查看: 20902|回复: 18
我做的一个气辅成型分析
发表于 2005-5-5 09:41:36 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
      气体可以走得很远,但是窜气比较严重,而且离气针较远处的气体吹空的体积很小。
      如何改善,请大家发表见解。谢谢!
发表于 2005-5-5 09:44:31 | 只看该作者
胶料的厚度(气道处的厚度是5mm,其他3mm)
发表于 2005-5-5 09:47:30 | 只看该作者
成型参数的设置:
Machine Name:     J1300EIII 5000H B
Material Name:    Novodur PMTM : Bayer USA
------------------------------------------------------------------------Machine Specification:
Maximum pressure:                              142.0000 MPa
Screw diameter:                                120.0000 mm
Maximum injection speed:                        89.3036 mm/s
Screw intensification ratio:                    10.0000
Machine response time:                            0.010 s
  Machine maximum clamp force:                  1300.0000 tonne
------------------------------------------------------------------------Temperature Settings
------------------------------------------------------------------------Melt temperature:                              240.0000 C
Mold cavity_side temperature:                   65.0000 C
Mold core-side temperature:                     65.0000 C
------------------------------------------------------------------------Injection Settings
------------------------------------------------------------------------Injection control method: Stroke vs ram speed
Injection profile:
         Ram position(mm)             Ram speed(mm/s)
          300.0000                  23.2189
          290.0000                  23.2189
          250.0000                  89.3036
          150.0000                  35.7214
           80.0000                   4.4652
            5.0000                   4.4652
            0.0000                   4.4652
Packing pressure profile
          Duration                 Pressure
             (s)                     (MPa)
            0.0000                  51.3028
           11.1000                  51.3028
Cooling time:                                   30.0000 s
------------------------------------------------------------------------Valve Gate Control Settings
------------------------------------------------------------------------   Valve gate opens and closes by:
         Control ID          Open                   Close
          1                  0.0000 s              3.5000 s
------------------------------------------------------------------------Gas Injection Control Settings
------------------------------------------------------------------------Gas injection controller no.   1 :
   Material                                           = Compressed Nitrogen
   ID                                                 =   1
   Gas injection control method                       = Pressure control
   Gas delay time                                     =      1.8000 s
   Gas injection time                                 =      8.0000 s
   Gas pressure vs time profile:
           time (s)             pressure (MPa)
            0.0000                 0.0000
   Maximum gas pressure                               =     10.0000 MPa
   Number of gas entrances using this controller      =       4
   Timer for closing polymer injection location shut-off valve = 5.25 s
------------------------------------------------------------------------Results from Flow  Analysis
Total volume of the part and cold runners:    1566.8200 cm^3
Switch-over Pressure:                           64.1285 MPa
Maximum clamp force required:                  768.4105 tonne
发表于 2005-5-6 12:48:20 | 只看该作者
传来学习学习
发表于 2005-5-6 17:10:19 | 只看该作者
chengx3655 wrote:
传来学习学习
传什么啊?sdy图档?
发表于 2005-5-6 17:12:28 | 只看该作者
某条件下的流动进气情况,由于流动不平衡,气体的进入方向有选择性
发表于 2005-5-7 10:41:00 | 只看该作者
      气体总是朝压力最小的方向前进。按道理,气针两边的气体是差不多的,而且在拐角处的窜气应该向外吧。moldex的结果似乎有点不合理。
      一己之见,欢迎讨论。
发表于 2005-5-7 11:55:07 | 只看该作者
拐角处的窜气不明显,是因为我把拐角的气道做了调整,且进气位置也做了调整
发表于 2005-5-7 12:03:26 | 只看该作者
气道是直角形状的,穿气明显一点
发表于 2005-5-7 12:51:23 | 只看该作者
4点进胶流动平衡时候的进气情况如图
GMT+8, 2025-4-23 18:40 , Processed in 0.036459 second(s), 11 queries , Gzip On, Redis On.
