查看: 15813|回复: 0
运行ANSYS8.0出错,大家看看这个问题怎么解决?
发表于 2005-4-12 22:12:48 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
求助!我运行软件程序时提示出现下面错误,该怎么解决?
***FATAL****
The database <-db> space requested is not currently available.
Reenter ANSYS command line with less database space requested.
The above error is non-recoverable by ANSYS
ANSYS run terminated by the indicated error
Current data base saved if possible.
上面的文字是dos下显示的,摘了部分。
GMT+8, 2025-4-20 05:47 , Processed in 0.032856 second(s), 10 queries , Gzip On, Redis On.
