查看: 17285|回复: 4
【求助】关于Help的问题:
发表于 2002-3-4 16:23:59 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
最近想装alias的help,但拷贝到相应位置并且设置好参数后,从Help/online docs菜单中可以调出help,但在对话框中无法通过有上角的问号调出于该对话框相关的help章节,不知何故?请指教。
发表于 2002-3-4 17:59:36 | 只看该作者
说真的 我9.7也没装成功过
少了HELP ON FUNCTION 有点不便
不过对指令有一定了解
大概知道哪里找的到而已…. 有没有朋友装成功过啊
发表于 2002-3-4 21:59:25 | 只看该作者
两位老兄试试看吧。
Installing the online documentation
The StudioTools online documentation is not installed on your system. In order to view the online documentation you must first install it using the following procedure.
Before you begin this procedure, make sure you have read it entirely. You may also want to print it out.
For more information on installing the online documentation, contact your system administrator or refer to the Installation Guide on the StudioTools Documentation CD.
To install the online documentation
1     Exit StudioTools if it is currently running.
2     Insert the StudioTools Documentation CD-ROM into your CD-ROM drive.
3     Copy the Help, Pdf, and movies directories from the StudioTools Documentation CD to either your system’s hard drive or to any system’s hard drive that you can access via a network or web server. All directories must be saved to the same level.
However, if your organziation has StudioTools installed on several systems, you may want to install the online documentation on a single computer or a web server instead of on each system. Please refer to your Installation Guide for more information.
We recommend that you install the online documentation Help directory on your system's hard drive in the following default location:
Platform Default Location
Windows drive:\aw\StudioTools9.7\Help
  drive:\aw\StudioTools9.7\Pdf
  drive:\aw\StudioTools9.7\movies
IRIX, HP-UX, and Solaris /usr/aw/alias9.7/Help
  /usr/aw/alias9.7/Pdf
  /usr/aw/alias9.7/movies
NOTE: If you install the online documentation in the above default location, you must overwrite the current bookshelf.html file.
4     Set the Alias Preferences to read your installed Help.
Choose StudioTools Preferences > User Options > File Systems Options > Help Location to the file path or URL of your installed copy of the online documentation.
For example set your Alias Preferences to https://WebServerName/onlinedocsLink/StudioTools9.7.
Make sure you use forward slashes (/) in the file path or URL.
发表于 2002-3-4 22:29:32 | 只看该作者
我曾经装过两次能用的,
但是关闭了之后再重新启动alias就又不能用了.:!(:!(
发表于 2002-3-5 00:06:00 | 只看该作者
谢谢lights兄 我看过这help装过
就是不成 估计是有小差错 改天再试 谢谢
GMT+8, 2025-4-20 00:47 , Processed in 0.031418 second(s), 10 queries , Gzip On, Redis On.
