pm5.5中把各种加工方式分类加入右键菜单---方便
发表于 2005-5-8 21:16:26 | 只看该作者
PM中的自定义右键菜单功能可以根据新的版本 自己的需要及爱好不断增加和
更新 真的很方便 推荐广大PM用户发挥使用
发表于 2005-5-8 22:43:16 | 只看该作者
本人的user_menu文件 敬请参考 以下为此文件内容:
U user_menu
T "ZHL MENU"
S
I "刷新隐藏" 1 "UNDRAW TOOL ALL UNDRAW PATTERN ALL UNDRAW BOUNDARY ALL UNDRAW FEATURESET ALL REFRESH"
S
M "粗加工"
I "偏置" 1 "IMPORT TEMPLATE ENTITY TOOLPATH D:\ZHLhome\myPTF\Offset-AreaClear-Model.ptf FORM TOOLPATH"
I "平行" 1 "IMPORT TEMPLATE ENTITY TOOLPATH D:\ZHLhome\\myPTF\Raster-AreaClear-Model.ptf FORM TOOLPATH"
I "轮廓" 1 "IMPORT TEMPLATE ENTITY TOOLPATH D:\ZHLhome\\myPTF\Profile-AreaClear-Model.ptf FORM TOOLPATH"
Z
M "精加工"
I "等高" 1 "IMPORT TEMPLATE ENTITY TOOLPATH D:\ZHLhome\myPTF\Constant-Z-Finishing.ptf FORM TOOLPATH"
I "平行" 1 "IMPORT TEMPLATE ENTITY TOOLPATH D:\ZHLhome\myPTF\Raster-Finishing.ptf FORM TOOLPATH"
I "三维偏置" 1 "IMPORT TEMPLATE ENTITY TOOLPATH D:\ZHLhome\myPTF\3D-Offset-Finishing.ptf FORM TOOLPATH"
I "参考线" 1 "IMPORT TEMPLATE ENTITY TOOLPATH D:\ZHLhome\myPTF\Pattern-Finishing.ptf FORM TOOLPATH"
I "放射线" 1 "IMPORT TEMPLATE ENTITY TOOLPATH D:\ZHLhome\myPTF\Radial-Finishing.ptf FORM TOOLPATH"
M "清角"
I "沿着" 1 "IMPORT TEMPLATE ENTITY TOOLPATH D:\ZHLhome\myPTF\Corner-Along-Finishing.ptf FORM TOOLPATH"
I "笔式" 1 "IMPORT TEMPLATE ENTITY TOOLPATH D:\ZHLhome\myPTF\Corner-Pencil-Finishing.ptf FORM TOOLPATH"
I "自动" 1 "IMPORT TEMPLATE ENTITY TOOLPATH D:\ZHLhome\myPTF\Corner-Automatic-Finishing.ptf FORM TOOLPATH"
I "缝合" 1 "IMPORT TEMPLATE ENTITY TOOLPATH D:\ZHLhome\myPTF\Corner-Stitch-Finishing.ptf FORM TOOLPATH"
I "多笔" 1 "IMPORT TEMPLATE ENTITY TOOLPATH D:\ZHLhome\myPTF\Corner-MultiPencil-Finishing.ptf FORM TOOLPATH"
Z
M "投影"
I "曲线" 1 "IMPORT TEMPLATE ENTITY TOOLPATH D:\ZHLhome\myPTF\Projection-Curve-Finishing.ptf FORM TOOLPATH"
I "直线" 1 "IMPORT TEMPLATE ENTITY TOOLPATH D:\ZHLhome\myPTF\Projection-Line-Finishing.ptf FORM TOOLPATH"
I "平面" 1 "IMPORT TEMPLATE ENTITY TOOLPATH D:\ZHLhome\myPTF\Projection-Plane-Finishing.ptf FORM TOOLPATH"
I "点" 1 "IMPORT TEMPLATE ENTITY TOOLPATH D:\ZHLhome\myPTF\Projection-Point-Finishing.ptf FORM TOOLPATH"
I "曲面" 1 "IMPORT TEMPLATE ENTITY TOOLPATH D:\ZHLhome\myPTF\Projection-Surface-Finishing.ptf FORM TOOLPATH"
Z
I "最佳等高" 1 "IMPORT TEMPLATE ENTITY TOOLPATH D:\ZHLhome\myPTF\Optimised-Constant-Z-Finishing.ptf FORM TOOLPATH"
I "嵌入线" 1 "IMPORT TEMPLATE ENTITY TOOLPATH D:\ZHLhome\myPTF\Embedded-Pattern-Finishing.ptf FORM TOOLPATH"
I "轮廓" 1 "IMPORT TEMPLATE ENTITY TOOLPATH D:\ZHLhome\myPTF\Profile-Finishing.ptf FORM TOOLPATH"
I "旋转" 1 "IMPORT TEMPLATE ENTITY TOOLPATH D:\ZHLhome\myPTF\Rotary-Finishing.ptf FORM TOOLPATH"
I "螺旋" 1 "IMPORT TEMPLATE ENTITY TOOLPATH D:\ZHLhome\myPTF\Spiral-Finishing.ptf FORM TOOLPATH"
I "SWARF" 1 "IMPORT TEMPLATE ENTITY TOOLPATH D:\ZHLhome\myPTF\Swarf-Finishing.ptf FORM TOOLPATH"
Z
I "钻孔" 1 "IMPORT TEMPLATE ENTITY TOOLPATH D:\ZHLhome\myPTF\Drilling.ptf FORM TOOLPATH"
#S
#I "ISO查看" 1 "UNDRAW TOOL ALL REFRESH ROTATE TRANSFORM ISO2"
#I "+Z查看" 1 "UNDRAW TOOL ALL REFRESH ROTATE TRANSFORM TOP"
#I "-Y查看" 1 "UNDRAW TOOL ALL REFRESH ROTATE TRANSFORM FRONT"
#I "+X查看" 1 "UNDRAW TOOL ALL REFRESH ROTATE TRANSFORM RIGHT"
#I "+Y查看" 1 "UNDRAW TOOL ALL REFRESH ROTATE TRANSFORM BACK"
#I "-X查看" 1 "UNDRAW TOOL ALL REFRESH ROTATE TRANSFORM LEFT"
S
I "之形" 1 "EDIT TOOLPATH ZIGZAG"
I "反向" 1 "EDIT TOOLPATH REVERSE"
I "反顺序" 1 "EDIT TOOLPATH REVERSE_ORDER"
S
I "缺省连接" 1 "MACRO D:\ZHLHOME\PMILL4\LEADS.MAC"
I "圆弧连接" 1 "MACRO D:\ZHLHOME\PMILL4\ARCLEADS.MAC"
I "安全基准" 1 "EDIT SAFZ 25 EDIT STAZ 5 EDIT DATUM X 0 EDIT DATUM Y 0 EDIT DATUM Z 50 RESET TOOLPATH RAPID RESET TOOLPATH DATUM"
S
I "打开模型" 1 "IMPORT MODEL FILEOPEN"
Z
注意其中D:\ZHLhome\myPTF文件夹为自建文件夹 其中存放各种加工方式的.ptf文件 这些文件是从pmill中自带原文件复制过来的
太好了顶啊
发表于 2005-6-7 13:29:37 | 只看该作者
真是感謝您的分享!!
发表于 2005-6-7 21:10:35 | 只看该作者
请问是怎么加的 我还是搞不懂 请赐教
发表于 2005-6-7 21:13:32 | 只看该作者
各位大哥能否给我一个user_menu文件呢
发表于 2005-6-8 12:25:31 | 只看该作者
其实没啥用,哈哈
发表于 2005-6-12 17:20:44 | 只看该作者
dddddd
18
发表于 2005-6-12 21:39:29 | 只看该作者
能具体说一下是怎么弄的吗?  谢了!
19
发表于 2005-7-23 20:24:08 | 只看该作者
哈哈,我的更好用呀,在右键前加上不同的英文不是更好用吗?
发表于 2005-7-23 20:26:31 | 只看该作者
加上英文直接按键盘就好了,快很多的!!!!
GMT+8, 2025-4-19 01:50 , Processed in 0.024081 second(s), 10 queries , Gzip On, Redis On.
