查看: 16118|回复: 1
proe新手的第一个程序问题?
发表于 2005-3-29 16:49:15 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
extern "C" int user_initialize()
 &nbsproError status;
 &nbsproFileName message_file;
  uiCmdCmdId cmd_id;
  status=ProCmdActionAdd("ShowTest",(uiCmdCmdActFn)ShowMessageTest,uiCmdPrioDefault,AccessDefault,PRO_B_TRUE,PRO_B_TRUE,[$cmd_id)]
  status=ProMenubarmenuPushbuttonAdd("Tools","ShowMessageTest","ShowMessageTest","Active ShowMessageTest Menu",NULL,PRO_B_TRUE,cmd_id,ProStringToWstring(message_file,"Message2.txt"));
  return status;
extern "C" void user_terminate()
  AFX_MANAGE_STATE(AfxGetStaticModuleState());
static uiCmdAccessState AccessDefault(uiCmdAccessMode access_mode)
  return(ACCESS_AVAILABLE);
int ShowMessageTest()
  AfxMessageBox("ok run",MB_OK);
  return true;
以上是李世国pro/toolkit程序设计的Example2_1,编译后出现31个连接错误可忽略,我用的的野火2.0,菜单项中没有Utilities,只有Tools中有auxiliary application项 注册总是出现startup of application failed
我看Info出现
FILE: 6
TIME: 29-Mar-05 16:46:39
Auxiliary application Information
Application 0: Example2_1
Exec path: D:\proe\solid\Example2_1\Debug\Example2_1.dll
Text path: D:\proe\solid\Example2_1\Debug\
Version 26 - 2004320
Application is not running.
这是怎么回事 望高手帮我跨过这到坎!!!!!!!!!
发表于 2005-3-30 16:02:18 | 只看该作者
这个问题你可以参照精华区里的有关vc设置的一些帖子,如果设置没问题应该不会出现上述问题
GMT+8, 2025-4-26 14:04 , Processed in 0.032944 second(s), 11 queries , Gzip On, Redis On.
