查看: 16205|回复: 1
约束问题
发表于 2005-4-14 15:30:17 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
选定元素,点击约束,出现问题,This constraint is created only temporarily .If you want make it permanent you need to activate the Geometrial constraint or the Dimensional constraint switch before clicking the ok button.
什么意思,怎样解决,我约束不了
发表于 2005-4-14 18:32:21 | 只看该作者
点击选上 sketch tools 中的 geometrical constraints 试试
GMT+8, 2025-3-14 21:10 , Processed in 0.019830 second(s), 11 queries , Gzip On, Redis On.
