查看: 16534|回复: 2
【求助】使用pro_batch中遇到的问题。
发表于 2002-12-7 18:27:46 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
在命令行中建入:
C:\>pro_batch -text (step)
************************ Batch File Execution *****************************
A carriage return after any prompt will result in the use of the
value specified within the brackets ([]).
Entering the command "quit" after any prompt will allow you to
exit. If you are in command file creation, "quit" will return
you to the Batch File Execution level. Entering "quit" at that
level will get you out of the program.
A list of intended file names will be created under
the name C:\pro_batch_list.txt
Do you wish to run an existing command file [No] ?
Enter the name for the new command file [C:\bfile.txt]:  test
File already exists. Delete [Yes] ?
Using test.
              ********** Begin command file creation **********
Enter the type of command line to be created [1] :
         1. plot
         2. stl
         3. iges
         4. dxf
         5. CADamin
         6. cl_file
         7. set
         8. vda
         9. step
        10. cgm
        11. vrml
        12. upgrade
Enter the full name of the object []:  base.prt
The following command line has been added to
test:
  -step -object base.prt
Would you like to create another command line [No]?
       ********** End of Command file Creation **********
Do you want to execute the batch command file [Yes] ?
The list of files to be created can be found under
C:\pro_batch_list.txt.
Do you want to plot the output file(s) ? [No]
Running pro_batch ...
The messages are output to file std.out.
此时不应有 0。
********* Batch File Execution Completed with failures **********
C:\>
换了其他的输出格式,问题同样出现,不知道那位大虾能帮忙看一下,不胜感激!!
hybox@sina.com
发表于 2002-12-10 15:21:09 | 只看该作者
建议斑竹将proe命令行中的各个命令用法定义讲解一番,新手必会受益!
(嘿嘿,看我提了一个多么有益于菜鸟的意见,从而证明我是个高尚的人、一
脱离了低级趣味的人、一个有益于人类的人,最重要的:一个应该得到加分的人。)
发表于 2002-12-10 18:28:44 | 只看该作者
Pro_Batch好象有个Windows版的,为什么不用呢
你这个Dos的我没试过
GMT+8, 2025-4-23 07:36 , Processed in 0.021128 second(s), 12 queries , Gzip On, Redis On.
