查看: 15796|回复: 0
我怎么看不到UNV文件
发表于 2005-4-18 08:42:08 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
在i-deas中输入一个UNV文件,出现一连串的揭示:
System of Units        Length  Time      Mass          Force       Temp(R:A) MM-mm (milli-newton)   mm      sec   kilogram(kg)    milli-newton  deg C:K   Reading dataset: 151 - Header Reading dataset: 164 - Units, Double PrecisionUnits set to MM Reading dataset: 1700 - Material Database HeaderNumber of Material Headers added: 1 Reading dataset: 1703 - Material Database Property Reading dataset: 1704 - Material Database Material TypeNumber of Material Types added: 1 Reading dataset: 1705 - Material Database Variable Reading dataset: 1714 - I9 Material Database MaterialNumber of Materials added: 1 Reading dataset: 1714 - I9 Material Database MaterialNumber of Materials added: 1 Reading dataset: 1714 - I9 Material Database MaterialNumber of Materials added: 1 Reading dataset: 1714 - I9 Material Database MaterialNumber of Materials added: 1 Reading dataset: 1714 - I9 Material Database MaterialNumber of Materials added: 1 Reading dataset: 1714 - I9 Material Database MaterialNumber of Materials added: 1 Reading dataset: 1714 - I9 Material Database MaterialNumber of Materials added: 1 Reading dataset: 1714 - I9 Material Database MaterialNumber of Materials added: 1 Reading dataset: 1714 - I9 Material Database MaterialNumber of Materials added: 1 Reading dataset: 1714 - I9 Material Database MaterialNumber of Materials added: 1 Reading dataset: 1714 - I9 Material Database MaterialNumber of Materials added: 1 Reading dataset: 1714 - I9 Material Database MaterialNumber of Materials added: 1 Reading dataset: 1714 - I9 Material Database MaterialNumber of Materials added: 1 Reading dataset: 1714 - I9 Material Database MaterialNumber of Materials added: 1 Reading dataset: 1714 - I9 Material Database MaterialNumber of
大体结构如上,最后停下来了,这个样子:dataset: 1101 - BinMain:;0 Reading dataset: 1102 - Part81682:;0,MainNumber of lines read: 350377Number of datasets read: 7698
但是没有看到有模型出现啊,怎么回事啊
GMT+8, 2024-12-26 13:36 , Processed in 0.024220 second(s), 15 queries , Gzip On, Redis On.
© 2002-2024 www.iCAx.org
