查看: 24342|回复: 46
pm5.5中把各种加工方式分类加入右键菜单---方便
发表于 2005-4-28 21:31:41 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
pm5.5中选用各种加工方式有时显的很罗嗦 不知各位同仁是否有同感
我将各种加工方式分类并按一定顺序自定义编辑加入右键菜单 感觉很
方便快捷 有哪位感兴趣的老兄可以跟帖
发表于 2005-4-29 01:54:54 | 只看该作者
早加了! 习惯就好!
发表于 2005-4-29 08:34:03 | 只看该作者
可不可以设成快捷键啊,如果可以的话就好了。
发表于 2005-4-30 01:00:55 | 只看该作者
以后可能会有的!~
发表于 2005-4-30 16:40:22 | 只看该作者
如何加,请不吝指教
发表于 2005-5-1 19:55:53 | 只看该作者
本人的user_menu文件 敬请参考 以下为此文件内容:
U user_menu
T "ZHL MENU"
S
I "刷新隐藏" 1 "UNDRAW TOOL ALL UNDRAW PATTERN ALL UNDRAW BOUNDARY ALL UNDRAW FEATURESET ALL REFRESH"
S
M "粗加工"
I "偏置" 1 "IMPORT TEMPLATE ENTITY TOOLPATH D:\ZHLhome\myPTF\Offset-AreaClear-Model.ptf FORM TOOLPATH"
I "平行" 1 "IMPORT TEMPLATE ENTITY TOOLPATH D:\ZHLhome\\myPTF\Raster-AreaClear-Model.ptf FORM TOOLPATH"
I "轮廓" 1 "IMPORT TEMPLATE ENTITY TOOLPATH D:\ZHLhome\\myPTF\Profile-AreaClear-Model.ptf FORM TOOLPATH"
Z
M "精加工"
I "等高" 1 "IMPORT TEMPLATE ENTITY TOOLPATH D:\ZHLhome\myPTF\Constant-Z-Finishing.ptf FORM TOOLPATH"
I "平行" 1 "IMPORT TEMPLATE ENTITY TOOLPATH D:\ZHLhome\myPTF\Raster-Finishing.ptf FORM TOOLPATH"
I "三维偏置" 1 "IMPORT TEMPLATE ENTITY TOOLPATH D:\ZHLhome\myPTF\3D-Offset-Finishing.ptf FORM TOOLPATH"
I "参考线" 1 "IMPORT TEMPLATE ENTITY TOOLPATH D:\ZHLhome\myPTF\Pattern-Finishing.ptf FORM TOOLPATH"
I "放射线" 1 "IMPORT TEMPLATE ENTITY TOOLPATH D:\ZHLhome\myPTF\Radial-Finishing.ptf FORM TOOLPATH"
M "清角"
I "沿着" 1 "IMPORT TEMPLATE ENTITY TOOLPATH D:\ZHLhome\myPTF\Corner-Along-Finishing.ptf FORM TOOLPATH"
I "笔式" 1 "IMPORT TEMPLATE ENTITY TOOLPATH D:\ZHLhome\myPTF\Corner-Pencil-Finishing.ptf FORM TOOLPATH"
I "自动" 1 "IMPORT TEMPLATE ENTITY TOOLPATH D:\ZHLhome\myPTF\Corner-Automatic-Finishing.ptf FORM TOOLPATH"
I "缝合" 1 "IMPORT TEMPLATE ENTITY TOOLPATH D:\ZHLhome\myPTF\Corner-Stitch-Finishing.ptf FORM TOOLPATH"
I "多笔" 1 "IMPORT TEMPLATE ENTITY TOOLPATH D:\ZHLhome\myPTF\Corner-MultiPencil-Finishing.ptf FORM TOOLPATH"
Z
M "投影"
I "曲线" 1 "IMPORT TEMPLATE ENTITY TOOLPATH D:\ZHLhome\myPTF\Projection-Curve-Finishing.ptf FORM TOOLPATH"
I "直线" 1 "IMPORT TEMPLATE ENTITY TOOLPATH D:\ZHLhome\myPTF\Projection-Line-Finishing.ptf FORM TOOLPATH"
I "平面" 1 "IMPORT TEMPLATE ENTITY TOOLPATH D:\ZHLhome\myPTF\Projection-Plane-Finishing.ptf FORM TOOLPATH"
I "点" 1 "IMPORT TEMPLATE ENTITY TOOLPATH D:\ZHLhome\myPTF\Projection-Point-Finishing.ptf FORM TOOLPATH"
I "曲面" 1 "IMPORT TEMPLATE ENTITY TOOLPATH D:\ZHLhome\myPTF\Projection-Surface-Finishing.ptf FORM TOOLPATH"
Z
I "最佳等高" 1 "IMPORT TEMPLATE ENTITY TOOLPATH D:\ZHLhome\myPTF\Optimised-Constant-Z-Finishing.ptf FORM TOOLPATH"
I "嵌入线" 1 "IMPORT TEMPLATE ENTITY TOOLPATH D:\ZHLhome\myPTF\Embedded-Pattern-Finishing.ptf FORM TOOLPATH"
I "轮廓" 1 "IMPORT TEMPLATE ENTITY TOOLPATH D:\ZHLhome\myPTF\Profile-Finishing.ptf FORM TOOLPATH"
I "旋转" 1 "IMPORT TEMPLATE ENTITY TOOLPATH D:\ZHLhome\myPTF\Rotary-Finishing.ptf FORM TOOLPATH"
I "螺旋" 1 "IMPORT TEMPLATE ENTITY TOOLPATH D:\ZHLhome\myPTF\Spiral-Finishing.ptf FORM TOOLPATH"
I "SWARF" 1 "IMPORT TEMPLATE ENTITY TOOLPATH D:\ZHLhome\myPTF\Swarf-Finishing.ptf FORM TOOLPATH"
Z
I "钻孔" 1 "IMPORT TEMPLATE ENTITY TOOLPATH D:\ZHLhome\myPTF\Drilling.ptf FORM TOOLPATH"
#S
#I "ISO查看" 1 "UNDRAW TOOL ALL REFRESH ROTATE TRANSFORM ISO2"
#I "+Z查看" 1 "UNDRAW TOOL ALL REFRESH ROTATE TRANSFORM TOP"
#I "-Y查看" 1 "UNDRAW TOOL ALL REFRESH ROTATE TRANSFORM FRONT"
#I "+X查看" 1 "UNDRAW TOOL ALL REFRESH ROTATE TRANSFORM RIGHT"
#I "+Y查看" 1 "UNDRAW TOOL ALL REFRESH ROTATE TRANSFORM BACK"
#I "-X查看" 1 "UNDRAW TOOL ALL REFRESH ROTATE TRANSFORM LEFT"
S
I "之形" 1 "EDIT TOOLPATH ZIGZAG"
I "反向" 1 "EDIT TOOLPATH REVERSE"
I "反顺序" 1 "EDIT TOOLPATH REVERSE_ORDER"
S
I "缺省连接" 1 "MACRO D:\ZHLHOME\PMILL4\LEADS.MAC"
I "圆弧连接" 1 "MACRO D:\ZHLHOME\PMILL4\ARCLEADS.MAC"
I "安全基准" 1 "EDIT SAFZ 25 EDIT STAZ 5 EDIT DATUM X 0 EDIT DATUM Y 0 EDIT DATUM Z 50 RESET TOOLPATH RAPID RESET TOOLPATH DATUM"
S
I "打开模型" 1 "IMPORT MODEL FILEOPEN"
Z
注意其中D:\ZHLhome\myPTF文件夹为自建文件夹 其中存放各种加工方式的.ptf文件 这些文件是从pmill中自带原文件复制过来的
发表于 2005-5-1 20:20:39 | 只看该作者
以下是自定义快捷菜单效果:
发表于 2005-5-1 22:06:38 | 只看该作者
zhl77586 wrote:
以下是自定义快捷菜单效果:
我也是像你这样 设的太深了 反而不方便了
发表于 2005-5-3 15:22:29 | 只看该作者
发表于 2005-5-8 20:29:38 | 只看该作者
  U user_menu
  T "ZHL MENU"
  S
  S
  M "粗加工"
  Z
  M "精加工"
  M "清角"
  Z
  M "投影"
  Z
  Z
  #S
  S
  S
  S
  Z
好,顶
GMT+8, 2025-4-18 05:38 , Processed in 0.033540 second(s), 11 queries , Gzip On, Redis On.
