查看: 17730|回复: 1
模具专业常用词汇(中英文对照)
发表于 2005-4-20 23:12:28 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
前几天在坛子里看到有人在找,还给钱,我们这个社会还是不要太黑的好!
都是为了吃饭吗!
模具专业英语
模具述语
一、入水:gate
    进入位: gate location
    水口形式:gate type
    大水口:edge gate
    细水口: pin-point gate
    水口大小:gate size
    转水口: switching runner/gate
    唧嘴口径: sprue diameter
二、流道: runner
    热流道: hot runner,hot manifold
    热嘴冷流道: hot sprue/cold runner
    唧嘴直流: direct sprue gate
    圆形流道:round(full/half runner
    流道电脑分析:mold flow analysis
    流道平衡:runner balance
    热嘴: hot sprue
    热流道板:hot manifold
    发热管:cartridge heater
    探针: thermocouples
    插头: connector plug
    插座: connector socket
    密封/封料: seal
三、运水:water line
    喉塞:line lpug
    喉管:tube
    塑胶管:plastic tube
    快速接头:jiffy quick connector plug/socker
四、模具零件: mold components
    三板模:3-plate mold
    二板模:2-plate mold
    边钉/导边:leader pin/guide pin
    边司/导套:bushing/guide bushing
    中托司:shoulder guide bushing
    中托边L:guide pin
    顶针板:ejector retainner plate
    托板: support plate
    螺丝: screw
    管钉:dowel pin
    开模槽:ply bar scot
    内模管位:core/cavity inter-lock
    顶针: ejector pin
    司筒:ejector sleeve
    司筒针:ejector pin
    推板:stripper plate
    缩呵:movable core,return core core puller
    扣机(尼龙拉勾):nylon latch lock
    斜顶:lifter
    模胚(架): mold base
    上内模:cavity insert
    下内模:core insert
    行位(滑块): slide
    镶件:insert
    压座/斜鸡:wedge
    耐磨板/油板:wedge wear plate
    压条:plate
    撑头: support pillar
    唧嘴: sprue bushing
    挡板:stop plate
    定位圈:locating ring
    锁扣:latch
    扣鸡:parting lock set
    推杆:push bar
    栓打螺丝:S.H.S.B
    顶板:eracuretun
    活动臂:lever arm
    分流锥:spure sperader
    水口司:bush
    垃圾钉:stop pin
    隔片:buffle
    弹弓柱:spring rod
    弹弓:die spring
    中托司:ejector guide bush
    中托边:ejector guide pin
    镶针:pin
    销子:dowel pin
    波子弹弓:ball catch
    喉塞: pipe plug
    锁模块:lock plate
    斜顶:angle from pin
    斜顶杆:angle ejector rod
    尼龙拉勾:parting locks
    活动臂:lever arm
    复位键、提前回杆:early return bar
    气阀:valves
    斜导边:angle pin
    术语:terms
    承压平面平衡:parting surface support balance
    模排气:parting line venting
    回针碰料位:return pin and cavity interference
    模总高超出啤机规格:mold base shut hight
    顶针碰运水:water line interferes withejector pin
    料位出上/下模:part from cavith (core) side
    模胚原身出料位:cavity direct cut on A-plate,core direct cut on B-plate.
    不准用镶件: Do not use (core/cavity) insert
    用铍铜做镶件: use beryllium copper insert
    初步(正式)模图设计:preliinary (final) mold design
    反呵:reverse core
    弹弓压缩量:spring compressed length
    稳定性好:good stability,stable
    强度不够:insufficient rigidity
    均匀冷却:even cooling
    扣模:sticking
    热膨胀:thero expansion
    公差:tolorance
    铜公(电极):copper electrode
    动模   movable mould moving half
  定模座板   fixed clamp plate, top clamping plate. top plate
  动模座板   moving clamp plate. bottom clamping plate. bottom plate
  上模座板   upper clamping plate
  下模座板   lower clamping plate
  凹模固定板   cavity-retainer plate
  型芯固定板   core-retainer plate
  凸模固定板   punch-retainer plate
   模套   chase. bolster. frame
  支承板   backing plate. supprr plate
   垫块   spacer parallel
   支架   ejector housing. mould base leg
      压力铸造模具   die-casting die
  压铸模零部件
  定模   fixed die, cover die
  定模座板   fixed clamping plate
  定模套板   bolstor, fixed die
  动模   moving die,ejector die
  动模座板   moving clamping plate
  直流道   sprue
  横流道   runner
发表于 2005-4-21 08:18:43 | 只看该作者
xxn
GMT+8, 2025-2-26 18:52 , Processed in 0.021721 second(s), 10 queries , Gzip On, Redis On.
