire 2.0 : Edit > Regenerate
2001 : Regenerate
Wildfire 2.0 : Tools > Relations
2001 : Relations
Wildfire 2.0 : Edit > Setup > Units
2001 : Set Up > Units
2001 : X-section
Assembly
Wildfire 2.0 : Insert > Component > Assemble
2001 : Component > Assemble
Wildfire 2.0 : Insert > Component > Create
2001 : Component > Create
Wildfire 2.0 : Edit > Definition
2001 : Component > Redefine
Wildfire 2.0 : Edit > Replace
2001 : Component > Adv Utils > Replace
Wildfire 2.0 : Edit > Component Operations > Merge
2001 : Component > Adv Utils > Merge
Wildfire 2.0 : Edit > Component Operations > Cut Out
2001 : Component > Adv Utils > Cut Out
Wildfire 2.0 : Insert > Component > Include
2001 : Component > Adv Utils > Include
Wildfire 2.0 : Edit > Component Operations > Group
2001 : Component > Adv Utils > Group
Wildfire 2.0 : Edit > Activate
2001 : Modify > Mod Part
2001 : Simplfd Rep
Wildfire 2.0 : View > View Manager > Explode
2001 : Explode State
Drawing
Wildfire 2.0 : Insert > Drawing View
2001 : View > Add View
In Pro/ENGINEER Wildfire 2.0, all Drawing View related menu managers have been consolidated into a new, easy to use dialog that gives you visual feedback while you are defining or modifying drawing views. As you advance from section to section, the view on the drawing sheet updates to your latest change. The Drawing View dialog is activated when a new drawing view is created or when an existing drawing view is modified.
Wildfire 2.0 : Click on View and Drag [RMB > Make sure Lock View Movement is unchecked]
2001 : View > Move View
Wildfire 2.0 : Edit > Properties or Double Click a View
2001 : View > Modify View
Wildfire 2.0 : Edit > Delete
2001 : View > Delete View
Wildfire 2.0 : Edit > Group > Relate to View
2001 : View > Relate View
Wildfire 2.0 : Edit > Properties > View Display section of Drawing View dialog
2001 : View > Disp Mode > View Disp
Wildfire 2.0 : View > Drawing Display > Edge Display
2001 : View > Disp Mode > Edge Disp
Wildfire 2.0 : View > Drawing Display > Component Display
2001 : View > Disp Mode > Member Disp
Wildfire 2.0 : File > Properties > Drawing Models
2001 : View > Dwg Models
Wildfire 2.0 : File > Properties > Drawing Options
2001 : Advanced > Draw Setup
发表于 2005-2-18 22:17:20 | 只看该作者
兄弟真的很是感谢啊
我要好好研究
发表于 2005-2-18 22:28:37 | 只看该作者
   请问一下:以前2001装配时有一个选项“重复”,在“wildfire2.0”里隐藏到哪里去了?谢谢——
发表于 2005-2-18 23:39:30 | 只看该作者
谢谢!收藏了!
发表于 2005-3-13 21:20:07 | 只看该作者
能否举例
GMT+8, 2025-2-28 12:52 , Processed in 0.029631 second(s), 12 queries , Gzip On, Redis On.
