双11·3D打印优惠活动
查看: 16721|回复: 2
哪位知道uf5940/41是什么函数?
发表于 2005-4-27 05:53:07 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
找了好久,也没有找到这俩个函数,谢谢哪位朋友了。
发表于 2005-4-27 21:58:47 | 只看该作者
在帮助文件里所搜一下不久ok了
Returns a matrix to map coordinates from one coordinate system to another.
  NOTE: rp1 and rp2 are invalid when they contain a zero direction vector, or
  the X and Y vectors are parallel.
  Return:
        void.
  Environment: Internal & External
  See Also:
  History:
extern UFUNEXPORT void FTN(uf5940)(
double *rp1,    /* <I>
                Real Data For Reference Coordinate System
                rp1[0-2] is the origin in absolute coordinates.
                rp1[3-8] are the X and Y vectors in absolute coordinates.
double *rp2,   /* <I>
               Real Data For Destination Coordinate System
                rp2[0-2] is the origin in absolute coordinates.
                rp2[3-8] are the X and Y vectors in absolute coordinates.
double *rr3,   /* <O>
                  Resulting Matrix.  This must be declared to hold 16 doubles.
int *ir4      /* <O>
                  Status Code
                     0 = Success
                     1 = rp1 Is Invalid
                     2 = rp2 Is Invalid
Returns the transformation of a position. No new objects are created here.
When rp2 is the "Change Coordinate" matrix (from UF5940), ra1 should be a
position with respect to the reference coordinate system in the input in order
to get back ra1 as a position with respect to the destination coordinate system
in the output. When rp2 is any other type of transformation matrix, ra1 should
be a position in the absolute coordinates. The output in ra1 is then a
transformed position in absolute coordinates as well.
Return: void.
See Also:
History:
extern UFUNEXPORT void FTN(uf5941)(
double *ra1,              /* <I/O>
                            &nbsposition/ Transformed Position
double *rp2               /* <I>
                          Defined Transformation Matrix.  This must be declared
                          to hold 16 doubles.
发表于 2005-4-27 23:24:12 | 只看该作者
太感谢qingwufy了^_^。不好意思,我还真不知道怎么在帮助文件里搜索函数呢。
GMT+8, 2025-10-20 23:24 , Processed in 0.026966 second(s), 11 queries , Gzip On, Redis On.
