查看: 16856|回复: 2
急急!!!大虾们过来看看吧!
发表于 2002-11-30 12:42:48 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
::6大虾们过来看看下面的内容吧!
具体参数是什么意思?怎么设置?小弟在此先谢了!
This file may be edited using available editor.Just type on the necessary lines appropriate values after the"="sign.Comments are not permitted on lines containing material properties names.
YOUNG-MODULUS=
POISSON- RATIO=
SHEAR-MODULUS=
MASS-DENSITY=
THERMAL-EXPANSION-COEFFICIENT=
THERMAL-EXPANSION-REF-TEMPERATURE=
STRUCTURAL-DAMLING-COEFFICIENT=
STRESS-LIMIT-FOR-TENSION=
STRESS-LIMIT-FOR-COMPRESSION=
STRESS-LIMIT-FOR-SHEAR=
THERMAL-CONCLUCTIVITY=
EMISSIUITY=
SPECIFIC-HEAT=
HARDNESS=
CONDITION=
INITIAL-BEND-Y-FACTOR=
BEND-TABLE=
PRO-UNIT-MASS=
PRO-UNIT-LENGTH=
PRO-UNIT-SYS=
发表于 2002-12-2 04:33:00 | 只看该作者
proe自带有铝、铜、钢、钛的设置.可能单位是英制的.可在proe安装文件夹中查找*.mat文件.?:\proe2001\jlink\jlink_appls\jlink_elev
这里只说一说我知道的:
STRESS-LIMIT-FOR-TENSION= 抗拉强度
STRESS-LIMIT-FOR-COMPRESSION= 抗压强度
STRESS-LIMIT-FOR-SHEAR= 抗剪强度
HARDNESS= 硬度
BEND-TABLE= 折弯表,用于扳金折弯或扭曲中的几个折弯的中性层位置控制.
这些参数可用于定义关系尺寸,例如压力容器的壁厚.
        MATERIAL  ST1020
after the "=" sign. Comments are not permitted on
YOUNG_MODULUS                    =     30E6
POISSON_RATIO                    =     0.29
SHEAR_MODULUS                    =     12E6
MASS_DENSITY                     =     489.84
THERMAL_EXPANSION_COEFFICIENT    =     8.4E-6
THERM_EXPANSION_REF_TEMPERATURE  =     60
STRUCTURAL_DAMPING_COEFFICIENT   =     0.22
STRESS_LIMIT_FOR_TENSION         =     65E3
STRESS_LIMIT_FOR_COMPRESSION     =     65E3
STRESS_LIMIT_FOR_SHEAR           =     19E3
THERMAL_CONDUCTIVITY             =     27
EMISSIVITY                       =     0.45
SPECIFIC_HEAT                    =     0.10
HARDNESS                         =     150
CONDITION                        =     N/A
INITIAL_BEND_Y_FACTOR            =     0.2
BEND_TABLE                       =     tableSt1020
PRO_UNIT_MASS                    =
PRO_UNIT_LENGTH                  =
PRO_UNIT_SYS                     =
发表于 2002-12-8 11:43:07 | 只看该作者
谢了!!楼上的兄弟
GMT+8, 2025-4-23 03:51 , Processed in 0.095519 second(s), 12 queries , Gzip On, Redis On.
