查看: 16882|回复: 7
哪位大哥有"手机的抗跌落研究"方面的资料
发表于 2005-4-17 16:16:17 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
传上来给小弟用用,谢谢啊!
发表于 2005-4-18 17:16:39 | 只看该作者
應該要說出手機哪方面的落下測試吧!因為其中抗落的測試有很多種囉!
发表于 2005-4-18 19:58:49 | 只看该作者
主要是手机的六个面,分析它的结构,提出当前手机在结构方面起到的抗跌落作用,当然如果能提出改善意见就更好了!
发表于 2005-4-18 23:14:26 | 只看该作者
我们老大说过一句话:
要想过落摔,就要知道手机里什么东西是最硬的?
结果他说是PCB板
所以,抗落摔得根本原则就是……………………
自己想吧
PS:我们公司的手机落摔只过1.5M的,所以说明老大的话也不一定对了
发表于 2005-4-19 10:39:28 | 只看该作者
Drop Test
RadioShack products shall withstand each of the following shipping requirements without damage:
Shipment from the original manufacturer to RadioShack warehouse. Such shipment is assumed to be in master packages and perhaps in internationally recognized shipping containers.
Re-shipment in individual gift packages to the individual RadioShack store by way of any available common carrier including Parcel Post, Express agencies and freight groups.
Final distribution to the customer in private or commercial delivery vans or in private cars.
RadioShack requires the following minimum requirements for acceptance of the individual package.
Individual package Drop Test Procedure (National Safe Transit Association Pre-shipment Test Procedures, Project 1A) Summary: One corner/three edges/six faces
Weight (Kg)
  Drop Height (cm)
0.0-9.5
  76.2
<18.6
  60.96
<27.7
  45.72
<45.4
  30.48
Note: RadioShack reserves the right of visual inspection and rejection if, in its opinion, a package has suspect qualities in spite of drop test results.
Drop Test Procedure Detail
With the packaged-product in its stable shipping position, face one end of the container and identify the surfaces as follows:
top as one;
right side as two;
bottom as three;
left side as four;
near end as five;
far end as six.
Identify edges by the numbers of those two surfaces forming that edge. For example, the edge formed by the top and the right side is identified as 1-2.
Identify corners by the numbers of those three surfaces which meet to form that corner. For example, the corner formed by the right side, bottom, and near end is identified as 2-3-5.
Drop or impact the packaged-product in the following sequence:
the 2-3-5 corner.
the shortest edge radiating from that corner.
the next longest edge radiating from that corner.
the longest edge radiating from that corner.
flat on one of the smallest faces.
flat on the opposite small face.
flat on one of the medium faces.
flat on the opposite medium face.
flat on one of the largest faces.
flat on the opposite large face.
Inspect both the package and the product. The packaged-product shall be considered to have satisfactorily  passed the test if, upon examination, the product is free from damage and the container still affords reasonable protection to the contents.
Out Of Carton Drop Tests
Products that can be attached to a user's belt by belt clip or an optional case shall pass the following out of carton drop test. Additional product-specific out of carton drop tests may be specified in that product's specific requirements section.
Product shall be set up for normal use. Drop test height shall be 50 centimeters.
Drop test surface shall be concrete covered with 1/8 inch asphalt tile (or similar tile).
Product shall be dropped a total of six times, once per surface.
Product may sustain slight damage (such as scratches, minor cracks or stress marks). Batteries may become disconnected and need to be reinstalled.  Product shall be fully operational.
Sport Products
1.  Water Resistance:
Product must meet Japanese Industrial Standard C0920-1993  section 4.6, Splash-Proof
Acceptance Criteria:
Splash-Proof  Type - No harmful effect caused by water splashed on unit from any direction. No ingress of water into the interior of the unit that will hinder the normal operation the unit.
  2.  Out-of-Box Drop Test:
Product must pass an out-of-box drop of six (6) random drops from the following height requirements.
Product will be dropped onto concrete covered with 1/8 inch of asphalt tile or similar material.
Arm Band Unit:
The unit is intended to be strapped to the upper arm of the user.
Test Conditions:
1.  Six (6) random drops from a height of sixty (60) inches (152.4cm).
2.  The headphones must be attached.
3.  The unit must have the batteries installed.
4.  A cassette unit must have a cassette installed
5.  The unit must be in Play/On mode.
The unit must operate and may sustain minor physical damage.
Handheld/Belt Clip Unit:
The unit is intended to be carried in the user's hand or clipped to the user's belt.
Test Conditions:
1.  Six (6) random drops from a height of forty-eight (48) inches (121.9cm).
Headset Unit
The unit is intended to be worn on the user's head.
Test Conditions:
1.  Six random drops from a height of  forty-eight (48) inches (121.9cm).
2.  The unit must have the batteries installed
3.  The unit must be On.
Belt Clip:
A detachable/replaceable belt clip is preferred.
Performance:
The unit must be able to operate in the normal operating environment of the product's intended use.
i.e. a belt clip unit must be able to maintain the radio channel while being bumped and jarred.
Results:
Results to be reviewed for practicality and good judgment. Any results that do not meet the criteria, will be handled on an application and/or case-by-case basis.
Radio Shack reserves the right to interpret the test results and that test results are subject to agreement between the vendor and Radio Shack.
发表于 2005-4-30 16:54:35 | 只看该作者
tks
发表于 2005-4-30 19:18:01 | 只看该作者
DROP TEST 要靠经验哦
发表于 2005-5-2 19:02:57 | 只看该作者
能够制造出真正抗跌落的手机就发了
GMT+8, 2025-4-17 14:36 , Processed in 0.028091 second(s), 11 queries , Gzip On, Redis On.
