查看: 15559|回复: 2
Urgent: UG NX3 and NASTRAN
发表于 2005-4-16 05:01:11 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
After Installing the NX3, I want to install NASTRAN, everything is ok. But following CAST, I analyse the Solid Part. and select NASTRAN as solver, it doesn't work. If I select Structure P. E, it works. I think the problem is thta Nastran is not installed suitable. Please tell me hoe to set up when I install the Nastran.
发表于 2005-4-16 06:40:31 | 只看该作者
It's seasonable. PE solver is locaded inside UGII_BASE_DIR.
you need to check syslog file to see what's happening.
read installation manuals carefully and i am sure there is information called "post installation" to tell you how to link them together. roughly saying, there is an env in UG to point where is NASTRAN. Installing NASTRAN first may help, or use default path to install both.
发表于 2005-4-16 07:06:22 | 只看该作者
我想下载UGNX3.0,不知在哪能找到它?
GMT+8, 2025-4-30 20:30 , Processed in 0.023343 second(s), 11 queries , Gzip On, Redis On.
